Home » Modeling » EMF » rool back on resource creation
rool back on resource creation [message #415510] |
Wed, 19 December 2007 13:26 |
Originally posted by: laurent.legoff.geensy.com
I'm about to integrate transaction plugin into our tool. To learn this
new api, I read the documentation and I write some test code to
manipulate the api. I wonder why a resource is not remove from
resourceset after a rollback, in the transaction I just create a
resource in a resource and add content in this resource. Is is anyone
know why this is done like this?
see the code below, the last assert is not what I'm waiting.
thanks
public void testAbortTransaction()
final int [] ntimes = new int[]{0};
ResourceSetListenerImpl resourceSetListener = new ResourceSetListenerImpl(){
public Command transactionAboutToCommit(ResourceSetChangeEvent
event) throws RollbackException {
ntimes[0]++;
assertTrue(event.getNotifications().size() >= 1);
throw new
RollbackException(PlatformExceptionUtil.createErrorStatus("Roll back"));
editingDomain.addResourceSetListener(resourceSetListener);
final Resource [] resource = new Resource[1];
RecordingCommand command = new RecordingCommand(editingDomain,
"Test Recording Transaction", "Test Recording Transaction") {
protected void doExecute()
resource[0] = createResource();
Person person = PeopleFactory.eINSTANCE.createPerson();
resource[0].getContents().add(person);
assertFalse(resource[0].getContents().isEmpty());
editingDomain.getCommandStack().execute(command);
editingDomain.removeResourceSetListener(resourceSetListener) ;
assertEquals(ntimes[0], 1);
// the transaction has been aborted and resource have to be empty
assertTrue(resource[0].getContents().isEmpty());
// the resource set is not empty !!
assertTrue(editingDomain.getResourceSet().getResources().isE mpty());
Re: rool back on resource creation [message #415515 is a reply to message #415514] |
Wed, 19 December 2007 15:30 |
Thank you,
But I don't understand why object cannot be reverted to proxy if there's
an undo. This is not a real "RollBack" or "Undo".
This is a feature or a bug?
thank you for being so quick to answer ;-)
Laurent
Ed Merks a écrit :
> Laurent,
> Chris can best answer this but because proxy resolves can cause
> resources to be added you generally can't expect proxies to be
> unresolved as part of undo...
> Laurent Le Goff wrote:
>> Hello,
>> thanks
>> ntimes[0]++;
>> throw new
>> @Override
Re: rool back on resource creation [message #415516 is a reply to message #415514] |
Wed, 19 December 2007 15:36 |
Hi, Ed,
Did you mean Christian?
In any case, rollback and undo only revert changes to the resource contents.
The Transaction API treats the entire resource set as an interconnected
data set, and the resources as meta-data in the classic sense of "data
about data." Transactions record and manage only changes to the data,
which includes changes to the existence of objects (as members of resource
contents lists).
You should find that the contents that you added to the new resource are not
present after a rollback, but the resource will still exist and will still
be loaded.
HTH,
Christian
Ed Merks wrote:
> Laurent,
>> Hello,
>> thanks
-----8<-----
Re: rool back on resource creation [message #415519 is a reply to message #415515] |
Wed, 19 December 2007 15:54 |
Hi, Laurent,
This behaviour is the designed intent, so I suppose it would be classified
as a "feature."
Resolving a proxy or loading a resource doesn't change any data (or, more
specifically, the *abstract state* of any objects) so why would you unload
it?
cW
> Thank you,
> Laurent
-----8<-----
Re: rool back on resource creation [message #415521 is a reply to message #415516] |
Wed, 19 December 2007 16:13 |
Thank you. Your response satisfy my curiosity.
Laurent
Christian W. Damus a écrit :
> Hi, Ed,
> contents lists).
> be loaded.
> HTH,
> Christian
> Ed Merks wrote:
>> Laurent,
>>> Hello,
>>> thanks
> -----8<-----
Re: rool back on resource creation [message #415523 is a reply to message #415516] |
Wed, 19 December 2007 17:52 |
Ed Merks Messages: 33137 Registered: July 2009 |
--------------090906010407080006010607
Christian,
Sorry. Today is just not my day. I just had a car accident too. :'(
If only people would use those handy signals and wouldn't feel the need
to turn right and then left in icy conditions.
Christian W. Damus wrote:
> Hi, Ed,
> contents lists).
> be loaded.
> HTH,
> Christian
> Ed Merks wrote:
>> Laurent,
>>> Hello,
>>> thanks
> -----8<-----
<html>
<head>
</head>
Christian,<br>
<br>
Sorry. Today is just not my day. I just had a car accident too. <span
class="moz-smiley-s15"><span> :'( </span></span> If only people
would use those handy signals and wouldn't feel the need to turn right
and then left in icy conditions.<br>
<br>
<br>
<blockquote cite="mid:fkbdpd$38n$1@build.eclipse.org" type="cite">
<pre wrap="">Hi, Ed,
contents lists).
be loaded.
HTH,
Christian
Ed Merks wrote:
</pre>
<blockquote type="cite">
<pre wrap="">Laurent,
</pre>
<pre wrap="">Hello,
thanks
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
-----8<-----
</pre>
</blockquote>
<br>
</body>
</html>
--------------090906010407080006010607--
Ed Merks
Current Time: Fri Apr 19 22:55:44 GMT 2024
Powered by FUDForum. Page generated in 0.02883 seconds
