Change Description/Change Summary Example [message #415507] |
Wed, 19 December 2007 03:55 |
Originally posted by: mduduzi.keswa.isizwe.com
Hi All,
I have been reading on SDO and EMF and how they both handle "audit
trail" of an object. I have decided follow the EMF(T) roadmap and SDO
seems to have branched off a bit.
I'm currently playing with Teneo-Hibernate and would like to incorporate
"Change Description" API of EMF to do the following:
1. Generate a "Change Description"/"audit trail" to attach a changed
object.
2. I'd be nice if "Change Description"'s can be associated with some user
session ID or transaction (is this what SDO calls objectGraph?)
3. Define a metamodel/Epackage for "Change Description" so that it can be
stored via Teneo-Hibernate
4. Be able to Redo/Undo
5. Would something like EMF Compare help out here - I'm not familiar with
it?
If someone out there can provide an example of playing with any of the
above wishlist capability, I'd appreciate it.
Thanks in advance,
-Mdu
Re: Change Description/Change Summary Example [message #415508 is a reply to message #415507] |
Wed, 19 December 2007 06:48 |
Hi Mdu,
CDO is a (EMFT) technology that has built-in support for auditing/audit
trails.
I probably can't help you to connect the technological snippets that you
listed but if you give a bit more background about your requirements we
could see if CDO is a possible solution.
Usually a CDO client opens a session to a CDO model repository. Then it
uses this session to open a *transaction* :
CDOSession session = CDOUtil.openSession(connector, "repoName");
CDOTransaction transaction = session.openTransaction();
Resource resource = transaction.createResource("...");
// Navigate and modify EObjects, just work normally with them....
transaction.commit();
If this CDO model repository was configured to support auditing you can
also open an *audit view* instead of a transaction:
long oneHourAgo = System.currentTimeMillis() - 60L * 60L* 1000L;
CDOAudit audit = session.openAudit(oneHourAgo);
Resource resource = audit.getResource("...");
// Navigate EObjects, work normally with them, just don't modify
them....
Eike Stepper
http://wiki.eclipse.org/CDO
http://wiki.eclipse.org/Net4j
Mdu schrieb:
> Hi All,
> incorporate "Change Description" API of EMF to do the following:
> object.
> user session ID or transaction (is this what SDO calls objectGraph?)
> be stored via Teneo-Hibernate
> with it?
> Thanks in advance,
> -Mdu
Cheers
/Eike
http://www.esc-net.de
Re: Change Description/Change Summary Example [message #415616 is a reply to message #415508] |
Sat, 22 December 2007 01:13 |
Eike,
Thanks for insightful response on CDO. The web application framework
requirements of what I'm trying to build are as follows:
1) Be based on MDA and SOA
2) Be able to use metamodel to automagically do the following:
2.1) A FormsBuilder that behaves like MS InfoPath (w/ DataSources onto
which form fields can be bound at design time). This has to be web based
using Ajax along the way.
...etc
3) Ability to configure (via web app UI) any class/entity within a
metamodel to turn off/on audit trails and support ff. queries on audit
trails:
3.1) Show all models/resources that we changed by user U during session
S.
3.2) Show all models/resources that were read by user U during session
S.
...etc
4) Automagically generate all artifacts of a web based application to
support serialization of models to be manipulated by a web client (via
Ajax or other)
5) Support for electronic signatures around signed forms in 2.1 - long
shot here.
5.1) Support for attaching electronic signatures around 'Object
Changes'. e.g. If a user submits a form to change certain sensitive
models, they'll be asked sign (maybe re-enter user/pwd) and have that
signature linked to all affected changes and be made immutabe.
6) Ability to support "change management" better by allowing changing of
metamodels and then automagically re-generate artifacts thus shortening
time-2-market on any app customization
7) Seamless integration with workflow tools such as jBPM by using 2.1
Ok, I can settle for the ff.:
2008 Wishlist to Santa: 1,2,3; others can follow long after this
Practical Questions:
1. What are fundamental differences between CDO and Teneo?
2. Can I embed CDO within app server like JBoss/Liferay(Portal) to simply
use it for services such a audit trails?
Thanks again,
-Mdu
Re: Change Description/Change Summary Example [message #415622 is a reply to message #415616] |
Sat, 22 December 2007 12:33 |
Ed Merks Messages: 33140 Registered: July 2009 |
Mdu,
Comments below.
Mdu wrote:
> Eike,
You forgot the "TM" (trademark) on MDA. :-P Isn't everything SOA these
days? It seems more of a state of mind than a thing of substance, but
that's just my personal opinion...
> onto which form fields can be bound at design time). This has to be
> web based using Ajax along the way.
The properties view is very much like a form and with the new data
binding framework support in EMF 2.4 you can easily bind EMF objects to
views. Also, with the RAP project, you can build GUIs using Eclipse
that are rendered using AJAX.
> ...etc
> trails:
You can certain turn off change recording or ignore the changes (though
I'm not sure what's the implication of ignoring changes).
> session S.
The change recorder does that.
> session S.
The resources that are demand loaded into the resource set will be the
ones the user read.
> ...etc 4) Automagically generate all artifacts of a web based
> application to support serialization of models to be manipulated by a
> web client (via Ajax or other)
We don't have any existing code to generate a web application, but it's
certainly possible to extend the templates to generate such things;
org.eclipse.emf.examples.generator.validator shows how to add templates
to generate additional things.
> shot here.
That's part of the web application itself. I'm not sure how to support
that...
> of metamodels and then automagically re-generate artifacts thus
> shortening time-2-market on any app customization
EMF's generator supports merging (at least for .java and .properties
files) so this is generally possible. The serialization support even
supports things like OPTION_RECORD_UNKNOWN_FEATURES to support forward
(limited) forward compatibility, i.e., the ability to read a newer
serialization with an older application and preserve the newer data.
The STP has BPMN support, buty I know nothing about it nor now it
relates to jBPM.
> 1. What are fundamental differences between CDO and Teneo? 2. Can I
> embed CDO within app server like JBoss/Liferay(Portal) to simply use
Good questions. I have some idea, but it's best for Eike to answer this
and expand on my answers above. His stuff is really cool. He'll be
giving a long talk about it at EclipseCon.
> Thanks again,
> -Mdu
Ed Merks
FUDForum. Page generated in 0.03241 seconds
