Home » Modeling » EMF » Using EMF plugins on HP-Itanium
Re: Using EMF plugins on HP-Itanium [message #415472 is a reply to message #415470] |
Fri, 14 December 2007 23:39 |
No real name Messages: 13 Registered: July 2009 |
Junior Member |
Hi Ed,
Thanks for responding.
The "org.eclipse.core.runtime*" and "org.eclipse.osgi*" plugins do not have
a platform dependency.
The problem is Eclipse does not provide separate Eclipse Platform zips that
contain platform dependent and platform independent code. So, now, to be
able to build my code on HP, I have to do the following...
1) Download a Windows or Solaris zip on HP.
2) Extract it.
3) Copy over "org.eclipse.core.runtime*" and "org.eclipse.osgi*" plugins
into my build structure so that the build can locate these plugins.
This seems to be a bad workaround. I was trying to find out if there is a
better approach.
-Arvind
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:fjv0k5$og3$1@build.eclipse.org...
> Arvind,
> Comments below.
> Arvind Parasuram wrote:
>> From what I have understood EMF is supposed to be platform independent
>> and can run standalone or within an Eclipse runtime if present.
> Yes.
>> The EMF plugins however declare "org.eclipse.runtime" as a required
>> bundle in MANIFEST.MF.
> When running within Eclipse this bundle is definitely required.
>> We have a custom home grown build setup that figures out plugin
>> dependencies by looking at the MANIFEST. This ends up breaking our builds
>> on HP-Itanium, because Eclipse does not deliver any runtime for
>> HP-Itanium.
> I didn't know about that.
>> One option of course is to build Eclipse on HP-Itanium to get past our
>> build issues. I would like to avoid doing this as this is additional
>> overhead for us.
>> Is there a version of EMF available that does not have a dependency on
>> "org.eclipse.runtime" in the MANIFEST?
> No.
>> If not, is there a way to specify "hard" Vs "soft" dependencies as part
>> of the build or in the MANIFEST?
> We do have optional dependencies, such as org.eclipse.core.resources, but
> when running in Eclipse/OSGi the eclipse ecore runtime is expected to be
> present. I'm not sure I really understand the problem. I didn't think
> the core runtime has platform dependencies either. Will you be running
> these plugins with the Equinox runtime? If not, can you just provide
> org.eclipse.core.runtime to keep the build happy knowing it won't be
> needed during standalone execution.?
>> Thanks in advance.
>> -Arvind
Re: Using EMF plugins on HP-Itanium [message #415473 is a reply to message #415472] |
Sat, 15 December 2007 00:07 |
Ed Merks Messages: 33141 Registered: July 2009 |
--------------020802020605060602010605
Arvind,
In the end, do you run them as plugins? If not, you can always
specialize your dependency computations to filter out ones you don't
have and you know you won't need.
> Hi Ed,
> 2) Extract it.
> better approach.
> -Arvind
>> Arvind,
>> Comments below.
>>> Hi,
>> Yes.
>>> HP-Itanium.
>>> overhead for us.
>> No.
>>> Thanks in advance.
>>> -Arvind
<html>
<head>
</head>
Arvind,<br>
<br>
have and you know you won't need.<br>
<br>
<br>
<blockquote cite="mid:fjv48n$mt3$1@build.eclipse.org" type="cite">
<pre wrap="">Hi Ed,
2) Extract it.
better approach.
-Arvind
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:fjv0k5$og3$1@build.eclipse.org">news:fjv0k5$og3$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Arvind,
Comments below.
</pre>
<pre wrap="">Hi,
</pre>
</blockquote>
<pre wrap="">Yes.
</pre>
<pre wrap="">The EMF plugins however declare "org.eclipse.runtime" as a required
</pre>
</blockquote>
<pre wrap="">When running within Eclipse this bundle is definitely required.
</pre>
<pre wrap="">We have a custom home grown build setup that figures out plugin
HP-Itanium.
</pre>
</blockquote>
<pre wrap="">I didn't know about that.
</pre>
<pre wrap="">One option of course is to build Eclipse on HP-Itanium to get past our
overhead for us.
</pre>
</blockquote>
<pre wrap="">No.
</pre>
<pre wrap="">If not, is there a way to specify "hard" Vs "soft" dependencies as part
</pre>
</blockquote>
<pre wrap="">We do have optional dependencies, such as org.eclipse.core.resources, but
</pre>
<pre wrap="">Thanks in advance.
-Arvind
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------020802020605060602010605--
Ed Merks
Re: Using EMF plugins on HP-Itanium [message #415474 is a reply to message #415473] |
Sat, 15 December 2007 07:10 |
Junior Member |
------=_NextPart_000_0058_01C83EA6.89E07120
charset="iso-8859-1"
Ed,
Both, we run them as plugins within an Eclipse application and just as =
java jars when running from command line utilities.
-Arvind
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:fjv5s4$v2g$1@build.eclipse.org...
Arvind,
In the end, do you run them as plugins? If not, you can always =
specialize your dependency computations to filter out ones you don't =
Arvind Parasuram wrote:=20
Hi Ed,
The "org.eclipse.core.runtime*" and "org.eclipse.osgi*" plugins do not =
have=20
The problem is Eclipse does not provide separate Eclipse Platform zips =
that=20
contain platform dependent and platform independent code. So, now, to be =
2) Extract it.
3) Copy over "org.eclipse.core.runtime*" and "org.eclipse.osgi*" plugins =
This seems to be a bad workaround. I was trying to find out if there is =
a=20
better approach.
-Arvind
"Ed Merks" <merks@ca.ibm.com> wrote in message=20
Arvind,
Comments below.
From what I have understood EMF is supposed to be platform independent=20
Yes.
The EMF plugins however declare "org.eclipse.runtime" as a required=20
We have a custom home grown build setup that figures out plugin=20
dependencies by looking at the MANIFEST. This ends up breaking our =
builds=20
on HP-Itanium, because Eclipse does not deliver any runtime for=20
HP-Itanium.
One option of course is to build Eclipse on HP-Itanium to get past =
our=20
build issues. I would like to avoid doing this as this is additional=20
overhead for us.
Is there a version of EMF available that does not have a dependency on=20
No.
If not, is there a way to specify "hard" Vs "soft" dependencies as =
part=20
We do have optional dependencies, such as =
org.eclipse.core.resources, but=20
when running in Eclipse/OSGi the eclipse ecore runtime is expected to be =
present. I'm not sure I really understand the problem. I didn't think=20
the core runtime has platform dependencies either. Will you be running=20
these plugins with the Equinox runtime? If not, can you just provide=20
org.eclipse.core.runtime to keep the build happy knowing it won't be=20
Thanks in advance.
-Arvind
=20
=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.6000.16544" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Ed,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Both, we run them as plugins within an =
Eclipse=20
application and just as java jars when running from command line=20
utilities.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>Thanks,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>-Arvind</FONT></DIV>
<BLOCKQUOTE=20
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
wrote in message <A=20
href=3D"news:fjv5s4$v2g$1@build.eclipse.org">news:fjv5s4$v2g$1@build.ecli=
pse.org</A>...</DIV>Arvind,<BR><BR>In=20
specialize=20
your dependency computations to filter out ones you don't have and you =
know=20
you won't need.<BR><BR><BR>Arvind Parasuram wrote:=20
<BLOCKQUOTE cite=3Dmid:fjv48n$mt3$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">Hi Ed,
have=20
that=20
2) Extract it.
a=20
better approach.
-Arvind
"Ed Merks" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:merks@ca.ibm.com"><merks@ca.ibm.com></A> wrote in =
message=20
<A class=3Dmoz-txt-link-freetext =
href=3D"news:fjv0k5$og3$1@build.eclipse.org">news:fjv0k5$og3$1@build.ecli=
pse.org</A>...
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Arvind,
Comments below.
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Hi,
</PRE></BLOCKQUOTE><PRE wrap=3D"">Yes.
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">The EMF plugins however =
</PRE></BLOCKQUOTE><PRE wrap=3D"">When running within Eclipse this =
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">We have a custom home =
builds=20
HP-Itanium.
</PRE></BLOCKQUOTE><PRE wrap=3D"">I didn't know about that.
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">One option of course is =
to build Eclipse on HP-Itanium to get past our=20
overhead for us.
</PRE></BLOCKQUOTE><PRE wrap=3D"">No.
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">If not, is there a way to =
specify "hard" Vs "soft" dependencies as part=20
</PRE></BLOCKQUOTE><PRE wrap=3D"">We do have optional =
dependencies, such as org.eclipse.core.resources, but=20
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Thanks in advance.
-Arvind
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D""><!---->
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_0058_01C83EA6.89E07120--
Re: Using EMF plugins on HP-Itanium [message #415476 is a reply to message #415474] |
Sat, 15 December 2007 16:39 |
--------------000701000507000002050809
Arvind,
If you run them as plugins within an Eclipse application then you must
be using the Eclipse core runtime, right? So it seems reasonable that
you should have the core runtime around when you build your plugins.
I'm slightly confused; maybe the issue is just the inability to get the
Equinox runtime as a separate download, although that is available:
<http://download.eclipse.org/eclipse/equinox/>
> Ed,
> -Arvind
> "Ed Merks" <merks@ca.ibm.com <mailto:merks@ca.ibm.com>> wrote in
> message news:fjv5s4$v2g$1@build.eclipse.org...
> Arvind,
> don't have and you know you won't need.
>> Hi Ed,
>> 2) Extract it.
>> better approach.
>> Regards,
>> -Arvind
>>> Arvind,
>>> Comments below.
>>>> Hi,
>>> Yes.
>>>> HP-Itanium.
>>>> overhead for us.
>>> No.
>>>> Thanks in advance.
>>>> -Arvind
<html>
<head>
</head>
Arvind,<br>
<br>
Equinox runtime as a separate download, although that is available:<a
href="http://download.eclipse.org/eclipse/equinox/"><br>
</a>
<blockquote><a href="http://download.eclipse.org/eclipse/equinox/">http://download.eclipse.org/eclipse/equinox/</a><br>
</blockquote>
<br>
<blockquote cite="mid:fjvulg$id0$1@build.eclipse.org" type="cite">
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<meta content="MSHTML 6.00.6000.16544" name="GENERATOR">
<style></style>
<div><font face="Arial" size="2">Ed,</font></div>
<div><font face="Arial" size="2">Both, we run them as plugins within
an Eclipse application and just as java jars when running from command
line utilities.</font></div>
<div> </div>
<div><font face="Arial" size="2">Thanks,</font></div>
<div><font face="Arial" size="2">-Arvind</font></div>
<blockquote
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;">
<div>"Ed Merks" <<a moz-do-not-send="true"
href="mailto:merks@ca.ibm.com">merks@ca.ibm.com</a>> wrote in
message <a moz-do-not-send="true"
href="news:fjv5s4$v2g$1@build.eclipse.org">news:fjv5s4$v2g$1@build.eclipse.org</a>...</div>
Arvind,<br>
<br>
<br>
<br>
<pre wrap="">Hi Ed,
2) Extract it.
better approach.
-Arvind
"Ed Merks" <a moz-do-not-send="true" class="moz-txt-link-rfc2396E"
<a moz-do-not-send="true" class="moz-txt-link-freetext"
</pre>
Comments below.
</pre>
<pre wrap="">Hi,
</pre>
</blockquote>
<pre wrap="">Yes.
</pre>
</pre>
</blockquote>
</pre>
HP-Itanium.
</pre>
</blockquote>
</pre>
overhead for us.
</pre>
</blockquote>
<pre wrap="">No.
</pre>
</pre>
</blockquote>
</pre>
-Arvind
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------000701000507000002050809--
Ed Merks
Re: Using EMF plugins on HP-Itanium [message #415496 is a reply to message #415476] |
Mon, 17 December 2007 22:14 |
Junior Member |
------=_NextPart_000_000A_01C840B7.2B4A6DB0
Ed,
Sorry to have confused you :-) It's a complicated issue. In short, yes, =
we would need the core runtime to build. But since Eclipse does not =
provide it on HP, either we have to build the runtime on HP or copy over =
the core runtime plugins from Solaris. Either option would work for us.
What I was referring to earlier was that the Eclipse platform zip =
includes both platform independent plugin jars and platform depedent =
plugin jars in one was zip. If it was split up into separate zips, we =
could have just downloaded the platform independent zip.
Thanks for your inputs.
-Arvind
news:fk1001$ihp$1@build.eclipse.org...
Arvind,
If you run them as plugins within an Eclipse application then you must =
be using the Eclipse core runtime, right? So it seems reasonable that =
you should have the core runtime around when you build your plugins. =
I'm slightly confused; maybe the issue is just the inability to get the =
Ed,
Both, we run them as plugins within an Eclipse application and just =
as java jars when running from command line utilities.
-Arvind
Arvind,
Hi Ed,
have=20
that=20
2) Extract it.
a=20
better approach.
-Arvind
Arvind,
Comments below.
Yes.
builds=20
HP-Itanium.
our=20
overhead for us.
No.
part=20
Thanks in advance.
-Arvind
=20
=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.6000.16587" name=3DGENERATOR></HEAD>
<DIV><FONT face=3DArial size=3D2>Sorry to have confused you :-) It's a =
complicated=20
issue. In short, yes, we would need the core runtime to build. But since =
Eclipse=20
does not provide it on HP, either we have to build the runtime on HP or =
copy=20
over the core runtime plugins from Solaris. Either option would work for =
us.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>What I was referring to =
earlier was that the=20
Eclipse platform zip includes both platform independent plugin jars and =
platform=20
depedent plugin jars in one was zip. If it was split up into separate =
zips, we=20
could have just downloaded the platform independent zip.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks for your inputs.</FONT></DIV>
<BLOCKQUOTE=20
href=3D"news:fk1001$ihp$1@build.eclipse.org">news:fk1001$ihp$1@build.ecli=
pse.org</A>...</DIV>Arvind,<BR><BR>If=20
you run them as plugins within an Eclipse application then you must be =
using=20
the Eclipse core runtime, right? So it seems reasonable that you =
should=20
have the core runtime around when you build your plugins. I'm =
slightly=20
confused; maybe the issue is just the inability to get the Equinox =
runtime as=20
a separate download, although that is available:<A=20
href=3D"http://download.eclipse.org/eclipse/equinox/"><BR></A>
<BLOCKQUOTE><A=20
href=3D"http://download.eclipse.org/eclipse/equinox/">http://download.ecl=
ipse.org/eclipse/equinox/</A><BR></BLOCKQUOTE><BR>Arvind=20
Parasuram wrote:=20
<BLOCKQUOTE cite=3Dmid:fjvulg$id0$1@build.eclipse.org type=3D"cite">
<STYLE></STYLE>
<DIV><FONT face=3DArial size=3D2>Both, we run them as plugins within =
an Eclipse=20
<DIV> </DIV>
<BLOCKQUOTE=20
BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" <<A href=3D"mailto:merks@ca.ibm.com"=20
moz-do-not-send=3D"true">merks@ca.ibm.com</A>> wrote in message =
<A=20
href=3D"news:fjv5s4$v2g$1@build.eclipse.org"=20
moz-do-not-send=3D"true">news:fjv5s4$v2g$1@build.eclipse.org</A>...</DIV>=
the end, do you run them as plugins? If not, you can always=20
specialize your dependency computations to filter out ones you =
don't have=20
and you know you won't need.<BR><BR><BR>Arvind Parasuram wrote:=20
have=20
that=20
2) Extract it.
a=20
better approach.
-Arvind
href=3D"mailto:merks@ca.ibm.com" =
moz-do-not-send=3D"true"><merks@ca.ibm.com></A> wrote in message=20
href=3D"news:fjv0k5$og3$1@build.eclipse.org" =
moz-do-not-send=3D"true">news:fjv0k5$og3$1@build.eclipse.org</A>...
</PRE>
Comments below.
</PRE>
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">The EMF plugins =
</PRE>
builds=20
HP-Itanium.
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">One option of course =
is to build Eclipse on HP-Itanium to get past our=20
overhead for us.
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">If not, is there a =
way to specify "hard" Vs "soft" dependencies as part=20
</PRE>
-Arvind
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BLOCKQUOTE><BR></BLOCKQUOTE ></BODY>=
</HTML>
------=_NextPart_000_000A_01C840B7.2B4A6DB0--
Re: Using EMF plugins on HP-Itanium [message #415498 is a reply to message #415496] |
Tue, 18 December 2007 13:36 |
--------------030706000704070901020706
Arvind,
Don't the equinox runtime download work or does it have the same type of
platform dependencies?
> Ed,
> yes, we would need the core runtime to build. But since Eclipse does
> copy over the core runtime plugins from Solaris. Either option would
> work for us.
> -Arvind
> message news:fk1001$ihp$1@build.eclipse.org...
> Arvind,
> must be using the Eclipse core runtime, right? So it seems
> reasonable that you should have the core runtime around when you
> build your plugins. I'm slightly confused; maybe the issue is
> just the inability to get the Equinox runtime as a separate
>> Ed,
>> just as java jars when running from command line utilities.
>> Thanks,
>> -Arvind
>> in message news:fjv5s4$v2g$1@build.eclipse.org...
>> Arvind,
>> always specialize your dependency computations to filter out
>> ones you don't have and you know you won't need.
>>> Hi Ed,
>>> 2) Extract it.
>>> better approach.
>>> Regards,
>>> -Arvind
>>>> Arvind,
>>>> Comments below.
>>>>> Hi,
>>>> Yes.
>>>>> HP-Itanium.
>>>>> overhead for us.
>>>> No.
>>>>> Thanks in advance.
>>>>> -Arvind
<html>
<head>
</head>
Arvind,<br>
<br>
of platform dependencies?<br>
<br>
<br>
<blockquote cite="mid:fk6sd7$3a9$1@build.eclipse.org" type="cite">
<meta content="MSHTML 6.00.6000.16587" name="GENERATOR">
<div><font face="Arial" size="2">Sorry to have confused you :-) It's
a complicated issue. In short, yes, we would need the core runtime to
build. But since Eclipse does not provide it on HP, either we have to
build the runtime on HP or copy over the core runtime plugins from
Solaris. Either option would work for us.</font></div>
<div> </div>
<div><font face="Arial" size="2">What I was referring to earlier was
that the Eclipse platform zip includes both platform independent plugin
jars and platform depedent plugin jars in one was zip. If it was split
up into separate zips, we could have just downloaded the platform
independent zip.</font></div>
<div> </div>
<div><font face="Arial" size="2">Thanks for your inputs.</font></div>
<div> </div>
<div> </div>
<blockquote
href="news:fk1001$ihp$1@build.eclipse.org">news:fk1001$ihp$1@build.eclipse.org</a>...</div>
Arvind,<br>
<br>
</a>
<blockquote><a moz-do-not-send="true"
</blockquote>
<br>
<style></style>
within an Eclipse application and just as java jars when running from
command line utilities.</font></div>
<div> </div>
<blockquote
<div>"Ed Merks" <<a href="mailto:merks@ca.ibm.com"
moz-do-not-send="true">merks@ca.ibm.com</a>> wrote in message <a
href="news:fjv5s4$v2g$1@build.eclipse.org" moz-do-not-send="true">news:fjv5s4$v2g$1@build.eclipse.org</a>...</div>
Arvind,<br>
<br>
<br>
<br>
type="cite">
<pre wrap="">Hi Ed,
2) Extract it.
better approach.
-Arvind
href="mailto:merks@ca.ibm.com" moz-do-not-send="true"><merks@ca.ibm.com></a> wrote in message
href="news:fjv0k5$og3$1@build.eclipse.org" moz-do-not-send="true">news:fjv0k5$og3$1@build.eclipse.org</a>...
</pre>
Comments below.
</pre>
<pre wrap="">Hi,
</pre>
</blockquote>
<pre wrap="">Yes.
</pre>
</pre>
</blockquote>
</pre>
HP-Itanium.
</pre>
</blockquote>
</pre>
overhead for us.
</pre>
</blockquote>
<pre wrap="">No.
</pre>
</pre>
</blockquote>
</pre>
-Arvind
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------030706000704070901020706--
Ed Merks
Re: Using EMF plugins on HP-Itanium [message #415715 is a reply to message #415498] |
Thu, 03 January 2008 00:09 |
Junior Member |
------=_NextPart_000_0018_01C84D59.DE46F740
Ed,
I didn't quite understand your question.
To explain further, our home grown build system looks at MANIFEST.MF =
files to make sure that all required plugins are present. Since our =
plugins depend on EMF and the EMF plugins declare "org.eclipse.runtime" =
as a required bundle in MANIFEST.MF, our build tries to look for this =
plugin on HPx and fails since Eclipse does not deliver the Eclipse 3.3 =
runtime on HPx. This is what is causing the problem. We finally got =
around it by just copying over the necessary plugins from Solaris.
-Arvind
news:fk8idc$c7e$1@build.eclipse.org...
Arvind,
Don't the equinox runtime download work or does it have the same type =
Ed,
Sorry to have confused you :-) It's a complicated issue. In short, =
yes, we would need the core runtime to build. But since Eclipse does not =
-Arvind
Arvind,
If you run them as plugins within an Eclipse application then you =
must be using the Eclipse core runtime, right? So it seems reasonable =
that you should have the core runtime around when you build your =
plugins. I'm slightly confused; maybe the issue is just the inability =
to get the Equinox runtime as a separate download, although that is =
available:
Ed,
Both, we run them as plugins within an Eclipse application and =
-Arvind
Arvind,
In the end, do you run them as plugins? If not, you can =
always specialize your dependency computations to filter out ones you =
Hi Ed,
have=20
that=20
2) Extract it.
a=20
better approach.
-Arvind
Arvind,
Comments below.
Yes.
builds=20
HP-Itanium.
our=20
overhead for us.
No.
part=20
Thanks in advance.
-Arvind
=20
=20
<HTML><HEAD>
<DIV><FONT face=3DArial size=3D2>I didn't quite understand your=20
question.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>To explain further, our home grown =
build system=20
looks at MANIFEST.MF files to make sure that all required plugins are =
present.=20
Since our plugins depend on EMF and the EMF plugins declare=20
"org.eclipse.runtime" as a required bundle in MANIFEST.MF, our build =
tries to=20
look for this plugin on HPx and fails since Eclipse does not deliver the =
Eclipse=20
3.3 runtime on HPx. This is what is causing the problem. We finally got =
around=20
it by just copying over the necessary plugins from Solaris.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Regards,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>-Arvind</DIV>
<DIV><BR></DIV></FONT>
<BLOCKQUOTE=20
href=3D"news:fk8idc$c7e$1@build.eclipse.org">news:fk8idc$c7e$1@build.ecli=
pse.org</A>...</DIV>Arvind,<BR><BR>Don't=20
the equinox runtime download work or does it have the same type of =
platform=20
dependencies?<BR><BR><BR>Arvind Parasuram wrote:=20
<BLOCKQUOTE cite=3Dmid:fk6sd7$3a9$1@build.eclipse.org type=3D"cite">
<DIV><FONT face=3DArial size=3D2>Sorry to have confused you :-) It's =
a=20
complicated issue. In short, yes, we would need the core runtime to =
build.=20
But since Eclipse does not provide it on HP, either we have to build =
the=20
runtime on HP or copy over the core runtime plugins from Solaris. =
Either=20
option would work for us.</FONT></DIV>
<DIV> </DIV>
earlier was that=20
the Eclipse platform zip includes both platform independent plugin =
jars and=20
platform depedent plugin jars in one was zip. If it was split up =
into=20
separate zips, we could have just downloaded the platform =
independent=20
zip.</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>Thanks for your =
<BLOCKQUOTE=20
<A=20
href=3D"news:fk1001$ihp$1@build.eclipse.org"=20
moz-do-not-send=3D"true">news:fk1001$ihp$1@build.eclipse.org</A>...</DIV>=
must be=20
using the Eclipse core runtime, right? So it seems =
reasonable that=20
plugins. =20
I'm slightly confused; maybe the issue is just the inability to =
get the=20
available:<A=20
href=3D"http://download.eclipse.org/eclipse/equinox/"=20
moz-do-not-send=3D"true"><BR></A>
<BLOCKQUOTE><A =
moz-do-not-send=3D"true">http://download.eclipse.org/eclipse/equinox/</A>=
Parasuram wrote:=20
<BLOCKQUOTE cite=3Dmid:fjvulg$id0$1@build.eclipse.org =
type=3D"cite">
<STYLE></STYLE>
<DIV><FONT face=3DArial size=3D2>Both, we run them as plugins =
within an=20
Eclipse application and just as java jars when running from =
command line=20
<DIV> </DIV>
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: =
5px; BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px">
moz-do-not-send=3D"true">merks@ca.ibm.com</A>> wrote in =
message <A=20
always=20
don't=20
have and you know you won't need.<BR><BR><BR>Arvind Parasuram =
wrote:=20
have=20
that=20
2) Extract it.
a=20
better approach.
-Arvind
</PRE>
Comments below.
</PRE>
</PRE>
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">We have a custom =
builds=20
HP-Itanium.
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">One option of =
course is to build Eclipse on HP-Itanium to get past our=20
overhead for us.
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">If not, is there =
a way to specify "hard" Vs "soft" dependencies as part=20
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Thanks in =
advance.
-Arvind
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BLOCKQUOTE><BR></BLOCKQUOTE ></BLOCK=
------=_NextPart_000_0018_01C84D59.DE46F740--
Current Time: Thu Apr 25 16:43:41 GMT 2024
Powered by FUDForum. Page generated in 0.03671 seconds
