still struggling with namespace packages. [message #415110] |
Fri, 30 November 2007 00:49 |
Jason Henriksen Messages: 231 Registered: July 2009 |
Hi again,
I'm trying to generate java from XSD that appears in many name spaces.
I have all these namespaces because I need the generated java classes
to be separated into a reasonable package structure.
The current java-only data model contains about 3000 different model
objects, so I'm imagining that I'll have hundreds of namespaces in play
once the whole thing is converted to EMF.
The crux of this is the need a utility that converts arbitrary SOAP XML
in to EObjects. Here's my current code to do that:
(I may have objects in the database, hence the Teneo factory)
static URI xmlURI = URI.createURI("*.xml");
public Object getObjectFromSoap(SOAPElement element)
ResourceSet resourceSet = new ResourceSetImpl();
// By default pull things from the database
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap()
.put(Resource.Factory.Registry.DEFAULT_EXTENSION, hrf);
// CONCERN 1: With one global namespace I have one
// global factory. If my whole enterprise starts using EMF
// I'll end up with literally hundreds of java packages and
// thus hundreds of namespaces and factories.
// It seems that since this utility doesn't know what's in
// the SOAP xml payload I need to register all of those packages.
// Is that correct? Is it possible to set up the package registry
// only once and re-use it between resource sets?
resourceSet.getPackageRegistry()
.put(packageImpl.getNsURI(),packageImpl);
// CONCERN 2: With one global namespace I know which resource factory
// to use. Do I need to somehow use the tag name as a key into
// determining which resource factory contains the object for
// the given tag and from that figure out which factory to use?
// If I have say 100 resourceFactories, do I need to create 100
// extensions and map them some how? Or does EMF have some kind of
// Class.forName("foo.bar.Class") that I just haven't found yet?
.put("xml", resourceFactory);
XMLResourceImpl resource =
(XMLResourceImpl)resourceSet.createResource(xmlURI);
String foo = element.toString();
// CONCERN 3: Since I don't know what object is in the SOAP payload,
// I'm not sure what namespace to specify. Is there a way to make it
// search the registered namespaces to find a tag that matches?
// Or is there a more elegant solution to this I haven't found yet?
// This is ugly, but I don't know how else to tell EMF what package
// to look in to find the tags/features. I've only found the outer
// tag to have it's namespace messed with so I don't think the inner
// tags need this
// (Maybe I just need to somehow prevent the namespace scrambling)
if (foo.indexOf("xmlns='http://vsp.com/'") == -1) {
foo = foo.substring(0, foo.indexOf(' '))
+ " xmlns='http://vsp.com/' xmlns:" + defaultPackage
+ "='http://vsp.com/' " + foo.substring(foo.indexOf(' '));
try {
resource.load(new ByteArrayInputStream(foo.getBytes()), null);
} catch (java.io.IOException ioe) {
ioe.printStackTrace();
return null;
return resource.getContents().get(0);
As always: thanks for our advice,
Jason Henriksen
Re: still struggling with namespace packages. [message #415112 is a reply to message #415110] |
Fri, 30 November 2007 01:07 |
Ed Merks Messages: 33140 Registered: July 2009 |
Jason,
Comments below.
jason henriksen wrote:
> Hi again,
> classes to be separated into a reasonable package structure.
> play once the whole thing is converted to EMF.
Wow. That kind of hurts the brain...
> XML in to EObjects. Here's my current code to do that:
Hmmm. But EMF generates one package per namespace. So I'd expect on
mondo package rather than hundreds of them.
ResourceSet has a setPackageRegistry method so you could share them
between resource set.
I don't really like seeing PackageImpls do much. Can't use use the
interface only?
The parser does that for you. It used
EPackage.Registry.INSTANCE.getEPackage(<namespace>) to find the package
for any particular qualified name.
Hmm. Resource factories. Why so many? You only have one resource
you're reading right?
You can use "*" to register against a wildcard. You can also turn
resource factory generation off for a package. If you look at what's
generated, they all look pretty much the same, i.e., use the same options.
In EMF 2.4 there is support for content handlers that can determine the
resource type to use based on the content itself. I suspect though that
a one-side-fits-all resource will be sufficient for you.
It will automatically find a package as I described above. The package
namespace is register in the package registry so the tag will be matched
to the right package base on that.
> // tags need this
Scrambling is good for eggs, but not much else.
> try {
If you have a string already, best not to convert it to byte. Look at
URIConverter.ReadableInputStream as a way to wrap the string. This
approach might use a system encoding to encode something that will thing
it should be using a UTF-8 encoding.
> return null;
Hopefully I've helped a tiny bit. It's pretty late...
> Jason Henriksen
Ed Merks
FUDForum. Page generated in 0.02619 seconds
