Multiple EditingDomain Resources [message #415000] |
Tue, 27 November 2007 23:15 |
Originally posted by: derrydavis.hotmail.com
I have a single form page that I am using to display data from multiple
models. The form page is being instantiated by a single EMF editor,
editor A and displays 'initial' data. The other data is being read in
via a resource loading it through the file system. The 'other' data is
associated with editor B. However I need to update both data sets. My
approach is to use a commandstack and execute commands on the
editingdomain through it. I can load the 'other' data into the editing
domain, but can't seem to get the command to run against the desired
data. The command run but doesn't do anything to the 'other' data in the
editingdomain. I have successfully run commandstack commands against the
initial data in the editingdomain. Any suggestions? Thanks in advance.
Re: Multiple EditingDomain Resources [message #415003 is a reply to message #415001] |
Wed, 28 November 2007 02:43 |
Steve Blass wrote:
> Do you Add... model B to the "Referenced generator models" pane in the
> "New EMF Project" wizard "Package Selection" page when you create the
> project for model A so that when you generate Editor A it knows about
> model B? (and/or vice versa)?
> Steve
>> multiple models. The form page is being instantiated by a single EMF
>> editor, editor A and displays 'initial' data. The other data is being
>> read in via a resource loading it through the file system. The 'other'
>> data is associated with editor B. However I need to update both data
>> sets. My approach is to use a commandstack and execute commands on the
>> the editingdomain. I have successfully run commandstack commands
>> against the initial data in the editingdomain. Any suggestions?
>> Thanks in advance.
Didn't know about that, that may do the trick. Thanks Steve!
FUDForum. Page generated in 0.01892 seconds
