loading XML: XMLTypeDocumentRootImpl instead of generated DocumentRootImpl? [message #414976] |
Tue, 27 November 2007 13:21 |
Originally posted by: joerg.von.frantzius.artnology.com
<html>
<head>
</head>
Hi,<br>
<br>
after we switched from org.eclipse.emf_2.2.0.v200703291501.jar to
org.eclipse.emf_2.3.0.v200709252135.jar (together with the other
required jars in their respective new versions) and regenerating model
code, our code for loading XML is broken, without our hand-written code
having changed. We're making use of a generated XMLProcessor by doing
the following:<br>
<tt><br>
AplusplusResourceImpl aplusplusResourceImpl =
(AplusplusResourceImpl) appXmlProc.load(aplusplusXmlStream,
LOAD_OPTIONS);<br>
DocumentRoot documentRoot = (DocumentRoot)
aplusplusResourceImpl.getContents().get(0);</tt><br>
<br>
The last cast will now fail, because the document root object in the
resource's contents is no longer an instance of our generated
DocumentRootImpl, but a
org.eclipse.emf.ecore.xml.type.impl.XMLTypeDocumentRootImpl. <br>
<br>
Has anything changed here so we have to supply some magic load option
or something like that?<br>
<br>
Thanks for any hints,<br>
Jörg<br>
</body>
</html>
Re: loading XML: XMLTypeDocumentRootImpl instead of generated DocumentRootImpl? [message #414978 is a reply to message #414976] |
Tue, 27 November 2007 13:44 |
Ed Merks Messages: 33141 Registered: July 2009 |
Jörg,
It sounds like you've ended up with a demand created document root which
implies that your model is not being found for some reason while the
root element is being processed. Perhaps setting a breakpoint in
XMLHandler.handleMissingPackage will give you a good idea why it's going
down this path...
I suppose it's possible that some change in the xmi impl classes caused
your override to be bypassed. We're very careful to try to avoid that,
but it's possible we overlooked something...
Jörg von Frantzius wrote:
> code having changed. We're making use of a generated XMLProcessor by
> doing the following:
> (AplusplusResourceImpl) appXmlProc.load(aplusplusXmlStream, LOAD_OPTIONS);
> Jörg
Ed Merks
Re: loading XML: XMLTypeDocumentRootImpl instead of generated DocumentRootImpl? [message #414982 is a reply to message #414978] |
Tue, 27 November 2007 14:03 |
Sorry for possibly creating any worries, but the XML had been totally
messed up, so EMF had no chance doing the right thing here. Shame on me!
Ed Merks schrieb:
> Jörg,
> which implies that your model is not being found for some reason while
> the root element is being processed. Perhaps setting a breakpoint in
> going down this path...
> caused your override to be bypassed. We're very careful to try to
> avoid that, but it's possible we overlooked something...
>> model code, our code for loading XML is broken, without our
>> hand-written code having changed. We're making use of a generated
>> XMLProcessor by doing the following:
>> LOAD_OPTIONS);
>> Jörg
FUDForum. Page generated in 0.02521 seconds
