Model Instances of a UML2 metamodel extension does not work for me [XMI coding problems] [message #414290] |
Mon, 29 October 2007 18:38 |
Originally posted by: reda.bendraou.gmail.com
Hello every one!!
I have a metamodel which is the result of UML2 metamodel extension by emof
classes (ecore encolsed to this email). I can generate the genmodel and even
the edit and editor stuff. I a seperate workbench, I can create model
instances of this metamodel (thanks to the wizard). However, once I close
and save the file (containing the model instance) it is impossible for me to
open it again. there is many errors due inresolved xmi references. Is anyone
has an idea about this bug and how can I manage it? Do I have to choose
explicitly a kind of xmi coding? Thanks in advance for your help!! Herein, a
sample of these errors (see jpeg joined file for the complete list) :
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedException:
org.eclipse.emf.ecore.xmi.UnresolvedReferenceException: Unresolved reference
'//@processElements.0/From_Start_to_CallBehavior'.
(platform:/resource/uml4spminstances/simpleProcessExample.um l4spm, 4, 112)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:316)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:275)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:398)
at uml4spm.presentation.Uml4spmEditor.createModel(Uml4spmEditor .java:954)
Thanks!!
r.
Re: Model Instances of a UML2 metamodel extension does not work for me [XMI coding problems] [message #414293 is a reply to message #414290] |
Mon, 29 October 2007 18:57 |
Ed Merks Messages: 33136 Registered: July 2009 |
--------------090803080601080103000002
Reda,
Given that you are doing a heavy weight extension of UML2 you likely
will need to look carefully at their documentation for doing that.
Perhaps it's as simple as registering the same resource as is registered
for *.uml resource to be used for your model. Just looking a the
fragment path
It seems likely that EModelElementImpl's specialized implementation of
eURIFragmentSegment is kicking in when perhaps that's not what you want.
I suspect that heavy weight extensions of UML should generally be
avoided and that you should be trying to get by with profiles...
Reda Bendraou wrote:
> Hello every one!!
> at
> at
> at
> Thanks!!
> r.
<html>
<head>
<title></title>
</head>
Reda,<br>
<br>
registered for *.uml resource to be used for your model. Just looking
a the fragment path<br>
<blockquote>
<pre wrap="">//@processElements.0/From_Start_to_CallBehavior</pre >
</blockquote>
eURIFragmentSegment is kicking in when perhaps that's not what you want.<br>
<br>
avoided and that you should be trying to get by with profiles...<br>
<br>
<br>
<blockquote cite="mid:fg59cm$n8c$1@build.eclipse.org" type="cite">
<pre wrap="">Hello every one!!
Thanks!!
r.
</pre>
</blockquote>
<br>
</body>
</html>
--------------090803080601080103000002--
Ed Merks
FUDForum. Page generated in 0.01506 seconds
