Home » Modeling » EMF » Validating additions to a list
Validating additions to a list [message #414106] |
Thu, 25 October 2007 03:59 |
Originally posted by: andrew_steady.hotmail.com
As there is no specific setter for adding a single value to a list, (we do
getX().add(y)) how can we prevent certain additions to the list - for
example we wish to prevent a relationship being added if it would result
in a cyclic dependancy.
We could do this with a post validation, or by restricting the options in
the first place - but I in this case we need to prevent on set.
What's the usual solution to this?
Andy
Re: Validating additions to a list [message #414113 is a reply to message #414108] |
Thu, 25 October 2007 10:18 |
Ed Merks Messages: 33141 Registered: July 2009 |
--------------070103010003000902060305
Miles,
Certainly if the things are being done by commands, that's a good
approach, but sometimes folks need to protect the model APIs themselves
from client programmers. For this type of scenario, one can specialize
the list implementation itself, i.e., specialize this method from the
base implementation which will handle set, add, and addAll:
* Validates a new content object and returns the validated object.
* This implementation checks for null, if {@link #canContainNull
necessary} and returns the argument object.
* Clients may throw additional types of runtime exceptions
* in order to handle constraint violations.
* @param index the position of the new content.
* @param object the new content.
* @return the validated content.
* @exception IllegalArgumentException if a constraint prevents
the object from being added.
protected E validate(int index, E object)
if (!canContainNull() && object == null)
throw new IllegalArgumentException("The 'no null' constraint
is violated");
return object;
Miles Parker wrote:
> On 2007-10-24 20:59:57 -0700, andrew_steady@hotmail.com (Andy Steady)
> said:
>> (we do getX().add(y)) how can we prevent certain additions to the
>> list - for example we wish to prevent a relationship being added if
>> it would result in a cyclic dependancy.
>> options in the first place - but I in this case we need to prevent on
>> set.
>> Andy
> Andy, this is really a job for EMF.edit I think, e.g. it is not a
> validation issue per se but a model editing issue. In addition to
> post-validation you can override the Objects item provider
> createAddCommand to return UnexecutableCommand in the case where the
> added command item would involve a cyclic dependency. hth..
<html>
<head>
</head>
Miles,<br>
<br>
base implementation which will handle set, add, and addAll:<small><br>
</small>
<blockquote><small> /**</small><br>
<small> * Validates a new content object and returns the validated
object.</small><br>
<small> * This implementation checks for null, if {@link
#canContainNull necessary} and returns the argument object.</small><br>
<small> * Clients may throw additional types of runtime exceptions </small><br>
<small> * in order to handle constraint violations.</small><br>
<small> * @param index the position of the new content.</small><br>
<small> * @param object the new content.</small><br>
<small> * @return the validated content.</small><br>
<small> * @exception IllegalArgumentException if a constraint
prevents the object from being added.</small><br>
<small> */</small><br>
<small> protected E validate(int index, E object)</small><br>
<small> {</small><br>
<small> if (!canContainNull() && object == null)</small><br>
<small> throw new IllegalArgumentException("The 'no null'
constraint is violated");</small><br>
<small> }</small><br>
<br>
<small> return object;</small><br>
</blockquote>
<br>
Miles Parker wrote:
<blockquote cite="mid:ffp7tp$k0g$1@build.eclipse.org" type="cite">On
2007-10-24 20:59:57 -0700, <a class="moz-txt-link-abbreviated" href="mailto:andrew_steady@hotmail.com">andrew_steady@hotmail.com</a> (Andy Steady)
said:
<br>
<br>
<blockquote type="cite">Hi,
<br>
<br>
do getX().add(y)) how can we prevent certain additions to the list -
for example we wish to prevent a relationship being added if it would
<br>
<br>
in the first place - but I in this case we need to prevent on set.
<br>
<br>
<br>
Andy
<br>
</blockquote>
<br>
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------070103010003000902060305--
Ed Merks
Re: Validating additions to a list [message #414135 is a reply to message #414113] |
Thu, 25 October 2007 17:22 |
Miles Parker Messages: 1341 Registered: July 2009 |
Right, but wouldn't Andrew's case need both in order to prevent the add
(or accomplish some alternative) rather then simply reporting it?
On 2007-10-25 03:18:29 -0700, Ed Merks <merks@ca.ibm.com> said:
> Miles,
> is violated");
> return object;
> Miles Parker wrote:
>> On 2007-10-24 20:59:57 -0700, andrew_steady@hotmail.com (Andy Steady) said:
>>> Hi,
>>> Andy
> <html>
> <head>
> </head>
> Miles,<br>
> <br>
> </small>
> validated
> object.</small><br>
> null)</small><br>
> <small> throw new
> <br>
> </blockquote>
> <br>
> (Andy Steady)
> said:
> <br>
> <br>
> <br>
> <br>
> <br>
> <br>
> <br>
> <br>
> <br>
> Andy
> <br>
> </blockquote>
> <br>
> <br>
> <br>
> </blockquote>
> <br>
> </body>
> </html>
Re: Validating additions to a list [message #414137 is a reply to message #414113] |
Thu, 25 October 2007 17:28 |
Thanks guys - some interesting options.
We don't need to support programmatic client access to the model so
probably a specialized command and validation in the model will suffice.
Also nice to know how, if its required, we can protect the model.
Andy
Re: Validating additions to a list [message #414139 is a reply to message #414135] |
Thu, 25 October 2007 18:11 |
Miles,
Yes, that's an excellent point. ;-)
> add (or accomplish some alternative) rather then simply reporting it?
>> Miles,
>> themselves from client programmers. For this type of scenario, one
>> can specialize the list implementation itself, i.e., specialize this
>> method from the base implementation which will handle set, add, and
>> addAll:
>> object.
>> is violated");
>> return object;
>>> Steady) said:
>>>> Hi,
>>>> on set.
>>>> Andy
>> <html>
>> <head>
>> </head>
>> Miles,<br>
>> <br>
>> specialize
>> </small>
>> the validated
>> object.</small><br>
>> constraint
>> <small> throw new
>> <br>
>> </blockquote>
>> <br>
>> (Andy Steady)
>> said:
>> <br>
>> <br>
>> <br>
>> <br>
>> <br>
>> <br>
>> <br>
>> <br>
>> <br>
>> Andy
>> <br>
>> </blockquote>
>> <br>
>> <br>
>> <br>
>> </blockquote>
>> <br>
>> </body>
>> </html>
Ed Merks
Current Time: Thu Apr 25 21:12:49 GMT 2024
Powered by FUDForum. Page generated in 0.03168 seconds
