Home » Modeling » EMF » model creation wizard: how to restrict possible root elements
Re: model creation wizard: how to restrict possible root elements [message #413818 is a reply to message #413814] |
Mon, 15 October 2007 16:07 |
Ed Merks Messages: 33140 Registered: July 2009 |
--------------030607020709020303010807
Philipp,
The only way right now is to specialize this method in the XyzModelWizard:
protected Collection<String> getInitialObjectNames()
Philipp W. Kutter wrote:
> Hi.
> If I generate Ecore from XSD, and if the XSD has only a number of root
> elements, being of complex types, the generated Editor wizard correctly
> restricts the possible root or "Model Elements" to those being root
> elements in the original XSD.
> How can I most elegantly do, if I use Ecore directly?
> Formulated for the Library example: how can I restrict the choices of
> the "model Elements" in the generated model creation wizard to "Library"?
> Do I really have to go through the XSD stuff??
> I'd prefer this to changing the code manually..
> Best, Philipp
> PS: I know I could do the above experiment on my own, and I will
> possibly. But I think the question is of general interest. Please
> correct me if I am wrong.
<html>
<head>
</head>
Philipp,<br>
<br>
XyzModelWizard:<br>
<blockquote> protected Collection<String> getInitialObjectNames()<br>
</blockquote>
<br>
<blockquote cite="mid:ff002f$8cr$1@build.eclipse.org" type="cite">Hi.
<br>
<br>
<br>
<br>
<br>
<br>
"Library"?
<br>
<br>
<br>
<br>
<br>
<br>
Best, Philipp
<br>
<br>
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------030607020709020303010807--
Ed Merks
Re: model creation wizard: how to restrict possible root elements [message #413821 is a reply to message #413818] |
Mon, 15 October 2007 16:25 |
Philipp Kutter Messages: 306 Registered: July 2009 |
Thanks, perfect. That code is easy to change by hand.
In the corresponding template, I see
genPackage.hasDocumentRoot()
and then,
for EStructuralFeature eStructuralFeature :
ExtendedMetaData.INSTANCE.getAllElements(
ExtendedMetaData.INSTANCE.getDocumentRoot(
<%=genPackage.getUncapPackageInterfaceName()%>)))
initialObjectNames.add(eStructuralFeature.getName());
Would setting a document root not be what I want to do, rather than
changing
as you propose, or am I completly wrong? What is a document root, and
where is it set in ECore?
Best, Philipp
Ed Merks wrote:
> Philipp,
>> Hi.
>> Best, Philipp
Re: model creation wizard: how to restrict possible root elements [message #413822 is a reply to message #413821] |
Mon, 15 October 2007 16:34 |
Philipp,
A document root is quite a complex thing to specify by hand. If you
generate from a schema with global elements or attributes, then you will
have one, but to build it by hand is a lot of work and it will kind of
mess up your clean model to create one so I would not recommend doing
that as a way to solve this problem.
> and then,
> changing
> Best, Philipp
> Ed Merks wrote:
>> Philipp,
>> XyzModelWizard:
>>> Hi.
>>> root elements, being of complex types, the generated Editor wizard
>>> correctly
>>> of the "model Elements" in the generated model creation wizard to
>>> "Library"?
>>> Best, Philipp
Ed Merks
Re: model creation wizard: how to restrict possible root elements [message #414383 is a reply to message #413822] |
Sun, 04 November 2007 17:43 |
Do you think it makes sense, if I enter a feature request, to define
Document Roots easily for any ECore model?
Best, Philipp
Ed Merks wrote:
> Philipp,
>> and then,
>> changing
>> Best, Philipp
>> Ed Merks wrote:
>>> Philipp,
>>> XyzModelWizard:
>>>> Hi.
>>>> correctly
>>>> "Library"?
>>>> Best, Philipp
Re: model creation wizard: how to restrict possible root elements [message #414384 is a reply to message #414383] |
Sun, 04 November 2007 17:48 |
--------------000503020308010906050400
Philipp,
I think it falls under this bugzilla:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=143478
> Best, Philipp
> Ed Merks wrote:
>> Philipp,
>> will have one, but to build it by hand is a lot of work and it will
>> kind of mess up your clean model to create one so I would not
>> recommend doing that as a way to solve this problem.
>>> and then,
>>> changing
>>> Best, Philipp
>>> Ed Merks wrote:
>>>> Philipp,
>>>> XyzModelWizard:
>>>>> Hi.
>>>>> correctly
>>>>> root elements in the original XSD.
>>>>> "Library"?
>>>>> Best, Philipp
<html>
<head>
<title></title>
</head>
Philipp,<br>
<br>
I think it falls under this bugzilla:<br>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=143478">https://bugs.eclipse.org/bugs/show_bug.cgi?id=143478</a><br>
</blockquote>
<br>
<blockquote cite="mid:fgl0ab$afh$1@build.eclipse.org" type="cite">Do
<br>
<br>
Best, Philipp
<br>
<br>
Ed Merks wrote:
<br>
<blockquote type="cite">Philipp,
<br>
<br>
kind of mess up your clean model to create one so I would not recommend
<br>
<br>
<br>
<br>
<blockquote type="cite">Thanks, perfect. That code is easy to
change by hand.
<br>
<br>
<br>
<br>
<br>
<br>
and then,
<br>
<br>
<br>
<br>
<br>
<%=genPackage.getUncapPackageInterfaceName()%> )))
<br>
<br>
<br>
<br>
<br>
<br>
changing
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Best, Philipp
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
XyzModelWizard:
<br>
<br>
<br>
<br>
<br>
<br>
<blockquote type="cite">Hi.
<br>
<br>
<br>
<br>
<br>
<br>
"Library"?
<br>
<br>
<br>
<br>
<br>
<br>
Best, Philipp
<br>
<br>
<br>
<br>
</blockquote>
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------000503020308010906050400--
Ed Merks
Current Time: Thu Apr 25 05:08:29 GMT 2024
Powered by FUDForum. Page generated in 0.03558 seconds
