Home » Modeling » EMF » Multiple models
Re: Multiple models [message #415807 is a reply to message #411212] |
Tue, 08 January 2008 09:28 |
Rene Ladan Messages: 51 Registered: July 2009 |
Member |
Ed Merks wrote:
> Waqas,
> The import wizards allow you to specify multiple schemas at once and
> will yield a single .genmodel that will reference multiple .ecores that
> will all be generated into a single plugin. So yes, you can do this.
I assume the additional model references the other models (e.g. via containment).
I have multiple independent models A,B, etc. Would it be possible to generate one
common editor for them (instead of separate editors)? Currently I'm trying this
with a dummy additional/master model M which only exists in the genmodel (not as an
ecore model) :
M.genmodel
\-- A.ecore
\-- B.ecore
The generated code looks ok, except that :
* it assumes the existence of a editor, metapackage, and ItemProviderAdapterFactory for M,
which aren't generated.
* the XyzEditor.java files in editor/Xyz.presentation all reference each other in their
initializeEditingDomain() methods. This probably isn't a big deal, but I somehow would
have expected that these references belong to some file generated for M (since it is the
'master').
Do I need another setup for the genmodel file or change the plugin.xml files for the generated
code?
Rene
> Waqas Ilyas wrote:
>> I need to manage multiple XML files in my application. For each XML
>> Schema i have a model, but there is an additional model that will
>> extend all teh existing models, and act as a glue between them.
>> I like to put all the models in one plugin, the models created
>> directly from XML and the one that extends and binds all of them. I
>> want one plugin that has all the generated code for different models
>> (which would be in different packages). Can I extend a model if the
>> Ecore files for both the base and child are in the same folder?
Re: Multiple models [message #415813 is a reply to message #415807] |
Tue, 08 January 2008 12:58 |
Ed Merks Messages: 33141 Registered: July 2009 |
--------------050900060306090901060601
Rene,
Actually, any one of the editors could potentially do the trick (because
there's almost no difference between editors if you look closely).
There are a few problems though. :-(
Firstly, if is is present
adapterFactory.addAdapterFactory(new
ReflectiveItemProviderAdapterFactory());
then the registered item providers for other packages won't be found.
I'll be looking at addressing that this bugzilla very soon:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=206857
That one is easy enough to address with a line of code change. The
harder problem is child creation
https://bugs.eclipse.org/bugs/show_bug.cgi?id=109472
The problem here is that the item providers generate support for child
creation based on all the models know at the time of generation.
Maybe your approach is quite a reasonable one and you could simply
change all the properties like model directory and such so that all the
code for the model, edit, and editor are generated into a single project
thereby avoiding plugin dependencies you don't really want. Does that
work? I assume you'll still have child creation issues though... I'm
trying find time for the latter bug too, it is a plan item, but my hack
for it so far was too ugly to post as a patch...
Rene Ladan wrote:
> Ed Merks wrote:
>> Waqas,
> ecore model) :
> M.genmodel
> \-- A.ecore
> \-- B.ecore
> 'master').
> code?
> Rene
>> Waqas Ilyas wrote:
>>> Hi,
<html>
<head>
<title></title>
</head>
Rene,<br>
<br>
(because there's almost no difference between editors if you look
closely). There are a few problems though. :-(<br>
<br>
Firstly, if is is present<br>
<br>
ReflectiveItemProviderAdapterFactory());<br>
<br>
I'll be looking at addressing that this bugzilla very soon:<br>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=206857">https://bugs.eclipse.org/bugs/show_bug.cgi?id=206857</a><br>
</blockquote>
harder problem is child creation<br>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=109472">https://bugs.eclipse.org/bugs/show_bug.cgi?id=109472</a><br>
</blockquote>
creation based on all the models know at the time of generation.<br>
<br>
project thereby avoiding plugin dependencies you don't really want.
Does that work? I assume you'll still have child creation issues
though... I'm trying find time for the latter bug too, it is a plan
item, but my hack for it so far was too ugly to post as a patch...<br>
<br>
<br>
Rene Ladan wrote:
<blockquote cite="mid:flvfoa$bf9$1@build.eclipse.org" type="cite">
<pre wrap="">Ed Merks wrote:
</pre>
<blockquote type="cite">
<pre wrap="">Waqas,
</pre>
</blockquote>
<pre wrap=""><!---->I assume the additional model references the other models (e.g. via containment).
ecore model) :
M.genmodel
\-- A.ecore
\-- B.ecore
'master').
code?
Rene
</pre>
<pre wrap="">Waqas Ilyas wrote:
</pre>
<pre wrap="">Hi,
</pre>
</blockquote>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------050900060306090901060601--
Ed Merks
Re: Multiple models [message #415837 is a reply to message #415813] |
Wed, 09 January 2008 12:23 |
Member |
Ed Merks wrote:
> Rene,
These lines are indeed present in Xyz.presentation.XyzEditor.intializeEditingDomain().
I commented them out, but it doesn't seem to make much difference.
I don't think this affects me, since all models are known at generation time.
I've added a wrapper model called "meta", which contains a single abstract class
containing transient 0..* references to the main element of the other models.
After regenerating the code (I even deleted all java and class files to be sure),
the editor runs but I cannot create a new "meta" model. Upon trying the wizard just
responds with a "Problem opening wizard" window telling "Could not instantiate class
'meta.presentation.MetaModelWizard' and the Finish button is then disabled.
Note that I manually copied and modified the MetaModelWizard and MetaActionBarContributor
class from one of the referenced models, as only the MetaEditorPlugin class is generated.
I think I can put the files online if you want.
Rene
> Rene Ladan wrote:
>> Ed Merks wrote:
>>> Waqas,
>> ecore model) :
>> M.genmodel
>> \-- A.ecore
>> \-- B.ecore
>> 'master').
>> code?
>> Thanks,
>> Rene
>>> Waqas Ilyas wrote:
>>>> Hi,
Re: Multiple models [message #415838 is a reply to message #415837] |
Wed, 09 January 2008 12:55 |
Rene,
Comments below.
Rene Ladan wrote:
> Ed Merks wrote:
>> Rene,
>> found. I'll be looking at addressing that this bugzilla very soon:
Do you really have a resource that has instances from all the models.
If you are using purely unspecialized item providers you really won't
notice a significant difference between the reflective ones and the
generated ones because the reflective ones effectively behave just like
the default generated ones.
>> child creation based on all the models know at the time of generation.
> generation time.
Yes, but are the known to the item provider itself when it's generated.
It sounds like not if the item provider is generated by a separate
GenModel that knows only about that one model.
>> the code for the model, edit, and editor are generated into a single
> abstract class
> models.
> to be sure),
Because it's abstract you can't create an instance of it.
> instantiate class
> disabled.
The error log will describe what's wrong. I don't think the wizard code
will deal well with the case of a model for which there are no
instantiable classes. Is there some object of one of the models that's
logically the root kind of like how an EPackage is the root of any
reasonable Ecore model? You'd want just a single wizard to create it.
Any of the generated editors should work pretty much the same.
> class is generated.
I can certainly imagine all the issues, but I don't have any hard and
fast solutions. As I've said, any of the generated editors should work
to edit any of the models, but the child creation issues is a hard
problem that I've not solved yet.
> Rene
>> Rene Ladan wrote:
>>> Ed Merks wrote:
>>>> Waqas,
>>>> that
>>> containment).
>>> to generate one
>>> trying this
>>> genmodel (not as an
>>> ecore model) :
>>> M.genmodel
>>> \-- A.ecore
>>> \-- B.ecore
>>> each other in their
>>> 'master').
>>> code?
>>> Thanks,
>>> Rene
>>>> Waqas Ilyas wrote:
>>>>> Hi,
Ed Merks
Re: Multiple models [message #415841 is a reply to message #415838] |
Wed, 09 January 2008 13:53 |
Member |
Ed Merks wrote:
> Rene,
> Comments below.
> Rene Ladan wrote:
>> Ed Merks wrote:
>>> Rene,
No, it's more the other way around: I have several models m1..m5 and
instances of them which I'm trying to combine into one editor. I could
combine these models into one big model but then the top element of the
models saved with the editor will be that of the combined model instead
of that of the actual model mi. This makes some legacy tools unusable.
The reason to combine the models is that they are independent but
logically complement each other regarding transformation and analysis
purposes.
>> generation time.
I currently have 5 ecore models and one wrapper ecore model, the latter
is the only one with a genmodel.
>> abstract class
>> models.
>> to be sure),
But it still won't work after making the class non-abstract, regenerating
the code and adding some (missing?) UI strings to plugin.properties.
Each model mi (not the wrapper model) has a logical root element.
Rene
>>> Rene Ladan wrote:
>>>> Ed Merks wrote:
>>>>> Waqas,
>>>>> that
>>>> containment).
>>>> to generate one
>>>> trying this
>>>> genmodel (not as an
>>>> ecore model) :
>>>> M.genmodel
>>>> \-- A.ecore
>>>> \-- B.ecore
>>>> each other in their
>>>> 'master').
>>>> code?
>>>> Thanks,
>>>> Rene
Re: Multiple models [message #415845 is a reply to message #415841] |
Wed, 09 January 2008 15:52 |
Rene,
Comments below.
Rene Ladan wrote:
> Ed Merks wrote:
>> Rene,
>> Comments below.
>> Rene Ladan wrote:
>>> Ed Merks wrote:
>>>> Rene,
I see. Note that EMF supports this like cross resource containment so
you could make it look like one big model for the editor, but still
serialize each branch in a separate file. Maybe that's what you want.
Otherwise, you can load multiple resources into a single editor using
"Load Resource..." so you might have some other automatic way of loading
them.
> purposes.
So the trick will be if you need something to tie them together or you
have some way to figure out the others just given one of them...
>>> generation time.
>> generated. It sounds like not if the item provider is generated by a
>> separate GenModel that knows only about that one model.
Okay. That's seems fine. Sorry for misunderstanding.
>>> abstract class
>>> other models.
>>> to be sure),
There shouldn't be anything missing. But keep in mind that plugin.xml
and MANIFEST.MFs aren't regenerated if you make changes to the model
that effect them. What exactly isn't working?
>> Is there some object of one of the models that's logically the root
>> kind of like how an EPackage is the root of any reasonable Ecore
>> model? You'd want just a single wizard to create it. Any of the
So I still think you could avoid generating any editors for any of the
other models and generate just the editor for the composite model. But
it seems there are problem but there shouldn't be. I'll need to know
the details...
> Rene
>>>> Rene Ladan wrote:
>>>>> Ed Merks wrote:
>>>>>> Waqas,
>>>>>> .ecores that
>>>>>> this.
>>>>> via containment).
>>>>> to generate one
>>>>> I'm trying this
>>>>> genmodel (not as an
>>>>> ecore model) :
>>>>> M.genmodel
>>>>> \-- A.ecore
>>>>> \-- B.ecore
>>>>> 'master').
>>>>> code?
>>>>> Thanks,
>>>>> Rene
Ed Merks
Re: Multiple models [message #415904 is a reply to message #415845] |
Thu, 10 January 2008 10:26 |
Member |
Ed Merks wrote:
> Rene,
> Comments below.
> Rene Ladan wrote:
>> Ed Merks wrote:
>>> Rene,
>>> Comments below.
>>> Rene Ladan wrote:
>>>> Ed Merks wrote:
>>>>> Rene,
Yes, that is exactly what I needed :) The FAQ at the EMF wiki and the
"Control..." option proved to be helpful.
> them.
Using the "Load Resource..." option, dragging the model into the main model
under the "meta" element and exporting it via "Control..." seems the way to
go right now. Not very user-friendly, but it works.
Rene
Current Time: Thu Apr 25 16:18:34 GMT 2024
Powered by FUDForum. Page generated in 0.03817 seconds
