Home » Eclipse Projects » Rich Client Platform (RCP) » ActionSet enablement ?
ActionSet enablement ? [message #406799] Wed, 26 January 2005 21:29 Go to next message
Stephane  fournier is currently offline Stephane fournierFriend
I would like to add Menus and MenuItems intoPerspective in using
actionSet rather than using WorkbenchAdvisor way with contributions ...
But to enable or disable the MenuItems, I need to perform a method
(boolean computeEnablement() ) to check user rigths and so on...
I do not want this method called on selectionChanged but called when
the menu is opened.
I have only read some criteria for actionSet to deal with enablement :
enableFor + enablement objectClass ....
I am a bit confused because it seems not to suit my needs.
Does anyone know how to do that ?
Stephane
Re: ActionSet enablement ? [message #435431 is a reply to message #406799] Thu, 18 August 2005 08:37 Go to previous message
WojT is currently offline WojTFriend
> I do not want this method called on selectionChanged but called when the
> menu is opened.
I have done it like this:
WorkbenchWindow workbenchWindow = get Workbench Window in Your way....
String mainMenuText = "menu label You set in actionSet in plugin.xml"
String subMenuText = "action label You set for subMenu"
MenuManager manager = workbenchWindow.getMenuManager();
MenuItem[] items = manager.getMenu().getItems();
for (int i = 0; i < items.length; i++){
MenuItem item = items[i];
if (item.getText().equals(mainMenuText)){
MenuItem[] subItems = item.getMenu().getItems();
for (int j = 0; j < subItems.length; j++){
MenuItem subItem = subItems[j];
if (subItem.getText().equals(subMenuText)){
subItem.setEnabled('THERE YOU SHOULD PUT METHOD WHICH
COMPUTE MENU ENABLING');
Maybe it is not the best way but it works for me :)
...::WojT::..
Previous Topic:remove/kill/destroy view and reinitialize it
Next Topic:How to load a class of swt
Current Time: Fri Dec 06 14:59:55 GMT 2024
Powered by FUDForum. Page generated in 0.03023 seconds
