Re: Registering a resource factory on a file name [message #399092] |
Mon, 06 March 2006 18:09  |
I dredged this up from the depths (dated Tue, 13 Apr 2004):
> Stefan,
> We may consider adding support for this to Resource.Factory.Registry in the
> future. For now you can override ResourceFactoryRegistryImpl.getFactory() to
> detect this case.
> Stefan wrote:
> > Hi,
> > I'd like to use my own resource / resource factory implementation for
> > ejb-jar.xml files. Of course I don't want to register the factory on the
> > ".xml" file extension, and I also don't want to invent my own URI protocol
> > for this, but use standard 'file:' URIs. Is it possible to register a
> > factory on a complete file name instead, i.e. "ejb-jar.xml" ? Which EMF
> > class would I need to subclass for accomplishing this?
> > bye,
> > Stefan
I have the exact same question. I want to do this for my particular
foo.xml file, but I don't want to register the factory on the entire
".xml" extension. Is there now extended support for this?
- Paul
Re: Registering a resource factory on a file name [message #399096 is a reply to message #399092] |
Tue, 07 March 2006 07:01   |
Paul,
You can register a factory for *.xml by extending the existing
XMLResourceFactoryImpl and overriding createResource to do something
special for certain special files and call super for the rest.
>> Stefan,
>> in the
>> detect this case.
>> Stefan wrote:
>> > Hi,
>> on the
>> protocol
>> EMF
>> > bye,
>> > Stefan
> - Paul
Re: Registering a resource factory on a file name [message #399423 is a reply to message #399422] |
Thu, 16 March 2006 15:42   |
Paul,
You'd register it only local to your resource set where you have
complete control, not in the global registry that effects everyone,
which would be very rude indeed!
> Ed Merks wrote:
>> Paul,
> Hi Ed,
> Isn't that a bit impolite? How about the others out there using the
> .xml extension? Won't I potentially be replacing somebody else's use
> of an extension of XMLResourceFactoryImpl?
> For instance, if somebody is trying to do something similar for
> foo.xml, and they implement FooXMLResourceFactoryImpl, which they then
> register to the *.xml extension, which factory would be retrieved in
> the lookup for an *.xml file? Theirs or mine?
> - Paul
Re: Registering a resource factory on a file name [message #1069711 is a reply to message #1069701] |
Tue, 16 July 2013 08:43  |
Am 16.07.2013 14:24, schrieb Wladimir Safonov:
> Hi Ed,
> I ran now into the same situation where support of file name matching for resource factories lookup is needed. I
> cannot simply use my local resource set for registering "xml" extension factory, because we have several *.xml files
> containing models of different types, which all need to be loaded into the same resource set. So I am looking now at
> the possibility of implementing another extension point which would provide support for configuring resource factory
> using file name patterns and hook it into the ResourceFactoryRegistryImpl.getFactory() method.
> Is there something similar planned in EMF for the future? Or is there meanwhile a better way to solve the problem? Of
> course, name patterns can still lead to overlapping, but this is a trade-off for giving more flexibility to the user.
> I can imagine that the resource factory registration based on name patterns can replace those based on file extensions
> and make the corresponding extension point obsolete after a while.
This thread might be interesting for you: http://www.eclipsezone.com/eclipse/forums/t107605.html
Cheers
/Eike
http://www.esc-net.de
FUDForum. Page generated in 0.04742 seconds
