Home » Modeling » EMF » Q: Loading XMLResources containing non-modeled namespaces?
Q: Loading XMLResources containing non-modeled namespaces? [message #386108] |
Wed, 16 June 2004 11:26 |
No real name Messages: 121 Registered: July 2009 |
I want to be able to load an object instance from persistent storage in
XML, such that the XML document is allowed to contain namespaces which
were unknown at the time the ecore was created.
Example: I generate a model using the library.xsd from the EMF Overview.
I progammatically instantiated a library and book and persist it using
XMLResourceImpl. I load that same XML document and instantiate the
Library. So far, so good.
Now I introduce an element from another non-modelled namespace, foo:
<?xml version="1.0" encoding="ASCII"?>
<library:Library xmlns:library="http://www.example.eclipse.org/Library">
<m:foo xmlns:m="http://example.org/foo">
<m:msg>Have a nice day</m:msg>
</m:foo>
<books title="Once upon a time" pages="100" category="Biography"
author="/1"/>
</library:Library>
I receive an exception:
org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'foo' not
found. (file:/c:/dev/libraryEmfXsd/xml/lib2.xml, 4, 43)
Is it possible that the unknown namespace, foo, is ignored and I still
instantiate the library portion without exception?
chris
PS. Here is my code to load:
File file = new File("xml/lib2.xml");
String filename = file.getAbsolutePath();
URI uri = URI.createFileURI(filename);
LibraryPackage pkg = LibraryPackageImpl.init();
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().
getExtensionToFactoryMap().put("*",new XMLResourceFactoryImpl());
Resource resource = resourceSet.createResource(uri);
resource.load(new FileInputStream(filename),Collections.EMPTY_MAP);
Re: Q: Loading XMLResources containing non-modeled namespaces? [message #386109 is a reply to message #386108] |
Wed, 16 June 2004 12:01 |
Ed Merks Messages: 33137 Registered: July 2009 |
Chris,
The exceptions are recorded and aren't thrown until the whole document is
processed, so you should pretty much already have what you want if you just
ignore errors. You should maybe consider using wildcards to allow such
content in the document rather than just wanting the errors to be ignored.
Another feature you can take advantage of is to use
XMLResource.OPTION_RECORD_UNKNOWN_FEATURES. When this is enabled, all the
unrecognized content is recorded in the EObjectToExtensionMap and no
exceptions produced.
Chris Giblin wrote:
> </m:foo>
> author="/1"/>
> </library:Library>
> chris
Ed Merks
Re: Q: Loading XMLResources containing non-modeled namespaces? [message #386111 is a reply to message #386109] |
Wed, 16 June 2004 12:13 |
Ed,
Mega-cool. That did it:
HashMap options = new HashMap(5);
options.put(XMLResource.OPTION_RECORD_UNKNOWN_FEATURE,
new Boolean(true));
resource.load(new FileInputStream(filename),options);
Thanks much,
Chris
Ed Merks wrote:
> Chris,
> Chris Giblin wrote:
>>Hi,
>> </m:foo>
>>author="/1"/>
>></library:Library>
>>Thanks,
>>chris
Re: Q: Loading XMLResources containing non-modeled namespaces? [message #386115 is a reply to message #386111] |
Wed, 16 June 2004 12:37 |
Chris,
I think this will be a pretty popular feature. The recorded out-of-band content,
i.e., the stuff in the map, will even be written out again on save, although
relative order with respect to recognized content won't be preserved.
As an aside, using Boolean.TRUE is better than new Boolean(true). ;-)
Chris Giblin wrote:
> Ed,
> new Boolean(true));
> Thanks much,
> Chris
> Ed Merks wrote:
> > Chris,
> > Chris Giblin wrote:
> >>Hi,
> >> </m:foo>
> >>author="/1"/>
> >></library:Library>
> >>Thanks,
> >>chris
Ed Merks
Re: Q: Loading XMLResources containing non-modeled namespaces? [message #415903 is a reply to message #386111] |
Thu, 10 January 2008 10:19 |
Rene Ladan Messages: 51 Registered: July 2009 |
Member |
This works nice indeed.
But is there a way to preserve the original namespaces/prefixes upon save?
I assume they get overridden by the namespace of the ecore model upon which
the editor is based when loading the model.
For the record, the code is in xyz.presentation.xyzEditor.handleChangedResources()
(usually in abc.editor/xyz.presentation/xyzEditor.java)
Rene
Chris Giblin wrote:
> Ed,
> new Boolean(true));
> Thanks much,
> Chris
> Ed Merks wrote:
>> Chris,
>> just
>> ignored.
>> the
>> Chris Giblin wrote:
>>> Hi,
>>> </m:foo>
>>> author="/1"/>
>>> </library:Library>
>>> Thanks,
>>> chris
Re: Q: Loading XMLResources containing non-modeled namespaces? [message #415906 is a reply to message #415903] |
Thu, 10 January 2008 11:49 |
Rene,
Namespace should always be preserved. XMI serializations don't
generally preserve prefixes because the prefixes used while loading are
not saved anywhere. XML serializations where the model uses a document
root will try to preserve prefixes because the documents root's
XMLNSPrefix map records them. But the prefixes will be bubbled to the
top of the document and if there are collisions, the prefixes will be
changed to make them unique. The XMLHelper has methods for getting and
setting prefix map at the end of loading or before saving, so I suppose
one could specialize a resource implementation to exploit that to record
the information somewhere other than on the document root.
> save?
> which
> Rene
> Chris Giblin wrote:
>> Ed,
>> new Boolean(true));
>> Thanks much,
>> Chris
>> Ed Merks wrote:
>>> Chris,
>>> document is
>>> you just
>>> ignored.
>>> all the
>>> Chris Giblin wrote:
>>>> Hi,
>>>> storage in
>>>> Overview.
>>>> <library:Library
>>>> </m:foo>
>>>> author="/1"/>
>>>> </library:Library>
>>>> Thanks,
>>>> chris
Ed Merks
Re: Q: Loading XMLResources containing non-modeled namespaces? [message #415908 is a reply to message #415903] |
Thu, 10 January 2008 15:12 |
Member |
The trick doesn't seem to work when loading external resources having foreign
namespaces without a prefix.
The following model has a namespace "XML" without a prefix. The element Root
is non-abstract and referenced via a cross-resource reference.
<Root xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns="XML" name="parameters">
This is the exception I get :
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedException: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'XML' not found. (file:../parameters-XML.ecore, 4, 35)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:316)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:275)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:398)
at org.eclipse.emf.edit.ui.action.LoadResourceAction$LoadResour ceDialog.processResources(LoadResourceAction.java:126)
at org.eclipse.emf.common.ui.dialogs.ResourceDialog.okPressed(R esourceDialog.java:331)
at org.eclipse.jface.dialogs.Dialog.buttonPressed(Dialog.java:4 64)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:616)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:227)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
at org.eclipse.emf.edit.ui.action.LoadResourceAction.run(LoadRe sourceAction.java:77)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'XML' not found. (file:.../parameters-XML.ecore, 4, 35)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(X MLHandler.java:2453)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefi x(XMLHandler.java:2285)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java:1239)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java:1336)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:970)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:83)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:953)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:684)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:167)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator. startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl$ContentDriver.scanRootElementHook(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl$PrologDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:179)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1354)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1155)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:256)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:271)
.... 42 more
Eclipse 3.3.1.1, EMF 2.3.1
Any ideas?
Rene
w
> Chris Giblin wrote:
>> Ed,
>> new Boolean(true));
>> Thanks much,
>> Chris
>> Ed Merks wrote:
>>> Chris,
>>> document is
>>> you just
>>> ignored.
>>> all the
>>> Chris Giblin wrote:
>>>> Hi,
>>>> Overview.
>>>> <library:Library
>>>> </m:foo>
>>>> author="/1"/>
>>>> </library:Library>
>>>> Thanks,
>>>> chris
Re: Q: Loading XMLResources containing non-modeled namespaces? [message #415911 is a reply to message #415908] |
Thu, 10 January 2008 17:12 |
--------------070907090505090104040205
Rene,
Does it call this method in XMLHandler and if so, I wonder why it
doesn't return a demand created package for your URI:
protected EPackage handleMissingPackage(String uriString)
if (XMLResource.XML_SCHEMA_URI.equals(uriString))
return xmlSchemaTypePackage;
else if (extendedMetaData != null)
if (recordUnknownFeature)
return extendedMetaData.demandPackage(uriString);
>> save?
>> which
> foreign
> element Root
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> .... 42 more
> Any ideas?
> Rene
> w
>> Chris Giblin wrote:
>>> Ed,
>>> new Boolean(true));
>>> Thanks much,
>>> Chris
>>> Ed Merks wrote:
>>>> Chris,
>>>> document is
>>>> you just
>>>> such
>>>> ignored.
>>>> all the
>>>> Chris Giblin wrote:
>>>>> Hi,
>>>>> storage in
>>>>> which
>>>>> Overview.
>>>>> using
>>>>> <library:Library
>>>>> </m:foo>
>>>>> author="/1"/>
>>>>> </library:Library>
>>>>> still
>>>>> Thanks,
>>>>> chris
<html>
<head>
</head>
Rene,<br>
<br>
doesn't return a demand created package for your URI:<br>
<blockquote><small> protected EPackage handleMissingPackage(String
uriString)<br>
{<br>
if (XMLResource.XML_SCHEMA_URI.equals(uriString))<br>
{<br>
return xmlSchemaTypePackage;<br>
}<br>
else if (extendedMetaData != null)<br>
{<br>
if (recordUnknownFeature)<br>
{<br>
return extendedMetaData.demandPackage(uriString);<br>
}</small><br>
</blockquote>
<br>
Rene Ladan wrote:
<blockquote cite="mid:fm5cl4$o3t$1@build.eclipse.org" type="cite">Rene
Ladan wrote:
<br>
<blockquote type="cite">This works nice indeed.
<br>
save?
<br>
which
<br>
<br>
<br>
</blockquote>
foreign
<br>
<br>
element Root
<br>
<br>
<br>
<br>
xmlns:xmi=<a class="moz-txt-link-rfc2396E" href="http://www.omg.org/XMI">"http://www.omg.org/XMI"</a>
xmlns:xsi=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/2001/XMLSchema-instance">"http://www.w3.org/2001/XMLSchema-instance"</a>
<br>
<br>
<br>
<br>
<br>
'XML' not found. (<a class="moz-txt-link-freetext" href="file:../parameters-XML.ecore">file:../parameters-XML.ecore </a>, 4, 35)
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
with uri 'XML' not found. (<a class="moz-txt-link-freetext" href="file:.../parameters-XML.ecore">file:.../parameters-XML.ecore </a>, 4, 35)
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
..... 42 more
<br>
<br>
<br>
<br>
Any ideas?
<br>
<br>
<br>
Rene
<br>
w
<br>
<blockquote type="cite">Chris Giblin wrote:
<br>
<blockquote type="cite">Ed,
<br>
<br>
<br>
<br>
<br>
new Boolean(true));
<br>
<br>
<br>
Thanks much,
<br>
Chris
<br>
<br>
<br>
Ed Merks wrote:
<br>
<br>
<blockquote type="cite">Chris,
<br>
<br>
is
<br>
just
<br>
<br>
ignored.
<br>
<br>
the
<br>
<br>
<br>
<br>
<br>
Chris Giblin wrote:
<br>
<br>
<br>
<blockquote type="cite">Hi,
<br>
<br>
<br>
<br>
<br>
Overview.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<library:Library
xmlns:library=<a class="moz-txt-link-rfc2396E" href="http://www.example.eclipse.org/Library">"http://www.example.eclipse.org/Library"</a>>
<br>
<br>
<m:foo xmlns:m=<a class="moz-txt-link-rfc2396E" href="http://example.org/foo">"http://example.org/foo"</a>>
<br>
<br>
</m:foo>
<br>
<br>
<br>
author="/1"/>
<br>
</library:Library>
<br>
<br>
<br>
<br>
found. (<a class="moz-txt-link-freetext" href="file:/c:/dev/libraryEmfXsd/xml/lib2.xml">file:/c:/dev/libraryEmfXsd/xml/lib2.xml </a>, 4, 43)
<br>
<br>
<br>
<br>
<br>
<br>
chris
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------070907090505090104040205--
Ed Merks
Re: Q: Loading XMLResources containing non-modeled namespaces? [message #415917 is a reply to message #415911] |
Fri, 11 January 2008 08:51 |
Member |
Ed Merks wrote:
> Rene,
The XyzEditor.java file imports XMLHandler but leaves it otherwise unused.
According to the (partial) backtrace, handleMissingPackage() is not called.
I've tried setting up breakpoints for PackageNotFoundException and at the
start of method handleChangedResources() but they get skipped over (running
in debug view).
>>> save?
>>> which
>> foreign
>> element Root
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> .... 42 more
>> Any ideas?
>> Thanks,
>> Rene
>> w
>>> Chris Giblin wrote:
>>>> Ed,
>>>> new Boolean(true));
>>>> Thanks much,
>>>> Chris
>>>> Ed Merks wrote:
>>>>> Chris,
>>>>> document is
>>>>> you just
>>>>> such
>>>>> ignored.
>>>>> all the
>>>>> Chris Giblin wrote:
>>>>>> Hi,
>>>>>> storage in
>>>>>> which
>>>>>> Overview.
>>>>>> using
>>>>>> <library:Library
>>>>>> </m:foo>
>>>>>> author="/1"/>
>>>>>> </library:Library>
>>>>>> still
>>>>>> Thanks,
>>>>>> chris
Re: Q: Loading XMLResources containing non-modeled namespaces? [message #415918 is a reply to message #415917] |
Fri, 11 January 2008 09:21 |
Rene,
All three places that throw PackageNotFoundException (all in XMLHandler)
all call handleMissingPackage before throwing that exception, so I'm
confused by your analysis that handleMissingPackage isn't even called.
Keep in mind that the exception is recorded and thrown later so set a
breakpoint in the constructor of the exception. It seems impossible for
that not to get hit unless there is a bug in the debugger, which seems
unlikely. Does you debugger work at all? I.e., can you get it to stop
anywhere in any of the EMF code?
Rene Ladan wrote:
> Ed Merks wrote:
>> Rene,
> unused.
> called.
> (running
> in debug view).
>>>> upon save?
>>>> upon which
>>> having foreign
>>> element Root
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> 35)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> .... 42 more
>>> Any ideas?
>>> Thanks,
>>> Rene
>>> w
>>>> Chris Giblin wrote:
>>>>> Ed,
>>>>> new Boolean(true));
>>>>> Thanks much,
>>>>> Chris
>>>>> Ed Merks wrote:
>>>>>> Chris,
>>>>>> document is
>>>>>> if you just
>>>>>> allow such
>>>>>> ignored.
>>>>>> enabled, all the
>>>>>> Chris Giblin wrote:
>>>>>>> Hi,
>>>>>>> storage in
>>>>>>> which
>>>>>>> Overview.
>>>>>>> using
>>>>>>> foo:
>>>>>>> <library:Library
>>>>>>> </m:foo>
>>>>>>> author="/1"/>
>>>>>>> </library:Library>
>>>>>>> 'foo' not
>>>>>>> still
>>>>>>> Thanks,
>>>>>>> chris
Ed Merks
Re: Q: Loading XMLResources containing non-modeled namespaces? [message #415924 is a reply to message #415918] |
Fri, 11 January 2008 12:12 |
Member |
Ed Merks wrote:
> Rene,
It turns out that the exception is indeed thrown, as is ClassNotFoundException()
(the EMF variant). I also tried changing the namespace to "http://www.w3.org/XML"
(not official, but it looks like XML has none), but that didn't help either (it
tries to substitute the html namespace). An empty namespace gives an exception
similar to the first one.
Yes, I can set a breakpoint at initializeEditingDomain() upon which the
IDE stops.
> Rene Ladan wrote:
>> Ed Merks wrote:
>>> Rene,
>> unused.
>> called.
>> (running
>> in debug view).
>>>>> upon save?
>>>>> upon which
>>>> having foreign
>>>> element Root
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> 35)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> .... 42 more
>>>> Any ideas?
>>>> Thanks,
>>>> Rene
>>>> w
>>>>> Chris Giblin wrote:
>>>>>> Ed,
>>>>>> new Boolean(true));
>>>>>> Thanks much,
>>>>>> Chris
>>>>>> Ed Merks wrote:
>>>>>>> Chris,
>>>>>>> document is
>>>>>>> if you just
>>>>>>> allow such
>>>>>>> ignored.
>>>>>>> enabled, all the
>>>>>>> Chris Giblin wrote:
>>>>>>>> Hi,
>>>>>>>> storage in
>>>>>>>> which
>>>>>>>> Overview.
>>>>>>>> using
>>>>>>>> foo:
>>>>>>>> <library:Library
>>>>>>>> </m:foo>
>>>>>>>> author="/1"/>
>>>>>>>> </library:Library>
>>>>>>>> 'foo' not
>>>>>>>> still
>>>>>>>> Thanks,
>>>>>>>> chris
Re: Q: Loading XMLResources containing non-modeled namespaces? [message #415925 is a reply to message #415924] |
Fri, 11 January 2008 12:49 |
--------------090006020605040809090509
Rene,
If I change the LibraryExample.java generated in the *.tests project
generated for the XML Schema library tutorial like this:
XMLResource resource =
(XMLResource)resourceSet.createResource(URI.createURI("http:///My.library"));
DocumentRoot documentRoot =
LibraryFactory.eINSTANCE.createDocumentRoot();
Library root = LibraryFactory.eINSTANCE.createLibrary();
documentRoot.setLibrary(root);
resource.getContents().add(documentRoot);
Map<Object, Object> options = new HashMap<Object, Object>();
// options.put(XMLResource.OPTION_USE_FILE_BUFFER, Boolean.TRUE);
resource.save(System.out, options);
StringWriter stringWriter = new StringWriter();
resource.save(stringWriter, null);
System.out.println();
XMLResource resource2 =
(XMLResource)resourceSet.createResource(URI.createURI("http:///My2.library"));
resource2.load(new InputSource(new
StringReader(stringWriter.getBuffer().toString().replace("xmlns:library ",
"xmlns:other").replace("library:library", "other:library"))), null);
resource2.save(System.out, null);
XMLResource resource3 =
Boolean.TRUE);
resource3.load(new InputSource(new
StringReader(stringWriter.getBuffer().toString().replace("www.example.com ",
"www.example.org"))), options);
resource3.save(System.out, null);
it prints out this:
Enter a list of file paths or URIs that have content like this:
<library:library xmlns:library="http://www.example.com/Library"/>
<other:library xmlns:other="http://www.example.com/Library"/>
<library:library xmlns:library="http://www.example.org/Library"/>
So it appears to be working well. It's hard to comment on what's going
wrong for you because I'm not actually what you're doing and you don't
seem to be able to set a breakpoint and stop in handleMissingPackage, or
did you actually manage that?
Rene Ladan wrote:
> Ed Merks wrote:
>> Rene,
>> XMLHandler) all call handleMissingPackage before throwing that
>> exception, so I'm confused by your analysis that handleMissingPackage
>> isn't even called. Keep in mind that the exception is recorded and
>> thrown later so set a breakpoint in the constructor of the exception.
> either (it
> exception
>> It seems impossible for that not to get hit unless there is a bug in
>> the debugger, which seems unlikely. Does you debugger work at all?
>> I.e., can you get it to stop anywhere in any of the EMF code?
> IDE stops.
>> Rene Ladan wrote:
>>> Ed Merks wrote:
>>>> Rene,
>>> unused.
>>> called.
>>> at the
>>> (running
>>> in debug view).
>>>>>> upon save?
>>>>>> upon which
>>>>> having foreign
>>>>> element Root
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> 4, 35)
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> .... 42 more
>>>>> Any ideas?
>>>>> Thanks,
>>>>> Rene
>>>>> w
>>>>>> Chris Giblin wrote:
>>>>>>> Ed,
>>>>>>> new Boolean(true));
>>>>>>> Thanks much,
>>>>>>> Chris
>>>>>>> Ed Merks wrote:
>>>>>>>> Chris,
>>>>>>>> document is
>>>>>>>> if you just
>>>>>>>> allow such
>>>>>>>> be ignored.
>>>>>>>> enabled, all the
>>>>>>>> and no
>>>>>>>> Chris Giblin wrote:
>>>>>>>>> Hi,
>>>>>>>>> storage in
>>>>>>>>> namespaces which
>>>>>>>>> Overview.
>>>>>>>>> it using
>>>>>>>>> the
>>>>>>>>> namespace, foo:
>>>>>>>>> <library:Library
>>>>>>>>> </m:foo>
>>>>>>>>> author="/1"/>
>>>>>>>>> </library:Library>
>>>>>>>>> 'foo' not
>>>>>>>>> I still
>>>>>>>>> Thanks,
>>>>>>>>> chris
>>>>>>>>> resource.load(new
<html>
<head>
</head>
Rene,<br>
<br>
generated for the XML Schema library tutorial like this:<br>
<br>
(XMLResource)resourceSet.createResource(URI.createURI(<a class="moz-txt-link-rfc2396E" href="http:///My.library">"http:///My.library"</a>));<br>
LibraryFactory.eINSTANCE.createDocumentRoot();<br>
Library root = LibraryFactory.eINSTANCE.createLibrary();<br>
documentRoot.setLibrary(root);<br>
resource.getContents().add(documentRoot);<br>
Object>();<br>
Boolean.TRUE);<br>
resource.save(System.out, options);<br>
StringWriter stringWriter = new StringWriter();<br>
resource.save(stringWriter, null);<br>
System.out.println();<br>
<br>
(XMLResource)resourceSet.createResource(URI.createURI(<a class="moz-txt-link-rfc2396E" href="http:///My2.library">"http:///My2.library"</a>));<br>
"xmlns:other").replace("library:library", "other:library"))), null);<br>
resource2.save(System.out, null);<br>
<br>
Boolean.TRUE);<br>
StringReader(stringWriter.getBuffer().toString().replace("<a class="moz-txt-link-abbreviated" href="http://www.example.com">www.example.com</a>",
"<a class="moz-txt-link-abbreviated" href="http://www.example.org">www.example.org</a>"))), options);<br>
resource3.save(System.out, null);<br>
<br>
it prints out this:<br>
<blockquote>Enter a list of file paths or URIs that have content like
this:<br>
<?xml version="1.0" encoding="ASCII"?><br>
<library:library xmlns:library=<a class="moz-txt-link-rfc2396E" href="http://www.example.com/Library">"http://www.example.com/Library"</a>/><br>
<other:library xmlns:other=<a class="moz-txt-link-rfc2396E" href="http://www.example.com/Library">"http://www.example.com/Library"</a>/><br>
<library:library xmlns:library=<a class="moz-txt-link-rfc2396E" href="http://www.example.org/Library">"http://www.example.org/Library"</a>/><br>
</blockquote>
going wrong for you because I'm not actually what you're doing and you
don't seem to be able to set a breakpoint and stop in
handleMissingPackage, or did you actually manage that?<br>
<br>
<br>
Rene Ladan wrote:
<blockquote cite="mid:fm7mg4$o0l$1@build.eclipse.org" type="cite">Ed
Merks wrote:
<br>
<blockquote type="cite">Rene,
<br>
<br>
<br>
</blockquote>
<br>
<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/XML">"http://www.w3.org/XML"</a>
<br>
either (it
<br>
exception
<br>
<br>
<br>
<blockquote type="cite"> It seems impossible for that not to get hit
unless there is a bug in the debugger, which seems unlikely. Does you
debugger work at all? I.e., can you get it to stop anywhere in any of
the EMF code?
<br>
<br>
</blockquote>
<br>
IDE stops.
<br>
<br>
<blockquote type="cite"><br>
Rene Ladan wrote:
<br>
<blockquote type="cite">Ed Merks wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
unused.
<br>
called.
<br>
the
<br>
(running
<br>
in debug view).
<br>
<br>
Rene Ladan wrote:
<br>
<blockquote type="cite">Rene Ladan wrote:
<br>
<br>
save?
<br>
which
<br>
<br>
<br>
</blockquote>
foreign
<br>
<br>
element Root
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
..... 42 more
<br>
<br>
<br>
<br>
Any ideas?
<br>
<br>
<br>
Rene
<br>
w
<br>
<br>
<br>
<br>
<br>
<br>
<br>
new Boolean(true));
<br>
<br>
<br>
Thanks much,
<br>
Chris
<br>
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
<br>
is
<br>
just
<br>
<br>
ignored.
<br>
<br>
the
<br>
<br>
<br>
<br>
<br>
Chris Giblin wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Overview.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<library:Library
<br>
<br>
<br>
<br>
</m:foo>
<br>
<br>
<br>
author="/1"/>
<br>
</library:Library>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
chris
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------090006020605040809090509--
Ed Merks
Re: Q: Loading XMLResources containing non-modeled namespaces? [message #415927 is a reply to message #415925] |
Fri, 11 January 2008 14:17 |
Member |
Ed Merks wrote:
> Rene,
I managed to set a breakpoint there. If I add a prefixless namespace having
value "XML", this happens at line 2465 of XMLHandler.java:
uriString == "XML"
extendedMetadata == null
return null
This produces a PackageNotFoundException, but the program keeps trying to add
a node "Root" to the top of the (new?) tree. This fails too because, causing
a ClassNotFoundException which gets thrown using the error() method.
The same exceptions occur if I open the file (attached) in the Sample EMF Editor.
After performing "Register metamodel" on the metamodel (an ATL menu extension)
the exception is still thrown. However, after performing the same action on a partial
metamodel describing only the relevant part where the package name is "XML", the
file is actually editable in the Sample EMF Editor.
Maybe I should just remove it from the metamodel since it's not really worth the
trouble...
> Rene Ladan wrote:
>> Ed Merks wrote:
>>> Rene,
>> either (it
>> exception
>> IDE stops.
>>> Rene Ladan wrote:
>>>> Ed Merks wrote:
>>>>> Rene,
>>>> unused.
>>>> called.
>>>> at the
>>>> (running
>>>> in debug view).
>>>>>>> upon save?
>>>>>>> upon which
>>>>>> having foreign
>>>>>> element Root
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> 4, 35)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> .... 42 more
>>>>>> Any ideas?
>>>>>> Thanks,
>>>>>> Rene
>>>>>> w
>>>>>>> Chris Giblin wrote:
>>>>>>>> Ed,
>>>>>>>> new Boolean(true));
>>>>>>>> Thanks much,
>>>>>>>> Chris
>>>>>>>> Ed Merks wrote:
>>>>>>>>> Chris,
>>>>>>>>> document is
>>>>>>>>> if you just
>>>>>>>>> allow such
>>>>>>>>> be ignored.
>>>>>>>>> enabled, all the
>>>>>>>>> and no
>>>>>>>>> Chris Giblin wrote:
>>>>>>>>>> Hi,
>>>>>>>>>> storage in
>>>>>>>>>> namespaces which
>>>>>>>>>> Overview.
>>>>>>>>>> it using
>>>>>>>>>> the
>>>>>>>>>> namespace, foo:
>>>>>>>>>> <library:Library
>>>>>>>>>> </m:foo>
>>>>>>>>>> author="/1"/>
>>>>>>>>>> </library:Library>
>>>>>>>>>> 'foo' not
>>>>>>>>>> I still
>>>>>>>>>> Thanks,
>>>>>>>>>> chris
>>>>>>>>>> resource.load(new
Re: Q: Loading XMLResources containing non-modeled namespaces? [message #415931 is a reply to message #415927] |
Fri, 11 January 2008 16:05 |
--------------010003070401000107040406
Rene,
Comments below.
Rene Ladan wrote:
> Ed Merks wrote:
>> Rene,
>> you don't seem to be able to set a breakpoint and stop in
> having
> uriString == "XML"
> return null
> to add
> causing
Given that the option you said you are using would have ensured that
extendedMetaData was not null, I would conclude that you aren't using
the option:
recordUnknownFeature =
Boolean.TRUE.equals(options.get(XMLResource.OPTION_RECORD_UN KNOWN_FEATURE));
if (recordUnknownFeature && extendedMetaData == null)
setExtendedMetaDataOption(Boolean.TRUE);
> EMF Editor.
> extension)
> action on a partial
> "XML", the
I don't understand this part. I thought the whole line of discussion
was that the option above wasn't working?
> worth the
> trouble...
>> Rene Ladan wrote:
>>> Ed Merks wrote:
>>>> Rene,
>>>> handleMissingPackage isn't even called. Keep in mind that the
>>>> exception is recorded and thrown later so set a breakpoint in the
>>> either (it
>>> an exception
>>>> in the debugger, which seems unlikely. Does you debugger work at
>>>> all? I.e., can you get it to stop anywhere in any of the EMF code?
>>> IDE stops.
>>>> Rene Ladan wrote:
>>>>> Ed Merks wrote:
>>>>>> Rene,
>>>>> unused.
>>>>> not called.
>>>>> at the
>>>>> (running
>>>>> in debug view).
>>>>>>>> upon save?
>>>>>>>> model upon which
>>>>>>> having foreign
>>>>>>> element Root
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> .... 42 more
>>>>>>> Any ideas?
>>>>>>> Thanks,
>>>>>>> Rene
>>>>>>> w
>>>>>>>> Chris Giblin wrote:
>>>>>>>>> Ed,
>>>>>>>>> new Boolean(true));
>>>>>>>>> Thanks much,
>>>>>>>>> Chris
>>>>>>>>> Ed Merks wrote:
>>>>>>>>>> Chris,
>>>>>>>>>> document is
>>>>>>>>>> want if you just
>>>>>>>>>> allow such
>>>>>>>>>> to be ignored.
>>>>>>>>>> enabled, all the
>>>>>>>>>> and no
>>>>>>>>>> Chris Giblin wrote:
>>>>>>>>>>> Hi,
>>>>>>>>>>> storage in
>>>>>>>>>>> namespaces which
>>>>>>>>>>> EMF Overview.
>>>>>>>>>>> persist it using
>>>>>>>>>>> instantiate the
>>>>>>>>>>> namespace, foo:
>>>>>>>>>>> <library:Library
>>>>>>>>>>> </m:foo>
>>>>>>>>>>> author="/1"/>
>>>>>>>>>>> </library:Library>
>>>>>>>>>>> 'foo' not
>>>>>>>>>>> and I still
>>>>>>>>>>> Thanks,
>>>>>>>>>>> chris
>>>>>>>>>>> resource.load(new
<html>
<head>
</head>
Rene,<br>
<br>
Comments below.<br>
<br>
Rene Ladan wrote:
<blockquote cite="mid:fm7tpq$mmq$1@build.eclipse.org" type="cite">Ed
Merks wrote:
<br>
<br>
<br>
</blockquote>
<br>
<blockquote type="cite">So it appears to be working well. It's hard
to comment on what's going wrong for you because I'm not actually what
you're doing and you don't seem to be able to set a breakpoint and stop
in handleMissingPackage, or did you actually manage that?
<br>
</blockquote>
having
<br>
<br>
uriString == "XML"
<br>
<br>
return null
<br>
to add
<br>
causing
<br>
<br>
</blockquote>
the option:<br>
<br>
<small> recordUnknownFeature =
<br>
if (recordUnknownFeature && extendedMetaData == null)<br>
{<br>
setExtendedMetaDataOption(Boolean.TRUE);<br>
}</small><br>
<br>
<br>
<blockquote cite="mid:fm7tpq$mmq$1@build.eclipse.org" type="cite"><br>
EMF Editor.
<br>
extension)
<br>
action on a partial
<br>
"XML", the
<br>
<br>
</blockquote>
was that the option above wasn't working?<br>
worth the
<br>
trouble...
<br>
<br>
Rene Ladan wrote:
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
either (it
<br>
exception
<br>
<br>
<br>
hit unless there is a bug in the debugger, which seems unlikely. Does
you debugger work at all? I.e., can you get it to stop anywhere in any
of the EMF code?
<br>
<br>
</blockquote>
<br>
IDE stops.
<br>
<br>
Rene Ladan wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
unused.
<br>
called.
<br>
the
<br>
(running
<br>
in debug view).
<br>
<br>
Rene Ladan wrote:
<br>
<br>
<br>
save?
<br>
which
<br>
<br>
<br>
</blockquote>
foreign
<br>
<br>
element Root
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
..... 42 more
<br>
<br>
<br>
<br>
Any ideas?
<br>
<br>
<br>
Rene
<br>
w
<br>
<br>
<br>
<br>
<br>
<br>
<br>
new Boolean(true));
<br>
<br>
<br>
Thanks much,
<br>
Chris
<br>
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
<br>
is
<br>
just
<br>
<br>
ignored.
<br>
<br>
the
<br>
<br>
<br>
<br>
<br>
Chris Giblin wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Overview.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<library:Library
<br>
<br>
<br>
<br>
</m:foo>
<br>
<br>
<br>
author="/1"/>
<br>
</library:Library>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
chris
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------010003070401000107040406--
Ed Merks
Re: Q: Loading XMLResources containing non-modeled namespaces? [message #415934 is a reply to message #415931] |
Fri, 11 January 2008 16:24 |
Member |
Ed Merks wrote:
> Rene,
> Comments below.
> Rene Ladan wrote:
>> Ed Merks wrote:
>>> Rene,
>> having
>> uriString == "XML"
>> return null
>> to add
>> causing
> the option:
I am, but possibly not at all the required places:
MetaEditor.java:
protected void handleChangedResources() {
EMap<String,String> m;
if (!changedResources.isEmpty() && (!isDirty() || handleDirtyConflict())) {
editingDomain.getCommandStack().flush();
updateProblemIndication = false;
for (Resource resource : changedResources) {
if (resource.isLoaded()) {
resource.unload();
try {
options.put(XMLResource.OPTION_RECORD_UNKNOWN_FEATURE, Boolean.TRUE);
>> EMF Editor.
>> extension)
>> action on a partial
>> "XML", the
It does, but indeed not in the above situation when using a user-generated
editor.
>> worth the
>> trouble...
>>> Rene Ladan wrote:
>>>> Ed Merks wrote:
>>>>> Rene,
>>>> either (it
>>>> an exception
>>>> IDE stops.
>>>>> Rene Ladan wrote:
>>>>>> Ed Merks wrote:
>>>>>>> Rene,
>>>>>> unused.
>>>>>> not called.
>>>>>> at the
>>>>>> (running
>>>>>> in debug view).
>>>>>>>>> upon save?
>>>>>>>>> model upon which
>>>>>>>> having foreign
>>>>>>>> element Root
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> Source)
>>>>>>>> at
>>>>>>>> Source)
>>>>>>>> at
>>>>>>>> Source)
>>>>>>>> at
>>>>>>>> Source)
>>>>>>>> at
>>>>>>>> Source)
>>>>>>>> at
>>>>>>>> Source)
>>>>>>>> at
>>>>>>>> Source)
>>>>>>>> at
>>>>>>>> Source)
>>>>>>>> at
>>>>>>>> Source)
>>>>>>>> at
>>>>>>>> Source)
>>>>>>>> at
>>>>>>>> Source)
>>>>>>>> at
>>>>>>>> Source)
>>>>>>>> at
>>>>>>>> Source)
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> .... 42 more
>>>>>>>> Any ideas?
>>>>>>>> Thanks,
>>>>>>>> Rene
>>>>>>>> w
>>>>>>>>> Chris Giblin wrote:
>>>>>>>>>> Ed,
>>>>>>>>>> new Boolean(true));
>>>>>>>>>> Thanks much,
>>>>>>>>>> Chris
>>>>>>>>>> Ed Merks wrote:
>>>>>>>>>>> Chris,
>>>>>>>>>>> document is
>>>>>>>>>>> want if you just
>>>>>>>>>>> allow such
>>>>>>>>>>> to be ignored.
>>>>>>>>>>> enabled, all the
>>>>>>>>>>> and no
>>>>>>>>>>> Chris Giblin wrote:
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> storage in
>>>>>>>>>>>> namespaces which
>>>>>>>>>>>> EMF Overview.
>>>>>>>>>>>> persist it using
>>>>>>>>>>>> instantiate the
>>>>>>>>>>>> namespace, foo:
>>>>>>>>>>>> <library:Library
>>>>>>>>>>>> </m:foo>
>>>>>>>>>>>> author="/1"/>
>>>>>>>>>>>> </library:Library>
>>>>>>>>>>>> 'foo' not
>>>>>>>>>>>> and I still
>>>>>>>>>>>> Thanks,
>>>>>>>>>>>> chris
>>>>>>>>>>>> resource.load(new
Re: Q: Loading XMLResources containing non-modeled namespaces? [message #415936 is a reply to message #415934] |
Fri, 11 January 2008 16:35 |
Rene,
Comments below.
Rene Ladan wrote:
> Ed Merks wrote:
>> Rene,
>> Comments below.
>> Rene Ladan wrote:
>>> Ed Merks wrote:
>>>> Rene,
>>> namespace having
>>> uriString == "XML"
>>> return null
>>> trying to add
>>> because, causing
>> the option:
> MetaEditor.java:
You can put an option in the resource set (resourceSet.getLoadOptions())
and then they will all be used. You can also specialize the generated
resource factory impl so that you always set this option when you create
the resource.
> resource.unload();
> try {
>>> Sample EMF Editor.
>>> extension)
>>> action on a partial
>>> is "XML", the
> user-generated
> editor.
>>> really worth the
>>> trouble...
>>>> Rene Ladan wrote:
>>>>> Ed Merks wrote:
>>>>>> Rene,
>>>>> help either (it
>>>>> an exception
>>>>>> bug in the debugger, which seems unlikely. Does you debugger
>>>>>> work at all? I.e., can you get it to stop anywhere in any of the
>>>>>> EMF code?
>>>>> which the
>>>>> IDE stops.
>>>>>> Rene Ladan wrote:
>>>>>>> Ed Merks wrote:
>>>>>>>> Rene,
>>>>>>>> it doesn't return a demand created package for your URI:
>>>>>>> otherwise unused.
>>>>>>> not called.
>>>>>>> and at the
>>>>>>> over (running
>>>>>>> in debug view).
>>>>>>>>>> model upon which
>>>>>>>>> having foreign
>>>>>>>>> The element Root
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> Source)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> Source)
>>>>>>>>> at
>>>>>>>>> Source)
>>>>>>>>> at
>>>>>>>>> Source)
>>>>>>>>> at
>>>>>>>>> Source)
>>>>>>>>> at
>>>>>>>>> Source)
>>>>>>>>> at
>>>>>>>>> Source)
>>>>>>>>> at
>>>>>>>>> Source)
>>>>>>>>> at
>>>>>>>>> Source)
>>>>>>>>> at
>>>>>>>>> Source)
>>>>>>>>> at
>>>>>>>>> Source)
>>>>>>>>> at
>>>>>>>>> Source)
>>>>>>>>> at
>>>>>>>>> Source)
>>>>>>>>> at
>>>>>>>>> Source)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> .... 42 more
>>>>>>>>> Any ideas?
>>>>>>>>> Thanks,
>>>>>>>>> Rene
>>>>>>>>> w
>>>>>>>>>> Chris Giblin wrote:
>>>>>>>>>>> Ed,
>>>>>>>>>>> new Boolean(true));
>>>>>>>>>>> Thanks much,
>>>>>>>>>>> Chris
>>>>>>>>>>> Ed Merks wrote:
>>>>>>>>>>>> Chris,
>>>>>>>>>>>> whole document is
>>>>>>>>>>>> want if you just
>>>>>>>>>>>> to allow such
>>>>>>>>>>>> to be ignored.
>>>>>>>>>>>> enabled, all the
>>>>>>>>>>>> Chris Giblin wrote:
>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>> namespaces which
>>>>>>>>>>>>> EMF Overview.
>>>>>>>>>>>>> persist it using
>>>>>>>>>>>>> instantiate the
>>>>>>>>>>>>> namespace, foo:
>>>>>>>>>>>>> <library:Library
>>>>>>>>>>>>> </m:foo>
>>>>>>>>>>>>> author="/1"/>
>>>>>>>>>>>>> </library:Library>
>>>>>>>>>>>>> Feature 'foo' not
>>>>>>>>>>>>> and I still
>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>> chris
>>>>>>>>>>>>> resource.load(new
Ed Merks
Current Time: Sat Apr 20 02:08:50 GMT 2024
Powered by FUDForum. Page generated in 0.04856 seconds
