Re: Birt 2.5 Batch Problem: What is rp_issue? [message #444132 is a reply to message #369045] |
Fri, 31 July 2009 16:35 |
rp_issue must be a parameter you have in the report.
add
-p "rp_issue=value"
Jason
steve shiflett wrote:
> I used the sample genReport.bat file to run my report in batch. It
> complains that I haven't something called rp_issue. What is it - or
> where do I find out? I have been looking for documentation but after
> several hours - I cannot find anything. Can anyone help?
> The arguments I pass on:
> C:\Tomcat-5.5.27\Tomcat 5.5\webapps\birt-viewer>genReport -m runrender
> -f HTML -o steve.html "C:\Tomcat-5.5.27\Tomcat
> 5.5\webapps\birt-viewer\report\jira\resolution_by_component. rptdesign "
> The output are as follows:
> C:\Tomcat-5.5.27\Tomcat 5.5\webapps\birt-viewer>ECHO off
> Jul 21, 2009 2:54:01 PM org.eclipse.birt.report.engine.api.ReportRunner
> runAndRenderRepo
> SEVERE: Required parameter rp_issue is not set.
> org.eclipse.birt.report.engine.api.impl.ParameterValidationE xception:
> Required parameter ...
> etc.
FUDForum. Page generated in 0.03071 seconds
