Re: row minimum height in ppt [message #368882 is a reply to message #368856] |
Thu, 02 July 2009 14:33 |
Originally posted by: jasonweathersby.windstream.net
Tero,
Can you post a report that uses the sample db that shows the issue?
Jason
tero wrote:
> Hello,
> I am downloading a report as ppt and when trying to set the height of a
> row, I see a difference in the viewer but when downloading as ppt (a
> must for this report) there is no change (when crossing a minimum down).
> I need it to be as small as as possible and I see a lot of space between
> the containt and the top and bottom border. I reduced the padding of the
> row and the containt and I see a change in the viewer but not in the ppt.
> Any ideas?
> Tero
Re: row minimum height in ppt [message #368909 is a reply to message #368898] |
Mon, 06 July 2009 14:02 |
Tero,
Just select the xml view and paste it in the reply.
Jason
tero wrote:
> Hello Jason,
> Do you have a place where I could upload it?
> Thanks + regards,
> Gerardo
> Jason Weathersby wrote:
>> Tero,
>> Thanks
>> Jason
>> tero wrote:
>>> Hello,
>>> a row, I see a difference in the viewer but when downloading as ppt
>>> (a must for this report) there is no change (when crossing a minimum
>>> down).
>>> between the containt and the top and bottom border. I reduced the
>>> padding of the row and the containt and I see a change in the viewer
>>> but not in the ppt.
>>> Any ideas?
>>> Thanks,
>>> Tero
FUDForum. Page generated in 0.02727 seconds
