Unable to restart standalone BIRT engine in JUnit test code [message #368818] |
Mon, 29 June 2009 10:16 |
Originally posted by: csaba.szucs.continental-corporation.com
Hello Guys,
In my JUnit tests I start and shutdown BIRT standalone engine again and
again within each test method.
I shut down standalone BIRT engine this way, I am not sure if it is
correct or not:
engine.destroy();
Platform.shutdown();
But during the first try to restart BIRT engine I get the following
exceptions:
Could you tell me what the problem is, thanks a lot!
Csaba
Exception in thread "main" java.lang.ExceptionInInitializerError
org.eclipse.birt.report.engine.api.impl.ReportEngineFactory$ 1.run(ReportEngineFactory.java:18)
org.eclipse.birt.report.engine.api.impl.ReportEngineFactory$ 1.run(ReportEngineFactory.java:1)
org.eclipse.birt.report.engine.api.impl.ReportEngineFactory. createReportEngine(ReportEngineFactory.java:14)
com.continental.plm.reportmanager.ReportEngineHandler.create EngineForStandaloneJavaPlatform(ReportEngineHandler.java:29)
com.continental.plm.reportmanager.ReportToolbox.getReportEng ineForStandaloneJavaPlatform(ReportToolbox.java:47)
com.continental.plm.reportmanager.ReportManager.<init>(ReportManager.java:40)
com.continental.plm.reportmanager.ReportManager.main(ReportM anager.java:231)
Caused by: java.lang.IllegalStateException
org.mozilla.javascript.ContextFactory.initGlobal(ContextFact ory.java:207)
org.eclipse.birt.report.engine.api.impl.ReportEngine.<clinit >(ReportEngine.java:221)
... 8 more
Some help for investigating the exception trace:
public static IReportEngine createEngineForStandaloneJavaPlatform(final
String birtHome) throws Exception {
EngineConfig config = new EngineConfig();
config.setEngineHome(birtHome);
Platform.startup(config);
IReportEngineFactory factory = (IReportEngineFactory) Platform
.createFactoryObject(IReportEngineFactory.EXTENSION_REPORT_E NGINE_FACTORY);
return factory.createReportEngine(config);
So the problem is at the last statement of my above method
(ReportEngineHandler.java:29).
Re: Unable to restart standalone BIRT engine in JUnit test code [message #368822 is a reply to message #368818] |
Mon, 29 June 2009 14:18 |
Originally posted by: jasonweathersby.windstream.net
Csaba,
Can you log a bug for this? Post the bugzilla id here.
Jason
Csaba wrote:
> Hello Guys,
> correct or not:
> engine.destroy();
> exceptions:
> Csaba
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> ... 8 more
> createEngineForStandaloneJavaPlatform(final String birtHome) throws
> Exception {
FUDForum. Page generated in 0.03276 seconds
