Re: PDF Drill Through link to open in a new window? [message #368790 is a reply to message #368773] |
Thu, 25 June 2009 16:42 |
Originally posted by: jasonweathersby.windstream.net
Mike,
The target new window should work for PDF. You can also specify that
the target be in PDF. Not sure how you are running the report but try
it with the viewer. Export the master to pdf and then click on the link.
Jason
mike wrote:
> Hi Everyone or Jason
> Right now I a PDF that drill through to another PDF. Is it possible to
> set PDF Drill Through link to open in a new window? similiar to setting
> target attribute for HTML.
> Thanks
> mike
Re: PDF Drill Through link to open in a new window? [message #368811 is a reply to message #368807] |
Fri, 26 June 2009 15:51 |
Mike,
What code are you using to do this?
Jason
mike wrote:
> Hi Jason
> i'm opening the PDF within a iframe, and the drill through PDF also open
> inside the iframe but not a new window.. is there a way to set it
> programatically to open in a new window?
> Thanks
> mike
FUDForum. Page generated in 0.04848 seconds
