Home » Archived » BIRT » Re: Eclipse bug?
Re: Eclipse bug? [message #368748] Wed, 24 June 2009 04:24 Go to next message
mlt wrote:
> I have installed:
> eclipse
> Version: 3.4.2
> Build id: M20090211-1700
> on vista 64. I have installed the latest version of BIRT. When I create
> a report and try to edit the data source (double click the added data
> source) I get the error:
Note: I've copied this reply to the eclipse.birt newsgroup.
Are you certain that "the latest version of BIRT" does not require
Eclipse 3.5? It should not even install or run in 3.4 if it does require
3.5, but it's possible that is the source of your problem.
What version of BIRT did you install? How did you install it, via the
Software Updates GUI or by some other (manual) means?
Hope this helps,
Eric
> An error has occurred. See error log for more details.
> org.eclipse.datatools.connectivity.oda.design.ui.designsessi on.DataSourceDesignSession.setAndVerifyUseProfileSelectionPa ge()Z
> I have looked in the error log under the Plug-in Development perspective
> where I get the following info:
> Problems occurred when invoking code from plug-in: "org.eclipse.jface".
> java.lang.NoSuchMethodError:
> at
> org.eclipse.birt.report.designer.data.ui.datasource.DataSour ceEditor.addCustomPageODAV3(DataSourceEditor.java:122)
> at
> org.eclipse.birt.report.designer.data.ui.datasource.DataSour ceEditor. <init>(DataSourceEditor.java:78)
> at
> org.eclipse.birt.report.designer.internal.ui.views.data.prov iders.DataSourceNodeProvider.performEdit(DataSourceNodeProvi der.java:84)
> at
> org.eclipse.birt.report.designer.internal.ui.views.DefaultNo deProvider.performRequest(DefaultNodeProvider.java:410)
> at
> org.eclipse.birt.report.designer.internal.ui.views.actions.E ditAction.doAction(EditAction.java:85)
> at
> org.eclipse.birt.report.designer.internal.ui.views.actions.A bstractElementAction.run(AbstractElementAction.java:66)
> at
> org.eclipse.birt.report.designer.internal.ui.views.RenameLis tener.doubleClick(RenameListener.java:214)
> at
> org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredV iewer.java:799)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
> at org.eclipse.core.runtime.Platform.run(Platform.java:880)
> at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
> at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
> at
> org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(S tructuredViewer.java:797)
> at
> org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSel ect(AbstractTreeViewer.java:1419)
> at
> org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSe lected(StructuredViewer.java:1173)
> at
> org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEven t(OpenStrategy.java:237)
> at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.ja va:234)
> at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:295)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2384)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2348)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 00)
> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:495)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:490)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
> Any idea on how to solve this problem without reinstalling eclipse?
Re: Eclipse bug? [message #368749 is a reply to message #368748] Wed, 24 June 2009 09:11 Go to previous messageGo to next message
Originally posted by: asddd.asd.com
Manually installing DTP Enablement1.6.2 solved the problem. When
automatically updating a plugin should its dependencies not get updated
too?
"Eric Rizzo" <eclipse-news@rizzoweb.com> wrote in message
news:h1s9q5$d54$2@build.eclipse.org...
> mlt wrote:
>> I have installed:
>> eclipse
>> Version: 3.4.2
>> on vista 64. I have installed the latest version of BIRT. When I create a
> Are you certain that "the latest version of BIRT" does not require Eclipse
> 3.5? It should not even install or run in 3.4 if it does require 3.5, but
> Hope this helps,
> Eric
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
Re: Eclipse bug? [message #368759 is a reply to message #368749] Wed, 24 June 2009 14:59 Go to previous messageGo to next message
> too?
Yes, they should. If you don't get a response soon from the BIRT gurus,
I'd recommend entering a bug against BIRT with detailed steps to
reproduce. It is possible that some BIRT plug-in or feature is not
specifying its dependency versions correctly in the update site.
Eric
>> mlt wrote:
>>> I have installed:
>>> eclipse
>>> Version: 3.4.2
>>> create a report and try to edit the data source (double click the
>>> added data source) I get the error:
>> require 3.5, but it's possible that is the source of your problem.
>> Hope this helps,
>> Eric
>>> perspective where I get the following info:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Re: Eclipse bug? [message #368838 is a reply to message #368749] Tue, 30 June 2009 10:05 Go to previous message
Xiaoying Gu is currently offline Xiaoying GuFriend
Member
> too?
No, it won't. If you choose to search the updates of BIRT project, only
the updates of BIRT itself will be installed.
But this is still a BIRT 2.3 bug that the minimal version of datatools
is not correct in the feature defination. With the correct feature
defination, warnings or errors could be given when the dependecy is not
satisfied.
Xiaoying
Previous Topic:JavaDoc
Next Topic:Web Viewer Servlet Source
Current Time: Tue Apr 16 12:37:13 GMT 2024
Powered by FUDForum. Page generated in 0.12521 seconds
