Home » Archived » BIRT » Chart Grouping problem BIRT 2.3
Re: Chart Grouping problem BIRT 2.3 [message #368770 is a reply to message #368745] |
Wed, 24 June 2009 16:10 |
Originally posted by: jasonweathersby.windstream.net
Mehrab,
Does RID exist in the binding? That is the query you are using. Did
you create the row[RID]_Sum binding? I also assume this column does not
exist in the dataset:
dataSetRow["row[RID]_Sum"]
Jason
Mehrab wrote:
> Hi All,
> I upgrade my application form BIRT 2.1 to 2.3. In the application I use
> DE api to create chart. The code working fine on BIRT 2.1 but generate
> error in BIRT 2.3. Basically it generate error when grouping on base
> category and without grouping its working fine. Please anybody help me.
> My sample code, some part of .rptdesign file and error as follows:
> sample Code
> private Chart createLineChart(LineChartDTO lineChartDTO){
> ChartWithAxes cwaLine = ChartWithAxesImpl.create( );
> //get the primary base x axis
> Axis xAxisPrimary = cwaLine.getPrimaryBaseAxes( )[0];
> //y axis as the orthogonal axis
> Axis yAxisPrimary = cwaLine.getPrimaryOrthogonalAxis(
> xAxisPrimary );
> //create base category
> Series seCategory = SeriesImpl.create( );
> Query query = QueryImpl.create("row[\"CREATOR\"]");
> seCategory.getDataDefinition( ).add( query );
> //create series definition for the x axis or the base axis
> SeriesDefinition sdX = SeriesDefinitionImpl.create( );
> sdX.getSeries( ).add( seCategory );
> //Grouping
> sdX.getGrouping().setEnabled(true);
> sdX.getGrouping().setGroupingInterval(0);
> sdX.getGrouping().setGroupType(DataType.DATE_TIME_LITERAL);
> sdX.getGrouping().setAggregateExpression("Sum");
> xAxisPrimary.getSeriesDefinitions( ).add( sdX );
> LineSeries ls = (LineSeries) LineSeriesImpl.create();
> ls.getLabel().setVisible(true);
> Query query2 = QueryImpl.create("row[\"RID\"]");
> ls.getDataDefinition( ).add( query2 );
> sdY = SeriesDefinitionImpl.create();
> sdY.getSeriesPalette().shift(0);
> sdY.getSeries( ).add(ls);
> yAxisPrimary.getSeriesDefinitions( ).add( sdY );
> return cwaLine;
> <oda-data-set
> extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
> name="Main_Data_Set" id="102">
> <property name="dataSource">Data Source</property>
> <property name="queryText"> SELECT
> SIMS.ROLES."CREATOR",SIMS.ROLES."RID" FROM SIMS.ROLES </property>
> </oda-data-set>
> <property name="outputFormat">GIF</property>
> <property name="dataSet">Main_Data_Set</property>
> <property name="height">400px</property>
> <property name="width">500px</property>
> <list-property name="boundDataColumns">
> <structure>
> <property name="name">CREATOR</property>
> <expression name="expression">dataSetRow["CREATOR"]</expression>
> </structure>
> <structure>
> <property name="name">row[RID]_Sum</property>
> <expression name="expression">dataSetRow["row[RID]_Sum"]</expression >
> </structure>
> Error
> Jun 23, 2009 6:05:12 PM
> org.eclipse.birt.report.engine.executor.ExtendedGenerateExec utor execute
> SEVERE: Column binding "row[RID]_Sum" has referred to a data set column
> "row[RID]_Sum" which does not exist.
> org.eclipse.birt.data.engine.core.DataException: Column binding
> "row[RID]_Sum" has referred to a data set column "row[RID]_Sum" which
> does not exist.
> at
> org.eclipse.birt.data.engine.impl.ResultIterator.validateMan ualBindingExpressions(ResultIterator.java:311)
> at
> org.eclipse.birt.data.engine.impl.ResultIterator.<init>(ResultIterator.java:148)
> at
> org.eclipse.birt.data.engine.impl.QueryResults.getResultIter ator(QueryResults.java:176)
> at
> org.eclipse.birt.report.engine.data.dte.QueryResultSet.<init >(QueryResultSet.java:92)
> at
> org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExec uteQuery(DteDataEngine.java:129)
> at
> org.eclipse.birt.report.engine.data.dte.DataGenerationEngine .doExecuteQuery(DataGenerationEngine.java:79)
> at
> org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.e xecute(AbstractDataEngine.java:253)
> at
> org.eclipse.birt.report.engine.executor.ExtendedGenerateExec utor.executeQueries(ExtendedGenerateExecutor.java:204)
> at
> org.eclipse.birt.report.engine.executor.ExtendedGenerateExec utor.execute(ExtendedGenerateExecutor.java:65)
> at
> org.eclipse.birt.report.engine.executor.ExtendedItemExecutor .execute(ExtendedItemExecutor.java:61)
> at
> org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe dReportItemExecutor.execute(WrappedReportItemExecutor.java:4 5)
> at
> org.eclipse.birt.report.engine.internal.executor.emitter.Rep ortItemEmitterExecutor.execute(ReportItemEmitterExecutor.jav a:45)
> at
> org.eclipse.birt.report.engine.internal.executor.dup.Suppres sDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor .java:42)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutNodes(HTMLBlockStackingLM.java:63)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.la youtChildren(HTMLStackingLM.java:27)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.la yout(HTMLAbstractLM.java:133)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLInlineStackin gLM.resumeLayout(HTMLInlineStackingLM.java:104)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLInlineStackin gLM.layoutNodes(HTMLInlineStackingLM.java:153)
> at
> at
> at
> org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutNodes(HTMLBlockStackingLM.java:68)
> at
> at
> org.eclipse.birt.report.engine.layout.html.HTMLTableLM.layou tChildren(HTMLTableLM.java:76)
> at
> at
> at
> org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:90)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:101)
> at
> org.eclipse.birt.report.engine.presentation.ReportDocumentBu ilder.build(ReportDocumentBuilder.java:211)
> at
> org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTas k.java:237)
> at org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask. java:90)
> at
> com.anabase.art.reportviewer.ViewerServlet.generateRptDocFil e(ViewerServlet.java:535)
> at
> com.anabase.art.reportviewer.ViewerServlet.getRptDocFile(Vie werServlet.java:334)
> at
> com.anabase.art.reportviewer.ViewerServlet.viewReport(Viewer Servlet.java:194)
> at
> com.anabase.art.reportviewer.ViewerServlet.execute(ViewerSer vlet.java:420)
> at
> com.anabase.art.reportviewer.ViewerServlet.doPost(ViewerServ let.java:109)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
> at
> org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:290)
> at
> org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:206)
> at
> org.springframework.security.util.FilterChainProxy$VirtualFi lterChain.doFilter(FilterChainProxy.java:378)
> at
> org.springframework.security.intercept.web.FilterSecurityInt erceptor.invoke(FilterSecurityInterceptor.java:109)
> at
> org.springframework.security.intercept.web.FilterSecurityInt erceptor.doFilter(FilterSecurityInterceptor.java:83)
> at
> org.springframework.security.util.FilterChainProxy$VirtualFi lterChain.doFilter(FilterChainProxy.java:390)
> at
> org.springframework.security.ui.SessionFixationProtectionFil ter.doFilterHttp(SessionFixationProtectionFilter.java:67)
> at
> org.springframework.security.ui.SpringSecurityFilter.doFilte r(SpringSecurityFilter.java:53)
> at
> at
> org.springframework.security.ui.ExceptionTranslationFilter.d oFilterHttp(ExceptionTranslationFilter.java:101)
> at
> at
> at
> org.springframework.security.providers.anonymous.AnonymousPr ocessingFilter.doFilterHttp(AnonymousProcessingFilter.java:1 05)
> at
> at
> at
> org.springframework.security.ui.rememberme.RememberMeProcess ingFilter.doFilterHttp(RememberMeProcessingFilter.java:116)
> at
> at
> at
> org.springframework.security.wrapper.SecurityContextHolderAw areRequestFilter.doFilterHttp(SecurityContextHolderAwareRequ estFilter.java:91)
> at
> at
> at
> org.springframework.security.ui.basicauth.BasicProcessingFil ter.doFilterHttp(BasicProcessingFilter.java:174)
> at
> at
> at
> org.springframework.security.ui.AbstractProcessingFilter.doF ilterHttp(AbstractProcessingFilter.java:277)
> at
> at
> at
> at
> at
> at
> org.springframework.security.ui.logout.LogoutFilter.doFilter Http(LogoutFilter.java:89)
> at
> at
> at
> org.springframework.security.context.HttpSessionContextInteg rationFilter.doFilterHttp(HttpSessionContextIntegrationFilte r.java:235)
> at
> at
> at
> org.springframework.security.util.FilterChainProxy.doFilter( FilterChainProxy.java:175)
> at
> org.springframework.web.filter.DelegatingFilterProxy.invokeD elegate(DelegatingFilterProxy.java:236)
> at
> org.springframework.web.filter.DelegatingFilterProxy.doFilte r(DelegatingFilterProxy.java:167)
> at
> org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:235)
> at
> at
> org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:233)
> at
> org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:191)
> at
> org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:128)
> at
> org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:102)
> at
> org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:109)
> at
> org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:286)
> at
> org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:845)
> at
> org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.process(Http11Protocol.java:583)
> at
> org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoin t.java:447)
> at java.lang.Thread.run(Unknown Source)
Re: Chart Grouping problem BIRT 2.3 [message #368780 is a reply to message #368770] |
Thu, 25 June 2009 04:29 |
Mehrab Messages: 14 Registered: July 2009 |
Junior Member |
Jason,
RID column exist in the dataset. When I create a report without x axis
grouping, it's create following tag in the .rptdesign file and display
report properly. Here RID column is y axis.
<structure>
<property name="name">RID</property>
<expression name="expression">dataSetRow["RID"]</expression>
</structure>
But when I create report with x axis grouping, it's create following tag
in the .rptdesign file and report throw exception. row[RID]_Sum is not
available in the dataset.
<structure>
</structure>
Please help me. My java code and and .rptdesign file is is as follows:
////////////////////////////// Java code /////////////////////////////
private Chart createLineChart(LineChartDTO lineChartDTO) throws
ARTChartEngineException {
if(lineChartDTO.getDimension().equals(ARTProperties.DIMENSIO N_2D)){
cwaLine.setDimension( ChartDimension.TWO_DIMENSIONAL_LITERAL
else
if(lineChartDTO.getDimension().equals(ARTProperties.DIMENSIO N_3D)){
cwaLine.setDimension( ChartDimension.THREE_DIMENSIONAL_LITERAL
else
if(lineChartDTO.getDimension().equals(ARTProperties.DIMENSIO N_2D_DEPTH)){
* hence there BIRT dont support for Date time data in the
* y axis for three dimension chart. problem is rendering the 3d
chart
* in the BIRT engine
if( lineChartDTO.getYAxisType()== AxisType.DATE_TIME_LITERAL
&& cwaLine.getDimension() ==
ChartDimension.THREE_DIMENSIONAL_LITERAL ){
// throw new ARTChartEngineException("3d chart doesnt support
Date/time value in the series");
cwaLine.setDimension( ChartDimension.TWO_DIMENSIONAL_LITERAL );
cwaLine.setType( CHART_LINE );
cwaLine.setSubType( "Overlay" );
cwaLine.getTitle( ).setVisible( true );
cwaLine.getLegend( ).setVisible( true );
cwaLine.setOrientation( Orientation.VERTICAL_LITERAL );
cwaLine.getPlot( ).getClientArea( ).getOutline( ).setVisible( true
cwaLine.getPlot( ).getClientArea( ).setBackground(
ColorDefinitionImpl.create( 254, 251, 233 ) );
cwaLine.getLegend().setVisible(lineChartDTO.isHistoryVisible );
cwaLine.getTitle( ).getLabel().getCaption().getFont().setSize(10);
cwaLine.getTitle(
).getLabel().getCaption().getFont().setBold(true);
cwaLine.getBlock().getBounds().setHeight(300);
cwaLine.getBlock().getBounds().setWidth(600);
cwaLine.getTitle().getLabel().getCaption().setValue(lineChar tDTO.getTilte());
//PLOT
Plot plotArea = cwaLine.getPlot();
plotArea.getOutline().setVisible(true);
//##############LEGEND##############//
//set the legend or history of the pie
Legend legend = cwaLine.getLegend( );
this.setLegend(legend,lineChartDTO.isHistoryVisible());
xAxisPrimary.getLabel().getCaption().getFont().setSize(7);
xAxisPrimary.getLabel().getCaption().getFont().setName(this. getFontName());
xAxisPrimary.getTitle( ).getCaption( ).getFont().setSize(8);
).getFont().setName(this.getFontName());
xAxisPrimary.getTitle().setVisible(true);
xAxisPrimary.getTitle( ).getCaption().getFont().setBold(false);
createRotateText(xAxisPrimary,lineChartDTO.getRotation());
//make the x axis as category
xAxisPrimary.setCategoryAxis( true );
xAxisPrimary.getTitle( ).getCaption( ).setValue(
lineChartDTO.getXAxisTitle() );
if(lineChartDTO.getXAxisType()!= null &&
lineChartDTO.getXAxisType() == AxisType.DATE_TIME_LITERAL){
log.debug("createBarChart(): x axis type is : date" );
xAxisPrimary.setType( AxisType.DATE_TIME_LITERAL );
xAxisPrimary.setFormatSpecifier(
JavaDateFormatSpecifierImpl.create( "dd/MMM/yyyy" ) );
else if(lineChartDTO.getXAxisType()!= null &&
lineChartDTO.getXAxisType() == AxisType.TEXT_LITERAL){
log.debug("createBarChart(): x axis type is : text" );
xAxisPrimary.setType( AxisType.TEXT_LITERAL );
lineChartDTO.getXAxisType() == AxisType.LINEAR_LITERAL){
log.debug("createBarChart(): x axis type is : linear" );
xAxisPrimary.setType( AxisType.LINEAR_LITERAL );
lineChartDTO.getXAxisType() == AxisType.LOGARITHMIC_LITERAL){
log.debug("createBarChart(): x axis type is : logger" );
xAxisPrimary.setType( AxisType.LOGARITHMIC_LITERAL );
//show the horizontal x grid at background of chart
Axis yAxisPrimary = cwaLine.getPrimaryOrthogonalAxis( xAxisPrimary
yAxisPrimary.getLabel().getCaption().getFont().setSize(8);
yAxisPrimary.getLabel().getCaption().getFont().setName(this. getFontName());
yAxisPrimary.getTitle( ).getCaption( ).getFont().setSize(8);
yAxisPrimary.getTitle( ).getCaption( ).setValue(
lineChartDTO.getYAxisTitle() );
yAxisPrimary.getTitle( ).getCaption().getFont().setBold(false);
yAxisPrimary.getTitle().setVisible(true);
//show the vertical y grid at background of chart
if(lineChartDTO.getGridType().equals(ARTProperties.GRID_HORI ZONTAL)){
createHorizontalGrid(yAxisPrimary);
else
if(lineChartDTO.getGridType().equals(ARTProperties.GRID_VERT ICAL)){
createVerticalGrid(xAxisPrimary);
else
if(lineChartDTO.getGridType().equals(ARTProperties.GRID_BOTH )) {
else{
//do nothing
//since this is none type so no grid will apply
if(lineChartDTO.getYAxisType()!= null &&
lineChartDTO.getYAxisType() == AxisType.DATE_TIME_LITERAL){
log.debug("y axis is now : date" );
yAxisPrimary.setType( AxisType.DATE_TIME_LITERAL );
yAxisPrimary.setFormatSpecifier(
else if(lineChartDTO.getYAxisType()!= null &&
lineChartDTO.getYAxisType() == AxisType.LINEAR_LITERAL){
log.debug("y axis is now : linear" );
NumberFormatSpecifier formatSepecifier =
NumberFormatSpecifierImpl.create( );
formatSepecifier.setMultiplier(lineChartDTO.getYAxisMultipli erValue());
yAxisPrimary.setFormatSpecifier(formatSepecifier);
yAxisPrimary.setType(AxisType.LINEAR_LITERAL);
lineChartDTO.getYAxisType() == AxisType.LOGARITHMIC_LITERAL){
log.debug("y axis is now : logger" );
yAxisPrimary.setType(AxisType.LOGARITHMIC_LITERAL);
else{
log.debug(lineChartDTO.getYAxisType() + ": is not supported ");
lineChartDTO.getCategoryDefinition() );
if(lineChartDTO.getXAxisSorting() != null ){
if(lineChartDTO.getXAxisSorting().equalsIgnoreCase("ASCENDING ") ){
sdX.setSorting(SortOption.ASCENDING_LITERAL);
else{
sdX.setSorting(SortOption.DESCENDING_LITERAL);
if(lineChartDTO.isGroupOnCategory()){
//if hte y axis is data type then no group will apply
if(lineChartDTO.getYAxisType() == AxisType.DATE_TIME_LITERAL){
//do not grouping
log.debug("y axis is date type , so no group will apply");
else{
* here we have three types of data Text,Linear,Date
* there will be different value for groupin
interval.accoding BIRT-2.1.0
* there is now understandable clear document about the
definition of
* grouping interval.but using trial and error process we
recover the following
* value for correct goruping
* TEXT = 0
* DATE/TIME = 1
* NUMBER = 1
sdX.getGrouping().setEnabled(lineChartDTO.isGroupOnCategory( ));
// set the text type group interval
if(lineChartDTO.getYAxisType() == AxisType.TEXT_LITERAL){
//Date and Number type is same group interval
else {
sdX.getGrouping().setGroupingInterval(1);
if(lineChartDTO.getXAxisType() ==
createCategoryGroupUnit(lineChartDTO,sdX);
||lineChartDTO.getDimension().equals(ARTProperties.DIMENSION _2D_DEPTH)){
createZAxis(xAxisPrimary);
cwaLine.setRotation( Rotation3DImpl.create( new Angle3D[]{
Angle3DImpl.create( -20, 45, 0 )
//create multiple line series
createMultipleLineSeries(yAxisPrimary,lineChartDTO);
return cwaLine;
* create multiple series on line chart
* @param yAxisPrimary as the base axis
* @param lineChartDTO , chart data object
private void createMultipleLineSeries(Axis yAxisPrimary,
Map<String,String> yseriesValueMap =
lineChartDTO.getYSeriesValuesMap();
//define blank series definition
SeriesDefinition sdY = null;
//value for the bar series color code
int count = -2;
int markerCount = 1;
Set<String> keySet = yseriesValueMap.keySet();
for(String key : keySet){
String exp = key;
String expName = yseriesValueMap.get(exp);
LineSeries ls = (LineSeries) LineSeriesImpl.create( );
ls.setSeriesIdentifier(expName);
ls.getLabel().setVisible( lineChartDTO.isShowSeriesValue() );
ls.getLabel().getCaption().getFont().setSize(9);
ls.getLabel().getCaption().getFont().setName(this.getFontNam e());
//ls.setLabelPosition( Position.OUTSIDE_LITERAL );
ls.getLabel().getCaption().getFont().setRotation(lineChartDT O.getSerriesRotation());
// ls.getLineAttributes().setColor(ColorDefinitionImpl.create(
154, 50, 102 ));
if(markerCount > 14){
log.debug("There is no available marker in the marker
list");
else{
ls.getMarker( ).setType(
getMarkerList().get(String.valueOf(markerCount)) );
154, 50, 102 ));
// ls.setMarker(MarkerImpl.create(MarkerType.BOX_LITERAL,1));
Query query2 = QueryImpl.create( exp );
sdY = SeriesDefinitionImpl.create( );
sdY.getSeriesPalette( ).update( count );
sdY.getSeries( ).add( ls );
count = count - 1;
markerCount = markerCount + 1;
///////////////////////////// .rptdesign ////////////////////////////
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.17"
id="1">
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="101">
<property
name="odaDriverClass">oracle.jdbc.driver.OracleDriver</property >
<property
name="odaURL">jdbc:oracle:thin:@192.168.174.25:1521:BDEV</property >
<property name="odaUser">mferdous</property>
<encrypted-property name="odaPassword"
encryptionID="base64">YW5hYmFzZQ==</encrypted-property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
</oda-data-set>
</data-sets>
<styles>
<style name="crosstab-cell" id="2">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="3">
</style>
<style name="Report_Title_Style" id="4">
<property name="backgroundColor">#A9B2FD</property>
<property name="fontFamily">"Arial"</property>
<property name="fontSize">12px</property>
<property name="fontWeight">bold</property>
</style>
<style name="Tpo_Label" id="5">
<property name="fontFamily">"Verdana"</property>
<property name="color">#FF0000</property>
</style>
<style name="App_Name" id="6">
<property name="fontSize">small</property>
<property name="color">#4F687A</property>
</style>
<style name="Parameters" id="7">
<property name="fontSize">11pt</property>
</style>
<style name="Date" id="8">
</style>
<style name="TH_Lebel" id="9">
<property name="color">#F7F7F7</property>
<property name="borderBottomColor">#F7F7F7</property>
<property name="borderRightColor">#D1D0D0</property>
<property name="borderRightWidth">0px</property>
</style>
<style name="Table_Data" id="10">
<property name="paddingTop">1pt</property>
<property name="paddingLeft">1pt</property>
<property name="paddingBottom">1pt</property>
<property name="paddingRight">1pt</property>
</style>
<style name="Statistical_Data" id="11">
<property name="borderBottomColor">#4F687A</property>
<property name="borderBottomWidth">thin</property>
<property name="borderTopColor">#4F687A</property>
<property name="borderTopWidth">thin</property>
<property name="textAlign">left</property>
</style>
<style name="GroupBy" id="12">
<property name="fontSize">x-small</property>
</style>
<style name="sub_table" id="13">
<property name="fontSize">smaller</property>
<property name="borderBottomColor">#000000</property>
<property name="borderTopColor">#000000</property>
<property name="textAlign">center</property>
</style>
<style name="Master_table" id="14">
</style>
<style name="SubReport_TH_Lebel" id="15">
</style>
<style name="SubReport_Title_Lebel" id="16">
</style>
<style name="Confidential" id="17">
<property name="textAlign">right</property>
</style>
<style name="copyright" id="18">
</style>
<style name="footerGridStyle" id="19">
</style>
<style name="pageNo" id="20">
</style>
<style name="background_color" id="21">
<property name="backgroundColor">#CFD3FF</property>
</style>
<style name="table_header" id="22">
<property name="backgroundColor">#4F687A</property>
</style>
<style name="title_and_logo" id="23">
<property name="fontSize">14px</property>
</style>
<style name="border_bottom" id="24">
</style>
<style name="border_top" id="25">
</style>
<style name="border_bottom_right" id="26">
<property name="borderRightColor">#000000</property>
<property name="borderRightWidth">thin</property>
</style>
<style name="border_right" id="27">
</style>
<style name="fcount_table" id="28">
<property name="borderLeftColor">#000000</property>
<property name="borderLeftWidth">thin</property>
</style>
<style name="row_background_color" id="29">
<property name="backgroundColor">#FF8040</property>
</style>
<style name="report_title" id="30">
</style>
</styles>
<page-setup>
<simple-master-page name="Master Page" id="31">
<property name="type">a4</property>
<property name="orientation">landscape</property>
<property name="topMargin">0.25in</property>
<property name="leftMargin">0.5in</property>
<property name="bottomMargin">0.25in</property>
<property name="rightMargin">0.5in</property>
<page-header>
<grid name="Row_outerGrid_header" id="32">
<property name="width">100%</property>
<column id="33"/>
<row id="34">
<cell id="35">
<grid name="innerGrid_outerGrid" id="36">
<column id="37"/>
<row id="38">
<cell id="39">
<grid name="titleAndLogoGrid"
id="40">
<property
name="style">title_and_logo</property>
<property
<column id="41"/>
<column id="42"/>
<row id="43">
<cell id="44">
<grid
name="reportTitleGrid" id="45">
<property
<column id="46"/>
<row id="47">
<cell id="48">
<property
name="verticalAlign">middle</property>
<label
id="49">
<property name="style">App_Name</property>
<text-property name="text">SIMS/ART</text-property>
</label>
</cell>
</row>
<row id="50">
<cell id="51">
<property
<label
id="52">
<property name="style">report_title</property>
<text-property name="text">greport</text-property>
</label>
</cell>
</row>
</grid>
</cell>
<cell id="53">
<grid name="logoGrid"
id="54">
<property
<column id="55"/>
<row id="56">
<cell id="57">
<property
<property
<image
name="Organization Logo" id="58">
<property name="height">48px</property>
<property name="source">embed</property>
<property name="imageName">ORG_LOGO</property>
</image>
</cell>
</row>
</grid>
</cell>
</row>
<row id="59">
<cell id="60"/>
<cell id="61"/>
</row>
</grid>
</cell>
</row>
<row id="62">
<cell id="63">
<grid name="grid_5" id="64">
<property
<column id="65">
<property
name="width">80%</property>
</column>
<column id="66">
<property
name="width">20%</property>
</column>
<row id="67">
<cell id="68"/>
<cell id="69">
<grid name="dateGrid"
id="70">
<property
<column id="71"/>
<row id="72">
<cell id="73">
<property
<label
id="74">
<property name="style">Parameters</property>
<text-property name="text">Date as of </text-property>
</label>
</cell>
</row>
<row id="75">
<cell id="76">
<property
<text
name="Date1" id="77">
<property name="style">Date</property>
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new
Date()</value-of>]]></text-property>
</text>
</cell>
</row>
</grid>
</cell>
</row>
</grid>
</cell>
</row>
</grid>
</cell>
</row>
</grid>
</page-header>
<page-footer>
<grid name="footerGrid" id="78">
<column id="79">
<property name="width">86%</property>
</column>
<column id="80">
<property name="width">6%</property>
</column>
<column id="81"/>
<row id="82">
<cell id="83">
<property name="colSpan">3</property>
<property name="rowSpan">1</property>
<property
name="style">footerGridStyle</property>
<grid name="grid_footer" id="84">
<column id="85"/>
<row id="86">
<cell id="87">
<text name="footerText" id="88">
<property
name="style">copyright</property>
<property
<text-property
name="content"><![CDATA[]]></text-property>
</text>
</cell>
</row>
</grid>
</cell>
</row>
<row id="89">
<cell id="90">
<text name="copyright" id="91">
<property name="style">copyright</property>
<property
<text-property
name="content"><![CDATA[&copy; 1996-2009 Anabase International
Corp&reg;. All rights reserved.]]></text-property>
</text>
</cell>
<cell id="92">
<property name="colSpan">2</property>
<text name="Confidential" id="93">
<property
name="style">Confidential</property>
<property
name="contentType">plain</property>
<text-property
name="content"><![CDATA[Confidential]]></text-property>
</text>
</cell>
<cell id="94"/>
</row>
<row id="95">
<cell id="96"/>
<cell id="97">
<text name="PageNo" id="98">
<property name="style">pageNo</property>
<property
<text-property
name="content"><![CDATA[Page:]]></text-property>
</text>
</cell>
<cell id="99">
<auto-text name="pageno" id="100">
<property
name="type">page-number</property>
</auto-text>
</cell>
</row>
</grid>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<grid name="gridComputedColumn" id="103">
<property name="style">Statistical_Data</property>
<column id="104">
<property name="width">18%</property>
</column>
<column id="105">
<property name="width">1%</property>
</column>
<column id="106">
<property name="width">81%</property>
</column>
</grid>
<grid id="107">
<column id="108"/>
<row id="109">
<cell id="110">
<extended-item extensionName="Chart" name="NewChart"
id="111">
<xml-property
name="xmlRepresentation"><![CDATA[<model:ChartWithAxes
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:attribute="http://www.birt.eclipse.org/ChartModelAttribute"
xmlns:data="http://www.birt.eclipse.org/ChartModelData"
xmlns:layout="http://www.birt.eclipse.org/ChartModelLayout"
xmlns:model="http://www.birt.eclipse.org/ChartModel"
xmlns:type="http://www.birt.eclipse.org/ChartModelType">
<Type>Line Chart</Type>
<SubType>Overlay</SubType>
<Block>
<Children xsi:type="layout:TitleBlock">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
<Height>0.0</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Bottom>3.0</Bottom>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Rowspan>-1</Rowspan>
<Columnspan>-1</Columnspan>
<Outline>
<Style>Solid</Style>
<Thickness>1</Thickness>
<Color>
<Transparency>255</Transparency>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
<Visible>false</Visible>
</Outline>
<Visible>true</Visible>
<Label>
<Caption>
<Value>gtitle</Value>
<Font>
<Size>10.0</Size>
<Bold>true</Bold>
<Alignment>
<horizontalAlignment>Center</horizontalAlignment>
<verticalAlignment>Center</verticalAlignment>
</Alignment>
</Font>
</Caption>
<Background xsi:type="attribute:ColorDefinition">
<Transparency>0</Transparency>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Bottom>0.0</Bottom>
<Right>3.0</Right>
</Insets>
</Label>
</Children>
<Children xsi:type="layout:Plot">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<HorizontalSpacing>5</HorizontalSpacing>
<VerticalSpacing>5</VerticalSpacing>
<ClientArea>
<Red>254</Red>
<Green>251</Green>
<Blue>233</Blue>
</Background>
<Outline>
<Thickness>0</Thickness>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>0.0</Left>
<Right>0.0</Right>
</Insets>
</ClientArea>
</Children>
<Children xsi:type="layout:Legend">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>2.0</Top>
<Left>2.0</Left>
<Bottom>2.0</Bottom>
<Right>2.0</Right>
</Insets>
</ClientArea>
<Text>
<Value></Value>
<Font>
<Size>7.0</Size>
<Alignment/>
</Font>
</Text>
<Orientation>Horizontal</Orientation>
<Direction>Left_Right</Direction>
<Separator>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Separator>
<Position>Below</Position>
<ItemType>Series</ItemType>
<Title>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Above</TitlePosition>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>600.0</Width>
<Height>300.0</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
</Block>
<Dimension>Two_Dimensional</Dimension>
<SeriesThickness>10.0</SeriesThickness>
<Interactivity/>
<Axes>
<Type>Text</Type>
<Title>
<Caption>
<Value>ctitle</Value>
<Font>
<Name>Verdana</Name>
<Size>8.0</Size>
<Bold>false</Bold>
<Alignment>
Re: Chart Grouping problem BIRT 2.3 [message #368789 is a reply to message #368780] |
Thu, 25 June 2009 16:36 |
Can you send the program that creates the report as well.
Take a look at this test from the source code:
package org.eclipse.birt.report.tests.chart.regression;
import java.awt.Graphics;
import java.awt.Graphics2D;
import java.awt.image.BufferedImage;
import org.eclipse.birt.chart.device.IDeviceRenderer;
import org.eclipse.birt.chart.exception.ChartException;
import org.eclipse.birt.chart.factory.GeneratedChartState;
import org.eclipse.birt.chart.factory.Generator;
import org.eclipse.birt.chart.factory.IDataRowExpressionEvaluator;
import org.eclipse.birt.chart.factory.RunTimeContext;
import org.eclipse.birt.chart.model.Chart;
import org.eclipse.birt.chart.model.ChartWithAxes;
import org.eclipse.birt.chart.model.attribute.AxisType;
import org.eclipse.birt.chart.model.attribute.Bounds;
import org.eclipse.birt.chart.model.attribute.DataType;
import org.eclipse.birt.chart.model.attribute.SortOption;
import org.eclipse.birt.chart.model.attribute.impl.BoundsImpl;
import org.eclipse.birt.chart.model.component.Axis;
import org.eclipse.birt.chart.model.component.Series;
import org.eclipse.birt.chart.model.component.impl.SeriesImpl;
import org.eclipse.birt.chart.model.data.Query;
import org.eclipse.birt.chart.model.data.SeriesDefinition;
import org.eclipse.birt.chart.model.data.impl.QueryImpl;
import org.eclipse.birt.chart.model.data.impl.SeriesDefinitionImpl;
import org.eclipse.birt.chart.model.impl.ChartWithAxesImpl;
import org.eclipse.birt.chart.model.type.BarSeries;
import org.eclipse.birt.chart.model.type.impl.BarSeriesImpl;
import org.eclipse.birt.chart.util.CDateTime;
import org.eclipse.birt.chart.util.PluginSettings;
import org.eclipse.birt.report.tests.chart.ChartTestCase;
* Regression description:
* </p>
* It does not work with dates (X Axis grouping)
* </p>
* Test description:
* <p>
* X Axis grouping, set x Axis data type to data time, render the
chart, verify
* if it will be take effect
* </p>
public class Regression_109622_1 extends ChartTestCase
private static String GOLDEN = "Regression_109622_1.jpg"; //$NON-NLS-1$
private static String OUTPUT = "Regression_109622_1.jpg"; //$NON-NLS-1$
* Comment for <code>serialVersionUID</code>
private static final long serialVersionUID = 1L;
* A chart model instance
private Chart cm = null;
* The jpg rendering device
private IDeviceRenderer dRenderer = null;
private GeneratedChartState gcs = null;
* execute application
* @param args
public static void main( String[] args )
new Regression_109622_1( );
* Constructor
public Regression_109622_1( )
final PluginSettings ps = PluginSettings.instance( );
try
dRenderer = ps.getDevice( "dv.JPG" );//$NON-NLS-1$
catch ( ChartException ex )
ex.printStackTrace( );
cm = createChart( );
bindGroupingData( cm );
BufferedImage img = new BufferedImage(
500,
500,
BufferedImage.TYPE_INT_ARGB );
Graphics g = img.getGraphics( );
Graphics2D g2d = (Graphics2D) g;
dRenderer.setProperty( IDeviceRenderer.GRAPHICS_CONTEXT, g2d );
dRenderer.setProperty( IDeviceRenderer.FILE_IDENTIFIER, this
.genOutputFile( OUTPUT ) ); //$NON-NLS-1$
Bounds bo = BoundsImpl.create( 0, 0, 500, 500 );
bo.scale( 72d / dRenderer.getDisplayServer( ).getDpiResolution( ) );
Generator gr = Generator.instance( );
try
gcs = gr.build(
dRenderer.getDisplayServer( ),
cm,
bo,
null,
null,
null );
gr.render( dRenderer, gcs );
catch ( ChartException e )
// TODO Auto-generated catch block
e.printStackTrace( );
public void test_regression_109622_1( ) throws Exception
Regression_109622_1 st = new Regression_109622_1( );
assertTrue( st.compareBytes( GOLDEN, OUTPUT ) );
private void bindGroupingData( Chart chart )
// Data Set
final Object[][] data = new Object[][]{
{"x1", new Integer( 1 ), new CDateTime( 2004, 12, 27 )},
{"x2", new Integer( 2 ), new CDateTime( 2004, 12, 22 )},
{"x3", new Integer( 3 ), new CDateTime( 2004, 12, 27 )},
{"x4", new Integer( 4 ), new CDateTime( 2004, 12, 22 )},
{"x5", new Integer( 5 ), new CDateTime( 2004, 12, 17 ),},
{"x6", new Integer( 6 ), new CDateTime( 2004, 12, 27 )},
{"x7", new Integer( 7 ), new CDateTime( 2004, 12, 17 ),},
{"x8", new Integer( 8 ), new CDateTime( 2004, 12, 22 )},
{"x9", new Integer( 9 ), new CDateTime( 2004, 12, 17 ),},
{"x0", new Integer( 0 ), new CDateTime( 2004, 12, 17 ),},};
try
gr.bindData( new IDataRowExpressionEvaluator( ) {
int idx = 0;
public void close( )
public Object evaluate( String expression )
if ( "X".equals( expression ) )
return data[idx][0];
else if ( "Y".equals( expression ) )
return data[idx][1];
else if ( "G".equals( expression ) )
return data[idx][2];
return null;
public Object evaluateGlobal( String expression )
return evaluate( expression );
public boolean first( )
idx = 0;
return true;
public boolean next( )
idx++;
return ( idx < 9 );
}, chart, new RunTimeContext( ) );
private Chart createChart( )
ChartWithAxes cwaBar = ChartWithAxesImpl.create( );
// X-Axis
Axis xAxisPrimary = cwaBar.getPrimaryBaseAxes( )[0];
xAxisPrimary.getLabel( ).getCaption( ).getFont( ).setRotation( 75 );
// Y-Axis
Axis yAxisPrimary = cwaBar.getPrimaryOrthogonalAxis( xAxisPrimary );
yAxisPrimary.setType( AxisType.LINEAR_LITERAL );
// X-Series
Query xQ = QueryImpl.create( "G" );
seCategory.getDataDefinition( ).add( xQ );
sdX.setSorting( SortOption.ASCENDING_LITERAL );
sdX.getGrouping( ).setEnabled( true );
sdX.getGrouping( ).setGroupType( DataType.DATE_TIME_LITERAL );
sdX.getGrouping( ).setAggregateExpression( "Sum" );
sdX.getGrouping( ).setGroupingInterval( 1 );
// Y-Series
BarSeries bs = (BarSeries) BarSeriesImpl.create( );
bs.getLabel( ).setVisible( true );
Query yQ = QueryImpl.create( "Y" );
bs.getDataDefinition( ).add( yQ );
SeriesDefinition sdY = SeriesDefinitionImpl.create( );
sdY.getSeriesPalette( ).update( 0 );
sdY.getSeries( ).add( bs );
return cwaBar;
Jason
Mehrab wrote:
> Jason,
> <structure>
> </structure>
> <structure>
> </structure>
> else
> ChartDimension.THREE_DIMENSIONAL_LITERAL ); }
> else
> chart
> * in the BIRT engine */
> true );
> cwaLine.getTitle( ).getLabel().getCaption().getFont().setBold(true);
> //PLOT Plot plotArea = cwaLine.getPlot();
> date" );
> xAxisPrimary );
> else
> else
> else{
> //do nothing
> else{
> supported ");
> else{
> //do not grouping
> else{
> definition of * grouping interval.but using trial and
> error process we recover the following
> * TEXT = 0
> * DATE/TIME = 1
> * NUMBER = 1
> else {
> return cwaLine;
> int count = -2;
> String exp = key;
> ls.getLineAttributes().setColor(ColorDefinitionImpl.create( 154, 50, 102
> marker list");
> else{
> count = count - 1;
> markerCount = markerCount + 1; }
> id="1">
> <data-sources>
> <oda-data-source
> id="101">
> <property
> <property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </style>
> </style>
> </style>
> </style>
> </style>
> </style>
> </style>
> </style>
> </style>
> </style>
> </style>
> </style>
> </style>
> </style>
> </style>
> </style>
> </style>
> </style>
> </style>
> </style>
> </style>
> </style>
> </style>
> </style>
> </style>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-header>
> <column id="33"/>
> <row id="34">
> <cell id="35">
> <column id="37"/>
> <row id="38">
> <cell id="39">
> id="40">
> <property
> <property
> <column id="41"/>
> <column id="42"/>
> <row id="43">
> <cell id="44">
> <grid
> <property
> <column id="46"/>
> <row id="47">
> <cell id="48">
> <property
> <label
> id="49">
> </label>
> </cell>
> </row>
> <row id="50">
> <cell id="51">
> <property
> <label
> id="52">
> </label>
> </cell>
> </row>
> </grid>
> </cell>
> <cell id="53">
> id="54">
> <property
> <column id="55"/>
> <row id="56">
> <cell id="57">
> <property
> <property
> <image
> </image>
> </cell>
> </row>
> </grid>
> </cell>
> </row>
> <row id="59">
> <cell id="60"/>
> <cell id="61"/>
> </row>
> </grid>
> </cell>
> </row>
> <row id="62">
> <cell id="63">
> <property
> <column id="65">
> <property
> </column>
> <column id="66">
> <property
> </column>
> <row id="67">
> <cell id="68"/>
> <cell id="69">
> id="70">
> <property
> <column id="71"/>
> <row id="72">
> <cell id="73">
> <property
> <label
> id="74">
> </label>
> </cell>
> </row>
> <row id="75">
> <cell id="76">
> <property
> <text
> </text>
> </cell>
> </row>
> </grid>
> </cell>
> </row>
> </grid>
> </cell>
> </row>
> </grid>
> </cell>
> </row>
> </grid>
> </page-header>
> <page-footer>
> <column id="79">
> </column>
> <column id="80">
> </column>
> <column id="81"/>
> <row id="82">
> <cell id="83">
> <property
> <column id="85"/>
> <row id="86">
> <cell id="87">
> <property
> <property
> <text-property
> </text>
> </cell>
> </row>
> </grid>
> </cell>
> </row>
> <row id="89">
> <cell id="90">
> <text-property
> </text>
> </cell>
> <cell id="92">
> <property
> <property
> <text-property
> </text>
> </cell>
> <cell id="94"/>
> </row>
> <row id="95">
> <cell id="96"/>
> <cell id="97">
> <text-property
> </text>
> </cell>
> <cell id="99">
> <property name="type">page-number</property>
> </auto-text>
> </cell>
> </row>
> </grid>
> </page-footer>
> </page-setup>
> <body>
> <column id="104">
> </column>
> <column id="105">
> </column>
> <column id="106">
> </column>
> </grid>
> <grid id="107">
> <column id="108"/>
> <row id="109">
> <cell id="110">
> id="111">
> <xml-property
> xm
Re: Chart Grouping problem BIRT 2.3 [message #368840 is a reply to message #368789] |
Tue, 30 June 2009 11:47 |
Junior Member |
Jason,
My simple chart program that creates the report .rptdesign file. If I use
BIRT 2.1 to run the program then its create and run report properly. But
if I use BIRT 2.3 then its throw exception on report runtime. If I create
report without x-axis grouping then the report run properly. Please help
me. I think its a bug.
Thank you.
Mehrab
Take a look at this source code:
package com.birt.test;
import java.io.IOException;
import org.eclipse.birt.chart.model.attribute.IntersectionType;
import org.eclipse.birt.chart.model.attribute.TickStyle;
import org.eclipse.birt.chart.model.attribute.impl.ColorDefinitionI mpl;
import org.eclipse.birt.chart.model.layout.Plot;
import org.eclipse.birt.chart.model.type.LineSeries;
import org.eclipse.birt.chart.model.type.impl.LineSeriesImpl;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.model.api.DesignConfig;
import org.eclipse.birt.report.model.api.ElementFactory;
import org.eclipse.birt.report.model.api.ExtendedItemHandle;
import org.eclipse.birt.report.model.api.IDesignEngine;
import org.eclipse.birt.report.model.api.IDesignEngineFactory;
import org.eclipse.birt.report.model.api.OdaDataSetHandle;
import org.eclipse.birt.report.model.api.OdaDataSourceHandle;
import org.eclipse.birt.report.model.api.ReportDesignHandle;
import org.eclipse.birt.report.model.api.SessionHandle;
import org.eclipse.birt.report.model.api.SimpleMasterPageHandle;
import org.eclipse.birt.report.model.api.activity.SemanticException ;
import org.eclipse.birt.report.model.api.command.ContentException;
import org.eclipse.birt.report.model.api.command.NameException;
import com.ibm.icu.util.ULocale;
public class SimpleChart
private ReportDesignHandle reportDesignHandle = null;
private ElementFactory elementFactory = null;
private OdaDataSourceHandle odaDataSourceHandle = null;
private String dataSourceName = \"datasource\";
private String dataSetName = \"maindataset\";
private String query = \"SELECT SIMS.ROLES.\\\"CREATOR\\\",
SIMS.ROLES.\\\"RID\\\" FROM SIMS.ROLES \";
public static void main(String args[])
try {
new SimpleChart().createReport();
} catch (Exception e) {
e.printStackTrace();
public void createReport() throws SemanticException, IOException
System.out.println(\"Start\");
init();
createMasterPages();
createDataSources();
createDataSets();
createBody();
String outputPath = \"C:/work\";
reportDesignHandle.saveAs(outputPath + \"/\" +
\"SimpleChart2_1.rptdesign\");//$NON-NLS-1$//$NON-NLS-2$
System.out.println(\"End\");
private void init(){
DesignConfig config = new DesignConfig();
config.setProperty(\"BIRT_HOME\",
\" C:/Users/Mehrabul/Documents/Projects/AnabaseWorkSpace270509t est/art/war/WEB-INF/platform\ ");
IDesignEngine engine = null;
try {
Platform.startup(config);
IDesignEngineFactory factory = (IDesignEngineFactory) Platform
.createFactoryObject(IDesignEngineFactory.EXTENSION_DESIGN_E NGINE_FACTORY);
engine = factory.createDesignEngine(config);
} catch (Exception ex) {
ex.printStackTrace();
// we need a handle of session of design engine
SessionHandle sessionHandle = engine.newSessionHandle(ULocale.ENGLISH);
reportDesignHandle = sessionHandle.createDesign();
elementFactory = reportDesignHandle.getElementFactory();
private void createMasterPages() throws ContentException, NameException
SimpleMasterPageHandle simpleMasterPage =
elementFactory.newSimpleMasterPage(\"Master Page\");
reportDesignHandle.getMasterPages().add(simpleMasterPage);
private void createDataSets() throws SemanticException
String dataSetType =
\"org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet\";
OdaDataSetHandle dataSetHandle = null;
dataSetHandle = elementFactory.newOdaDataSet(dataSetName, dataSetType);
dataSetHandle.setDataSource(dataSourceName);
dataSetHandle.setQueryText(query);
reportDesignHandle.getDataSets().add(dataSetHandle);
private void createDataSources() throws SemanticException
// type of the data source
String extensionID = \"org.eclipse.birt.report.data.oda.jdbc\";
String driverClassName = \"oracle.jdbc.driver.OracleDriver\";
String driverURL = \"jdbc:oracle:thin:@192.168.174.25:1521:BDEV\";
String userName = \"mferdous\";
String userPassword = \"anabase\";
// now make a data source with the dataSourceName and extensionID.
odaDataSourceHandle = elementFactory.newOdaDataSource(dataSourceName,
extensionID);
odaDataSourceHandle.setProperty(\"odaDriverClass\", driverClassName);
odaDataSourceHandle.setProperty(\"odaURL\", driverURL);
odaDataSourceHandle.setProperty(\"odaUser\", userName);
odaDataSourceHandle.setProperty(\"odaPassword\", userPassword);
reportDesignHandle.getDataSources().add(odaDataSourceHandle) ;
private void createBody() throws SemanticException
ExtendedItemHandle extendedItemHandle =
elementFactory.newExtendedItem(\"Simple Chart\", \"Chart\");
extendedItemHandle.setWidth(\"700px\");
extendedItemHandle.setHeight(\"500px\");
extendedItemHandle.setProperty(ExtendedItemHandle.DATA_SET_P ROP,
dataSetName);
extendedItemHandle.setProperty(\"outputFormat\",\"GIF\");
Chart c = createChart();
extendedItemHandle.getReportItem().setProperty( \"chart.instance\", c );
reportDesignHandle.getBody().add(extendedItemHandle);
private Chart createChart() {
ChartWithAxes cwaLine = ChartWithAxesImpl.create();
cwaLine.setType( \"Line Chart\" ); //$NON-NLS-1$
cwaLine.setSubType( \"Overlay\" ); //$NON-NLS-1$
cwaLine.getBlock().getBounds().setHeight(400);
// Plot
cwaLine.getBlock().setBackground( ColorDefinitionImpl.WHITE() );
Plot p = cwaLine.getPlot();
p.getClientArea().setBackground( ColorDefinitionImpl.create( 255, 255,
225 ) );
// Title
cwaLine.getTitle().getLabel().getCaption().setValue( \"Overlay test Line
Chart\" );//$NON-NLS-1$
cwaLine.getTitle().setVisible(true);
// Legend
cwaLine.getLegend().setVisible( true );
// X-Axis
Axis xAxisPrimary = cwaLine.getPrimaryBaseAxes()[0];
xAxisPrimary.getMajorGrid().setTickStyle( TickStyle.BELOW_LITERAL );
xAxisPrimary.getOrigin().setType( IntersectionType.MIN_LITERAL );
// Y-Axis
Axis yAxisPrimary = cwaLine.getPrimaryOrthogonalAxis( xAxisPrimary );
yAxisPrimary.getMajorGrid().setTickStyle( TickStyle.RIGHT_LITERAL );
yAxisPrimary.getLabel().getCaption().setValue(\"TEST\");
yAxisPrimary.getLabel().setVisible(true);
// X-Series
Series seCategory = SeriesImpl.create();
SeriesDefinition sdX = SeriesDefinitionImpl.create();
xAxisPrimary.getSeriesDefinitions().clear();
xAxisPrimary.getSeriesDefinitions().add( sdX );
sdX.getSeries().add( seCategory );
Query query1 = QueryImpl.create( \"row[\\\"CREATOR\\\"]\" );
seCategory.getDataDefinition().clear();
seCategory.getDataDefinition().add( query1 );
// X Axis Grouping
sdX.getGrouping().setGroupType(DataType.TEXT_LITERAL);
sdX.getGrouping().setAggregateExpression(\"Sum\");
// Y-Sereis
SeriesDefinition sdY = SeriesDefinitionImpl.create();
sdY.getSeriesPalette().update( -2 );
yAxisPrimary.getSeriesDefinitions().clear();
LineSeries ls1 = (LineSeries) LineSeriesImpl.create();
ls1.setSeriesIdentifier(\"testls\");
ls1.setVisible(true);
ls1.getLabel().setVisible( true );
Query query2 = QueryImpl.create( \"row[\\\"RID\\\"]\" );//$NON-NLS-1$
yAxisPrimary.getSeriesDefinitions().add( sdY );
sdY.getSeries().add( ls1 );
ls1.getDataDefinition().clear();
ls1.getDataDefinition().add( query2 );
return cwaLine;
//////////////// .rptdesign using BIRT 2.1 ////////////////////////////
<?xml version=\"1.0\" encoding=\"UTF-8\"?>
<!-- Written by Eclipse BIRT 2.0 -->
<report xmlns=\"http://www.eclipse.org/birt/2005/design\"
version=\"3.2.2\" id=\"1\">
<data-sources>
<oda-data-source
extensionID=\"org.eclipse.birt.report.data.oda.jdbc\" name=\"datasource\"
id=\"3\">
<property
name=\"odaDriverClass\">oracle.jdbc.driver.OracleDriver</property >
<property
name=\"odaURL\">jdbc:oracle:thin:@192.168.174.25:1521:BDEV </property>
<property name=\"odaUser\">mferdous</property>
<encrypted-property
name=\"odaPassword\">YW5hYmFzZQ==</encrypted-property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID=\"org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet\ "
name=\"maindataset\" id=\"4\">
<property name=\"dataSource\">datasource</property>
<property name=\"queryText\">SELECT SIMS.ROLES.\"CREATOR\",
SIMS.ROLES.\"RID\" FROM SIMS.ROLES </property>
</oda-data-set>
</data-sets>
<page-setup>
<simple-master-page name=\"Master Page\" id=\"2\"/>
</page-setup>
<body>
<extended-item extensionName=\"Chart\" name=\"Simple Chart\"
id=\"5\">
<property name=\"height\">500px</property>
<property name=\"width\">700px</property>
<property name=\"dataSet\">maindataset</property>
<list-property name=\"boundDataColumns\">
<structure>
<property name=\"name\">CREATOR</property>
<expression
name=\"expression\">dataSetRow[\"CREATOR\"]</expression >
</structure>
<structure>
<property name=\"name\">RID</property>
<expression
name=\"expression\">dataSetRow[\"RID\"]</expression>
</structure>
</list-property>
<xml-property
name=\"xmlRepresentation\"><![CDATA[<model:ChartWithAxes
xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\"
xmlns:attribute=\"http://www.birt.eclipse.org/ChartModelAttribute\"
xmlns:data=\"http://www.birt.eclipse.org/ChartModelData\"
xmlns:layout=\"http://www.birt.eclipse.org/ChartModelLayout\"
xmlns:model=\"http://www.birt.eclipse.org/ChartModel\"
xmlns:type=\"http://www.birt.eclipse.org/ChartModelType\">
<Block>
<Children xsi:type=\"layout:TitleBlock\">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Label>
<Caption>
<Value>Overlay test Line Chart</Value>
<Font>
<Size>16.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Background xsi:type=\"attribute:ColorDefinition\">
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
</Children>
<Children xsi:type=\"layout:Plot\">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Red>255</Red>
<Green>255</Green>
<Blue>225</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>0.0</Left>
<Right>0.0</Right>
</Insets>
</ClientArea>
</Children>
<Children xsi:type=\"layout:Legend\">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>2.0</Top>
<Left>2.0</Left>
<Right>2.0</Right>
</Insets>
</ClientArea>
<Text>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Text>
<Orientation>Vertical</Orientation>
<Direction>Top_Bottom</Direction>
<Separator>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Separator>
<Position>Right</Position>
<Title>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Height>400.0</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
</Block>
<Interactivity/>
<Axes>
<Type>Text</Type>
<Title>
<Caption>
<Value>X-Axis Title</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Below</TitlePosition>
<AssociatedAxes>
<Type>Linear</Type>
<Title>
<Caption>
<Value>Y-Axis Title</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
<Rotation>90.0</Rotation>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Left</TitlePosition>
<SeriesDefinitions>
<Query>
<Definition></Definition>
</Query>
<SeriesPalette>
<Entries xsi:type=\"attribute:ColorDefinition\">
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
</SeriesPalette>
<Series xsi:type=\"type:LineSeries\">
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
<Definition>row["RID"]</Definition>
</DataDefinition>
<SeriesIdentifier>testls</SeriesIdentifier>
<DataPoint>
<Components>
<Type>Orthogonal_Value</Type>
</Components>
<Separator>, </Separator>
</DataPoint>
<LabelPosition>Above</LabelPosition>
<Stacked>false</Stacked>
<Markers>
<Type>Box</Type>
<Size>4</Size>
</Markers>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
</Series>
<Grouping>
<Enabled>false</Enabled>
<GroupingInterval>2</GroupingInterval>
<GroupType>Text</GroupType>
<AggregateExpression>Sum</AggregateExpression>
</Grouping>
</SeriesDefinitions>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
<Label>
<Caption>
<Value>TEST</Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<LabelPosition>Left</LabelPosition>
<MajorGrid>
<LineAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</LineAttributes>
<TickStyle>Right</TickStyle>
<TickAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</TickAttributes>
</MajorGrid>
<MinorGrid>
<LineAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</LineAttributes>
<TickStyle>Across</TickStyle>
<TickAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</TickAttributes>
</MinorGrid>
<Scale>
<MinorGridsPerUnit>5</MinorGridsPerUnit>
</Scale>
<Origin>
<Type>Min</Type>
<Value xsi:type=\"data:NumberDataElement\">
<Value>0.0</Value>
</Value>
</Origin>
<PrimaryAxis>true</PrimaryAxis>
<Percent>false</Percent>
</AssociatedAxes>
<SeriesDefinitions>
<Query>
</Query>
<SeriesPalette>
<Red>127</Red>
<Green>127</Green>
<Blue>127</Blue>
</Entries>
</SeriesPalette>
<Series>
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
<Definition>row["CREATOR"]</Definition>
</DataDefinition>
<SeriesIdentifier></SeriesIdentifier>
<DataPoint>
<Components>
</Components>
</DataPoint>
<LabelPosition>Outside</LabelPosition>
</Series>
<Grouping>
<Enabled>true</Enabled>
<GroupingInterval>1</GroupingInterval>
</Grouping>
<Sorting>Ascending</Sorting>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<LabelPosition>Below</LabelPosition>
<MajorGrid>
<LineAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</LineAttributes>
<TickStyle>Below</TickStyle>
<TickAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</TickAttributes>
</MajorGrid>
<MinorGrid>
<LineAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</TickAttributes>
</MinorGrid>
<Scale>
</Scale>
<Origin>
<Type>Min</Type>
<Value>0.0</Value>
</Value>
</Origin>
</Axes>
<Rotation/>
</model:ChartWithAxes>
]]></xml-property>
<property name=\"outputFormat\">GIF</property>
</extended-item>
</body>
</report>
/////////////////////////// .rptdesign using Birt 2.3 ////////////////
version=\"3.2.17\" id=\"1\">
<data-sources>
<oda-data-source
id=\"5\">
<property
<property
<encrypted-property name=\"odaPassword\"
encryptionID=\"base64\">YW5hYmFzZQ==</encrypted-property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
name=\"maindataset\" id=\"6\">
</oda-data-set>
</data-sets>
<styles>
<style name=\"crosstab-cell\" id=\"2\">
<property name=\"borderBottomColor\">#CCCCCC</property>
<property name=\"borderBottomStyle\">solid</property>
<property name=\"borderBottomWidth\">1pt</property>
<property name=\"borderLeftColor\">#CCCCCC</property>
<property name=\"borderLeftStyle\">solid</property>
<property name=\"borderLeftWidth\">1pt</property>
<property name=\"borderRightColor\">#CCCCCC</property>
<property name=\"borderRightStyle\">solid</property>
<property name=\"borderRightWidth\">1pt</property>
<property name=\"borderTopColor\">#CCCCCC</property>
<property name=\"borderTopStyle\">solid</property>
<property name=\"borderTopWidth\">1pt</property>
</style>
<style name=\"crosstab\" id=\"3\">
</style>
</styles>
<page-setup>
<simple-master-page name=\"Master Page\" id=\"4\"/>
</page-setup>
<body>
id=\"7\">
<xml-property
<Block>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Label>
<Caption>
<Font>
<Size>16.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Red>255</Red>
<Green>255</Green>
<Blue>225</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>0.0</Left>
<Right>0.0</Right>
</Insets>
</ClientArea>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>2.0</Top>
<Left>2.0</Left>
<Right>2.0</Right>
</Insets>
</ClientArea>
<Text>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Text>
<Separator>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Separator>
<Title>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
<Visible>false</Visible><
Re: Chart Grouping problem BIRT 2.3 [message #368843 is a reply to message #368840] |
Tue, 30 June 2009 18:04 |
Originally posted by: jasonweathersby.windstream.net
Mehrab,
This does indeed look like a bug. I checked 2.5 as well.
I was able to get it to work by saving the report and reopening the
design, and drop the sum column. Modified code is attached. Obviously
this is not ideal. Can you open a bug for this?
Jason
import java.util.Iterator;
import org.eclipse.birt.chart.model.attribute.GroupingUnitType;
import org.eclipse.birt.chart.model.data.SeriesGrouping;
import org.eclipse.birt.core.script.ScriptExpression;
import org.eclipse.birt.data.engine.api.querydefn.ComputedColumn;
import org.eclipse.birt.report.model.api.ComputedColumnHandle;
import org.eclipse.birt.report.model.api.DataSetHandle;
import org.eclipse.birt.report.model.api.DesignFileException;
import org.eclipse.birt.report.model.api.PropertyHandle;
import org.eclipse.birt.report.model.api.ScriptDataSetHandle;
import org.eclipse.birt.report.model.api.StructureFactory;
import
org.eclipse.birt.report.model.api.elements.structures.Proper tyBinding;
private String dataSourceName = "datasource";
private String dataSetName = "maindataset";
private SessionHandle sessionHandle =null;
private String query = "SELECT SIMS.ROLES.\"CREATOR\",
SIMS.ROLES.\"RID\" FROM SIMS.ROLES";
org.eclipse.birt.report.model.api.elements.structures.Comput edColumn
cs1, cs2 = null;
try {
System.out.println("Start");
init();
//createDataSources();
//createDataSets();
buildDataSource();
buildDataSet();
createBody();
String outputPath = "C:/work";
reportDesignHandle.saveAs("output/desample/simplechart.rptdesign ");
try
reportDesignHandle = sessionHandle.openDesign(
"output/desample/simplechart.rptdesign" );//$NON-NLS-1$
catch ( DesignFileException e )
ExtendedItemHandle eih = (ExtendedItemHandle)
reportDesignHandle.getBody( )
.getContents( ).get( 0 );
for ( Iterator iter = eih.getColumnBindings( )
.iterator( ); iter.hasNext( ); )
ComputedColumnHandle cch = (ComputedColumnHandle) iter.next( );
if( cch.getExpression().contains("_Sum") ){
cch.drop();
}else{
System.out.println("opened report "+cch.getExpression());
reportDesignHandle.save();
System.out.println("End");
DesignConfig config = new DesignConfig( );
config.setBIRTHome("C:/birt/birt-runtime-2_3_1/birt-runtime-2_3_1/ReportEngine ");
try {
..createFactoryObject(IDesignEngineFactory.EXTENSION_DESIGN_ ENGINE_FACTORY);
elementFactory.newSimpleMasterPage("Master Page");
void buildDataSource( ) throws SemanticException
OdaDataSourceHandle dsHandle = elementFactory.newOdaDataSource(
"Data Source", "org.eclipse.birt.report.data.oda.jdbc" );
dsHandle.setProperty( "odaDriverClass",
"org.eclipse.birt.report.data.oda.sampledb.Driver" );
dsHandle.setProperty( "odaURL", "jdbc:classicmodels:sampledb" );
dsHandle.setProperty( "odaUser", "ClassicModels" );
dsHandle.setProperty( "odaPassword", "" );
PropertyBinding pb = new PropertyBinding();
reportDesignHandle.getDataSources( ).add( dsHandle );
void buildDataSet( ) throws SemanticException
OdaDataSetHandle dsHandle = elementFactory.newOdaDataSet( dataSetName,
"org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet" );
dsHandle.setDataSource( "Data Source" );
String qry = "Select PRODUCTCODE, QUANTITYORDERED from orderdetails
where ordernumber = 10104";
dsHandle.setQueryText( qry );
reportDesignHandle.getDataSets( ).add( dsHandle );
"org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet";
dataSetType);
String extensionID = "org.eclipse.birt.report.data.oda.jdbc";
String driverClassName = "oracle.jdbc.driver.OracleDriver";
String driverURL = "jdbc:oracle:thin:@192.168.174.25:1521:BDEV";
String userName = "mferdous";
String userPassword = "anabase";
extensionID);
odaDataSourceHandle.setProperty("odaDriverClass", driverClassName);
odaDataSourceHandle.setProperty("odaURL", driverURL);
odaDataSourceHandle.setProperty("odaUser", userName);
odaDataSourceHandle.setProperty("odaPassword", userPassword);
elementFactory.newExtendedItem("Simple Chart", "Chart");
extendedItemHandle.setWidth("700px");
extendedItemHandle.setHeight("500px");
dataSetName);
extendedItemHandle.setProperty("outputFormat","GIF");
"chart.instance", c );
//PropertyHandle computedSet = extendedItemHandle.getColumnBindings( );
//computedSet.clearValue();
cs1 = StructureFactory.createComputedColumn( );
cs1.setName( "PRODUCTCODE" );
cs1.setExpression( "dataSetRow[\"PRODUCTCODE\"]");
cs1.setDataType( "string" );
cs1.setAggregateOn(null);
cs2 = StructureFactory.createComputedColumn( );
cs2.setName( "QUANTITYORDERED" );
cs2.setExpression( "dataSetRow[\"QUANTITYORDERED\"]");
cs2.setDataType( "integer" );
extendedItemHandle.addColumnBinding(cs1, true);
extendedItemHandle.addColumnBinding(cs2, true);
cwaLine.setType( "Line Chart" ); //$NON-NLS-1$
cwaLine.setSubType( "Overlay" ); //$NON-NLS-1$
// Plot
255, 255,
225 ) );
// Title
cwaLine.getTitle().getLabel().getCaption().setValue("Overlay
test Line Chart" );
// Legend
// X-Axis
//xAxisPrimary.getMajorGrid().setTickStyle(
//xAxisPrimary.getOrigin().setType( IntersectionType.MIN_LITERAL );
// Y-Axis
xAxisPrimary );
//yAxisPrimary.getMajorGrid().setTickStyle(
//yAxisPrimary.getLabel().getCaption().setValue("TEST");
// X-Series
Series seCategory = SeriesImpl.create( );
// seCategory.setDataSet( categoryValues );
// Set category expression.
.add( QueryImpl.create( "row[\"PRODUCTCODE\"]" ) );
SeriesDefinition sdX = SeriesDefinitionImpl.create( );
sdX.getSeriesPalette( ).shift( 0 );
// Set default grouping.
SeriesGrouping grouping = sdX.getGrouping( );
grouping.getAggregateExpression();
grouping.setEnabled( true );
grouping.setGroupType( DataType.TEXT_LITERAL );
grouping.setGroupingUnit( GroupingUnitType.STRING_PREFIX_LITERAL );
grouping.setGroupingInterval( 1 );
grouping.setAggregateExpression( "Sum" ); // Set Count aggregation.
//$NON-NLS-1$
xAxisPrimary.getSeriesDefinitions( ).add( sdX );
sdX.getSeries( ).add( seCategory );
// Y-Series
LineSeries bs1 = (LineSeries) LineSeriesImpl.create( );
bs1.getDataDefinition( ).add( QueryImpl.create(
"row[\"QUANTITYORDERED\"]" ) );
bs1.getLabel( ).setVisible( true );
sdY.getGrouping().setEnabled(false);
yAxisPrimary.getSeriesDefinitions( ).add( sdY );
sdY.getSeries( ).add( bs1 );
return cwaLine;
Mehrab wrote:
> Jason,
> use BIRT 2.1 to run the program then its create and run report properly.
> But if I use BIRT 2.3 then its throw exception on report runtime. If I
> create report without x-axis grouping then the report run properly.
> Please help me. I think its a bug.
> Thank you.
> Mehrab
> try {
> init();
> createDataSets();
> createBody();
> try {
> dataSetType);
> extensionID);
> driverClassName);
> dataSetName);
> // Plot
> 255, 255,
> 225 ) );
> // Title
> test Line Chart\" );//$NON-NLS-1$
> // Legend
> // X-Axis
> // Y-Axis
> xAxisPrimary );
> // X-Series
> // X Axis Grouping
> sdX.getGrouping().setEnabled(true);
> // Y-Sereis
> );//$NON-NLS-1$
> return cwaLine;
> <data-sources>
> <oda-data-source
> name=\"datasource\" id=\"3\">
> <property
> <property
> <encrypted-property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> </oda-data-set>
> </data-sets>
> <page-setup>
> </page-setup>
> <body>
> id=\"5\">
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> </list-property>
> <xml-property
> <Block>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> <Width>0.0</Width>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Label>
> <Caption>
> <Font>
> <Size>16.0</Size>
> <Bold>true</Bold>
> <Alignment>
> </Alignment>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Label>
> </Children>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> <Width>0.0</Width>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <ClientArea>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>225</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>0.0</Left>
> <Right>0.0</Right>
> </Insets>
> </ClientArea>
> </Children>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> <Width>0.0</Width>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <ClientArea>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>2.0</Top>
> <Left>2.0</Left>
> <Right>2.0</Right>
> </Insets>
> </ClientArea>
> <Text>
> <Value></Value>
> <Font>
> <Alignment/>
> </Font>
> </Text>
> <Separator>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Separator>
> <Title>
> <Caption>
> <Value></Value>
> <Font>
> <Alignment/>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Title>
> </Children>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> </Block>
> <Interactivity/>
> <Axes>
> <Type>Text</Type>
> <Title>
> <Caption>
> <Font>
> <Size>14.0</Size>
> <Bold>true</Bold>
> <Alignment>
> </Alignment>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Title>
> <AssociatedAxes>
> <Type>Linear</Type>
> <Title>
> <Caption>
> <Font>
> <Size>14.0</Size>
> <Bold>true</Bold>
> <Alignment>
> </Alignment>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Title>
> <SeriesDefinitions>
> <Query>
> </Query>
> <SeriesPalette>
> <Red>232</Red>
> <Green>172</Green>
> <Blue>57</Blue>
> </Entries>
> <Red>128</Red>
> <Green>255</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>64</Red>
> <Green>128</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>170</Red>
> <Green>85</Green>
> <Blue>85</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>0</Blue>
> </Entries>
> <Red>80</Red>
> <Green>166</Green>
> <Blue>218</Blue>
> </Entries>
> <Red>242</Red>
> <Green>88</Green>
> <Blue>106</Blue>
> </Entries>
> </SeriesPalette>
> <Label>
> <Caption>
> <Value></Value>
> <Font>
> <Alignment/>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Label>
> <DataDefinition>
> </DataDefinition>
> <DataPoint>
> <Components>
> </Components>
> </DataPoint>
> <Markers>
> <Type>Box</Type>
> <Size>4</Size>
> </Markers>
> <LineAttributes>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </LineAttributes>
> </Series>
> <Grouping>
> </Grouping>
> <LineAttributes>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </LineAttributes>
> <Label>
> <Caption>
> <Value>TEST</Value>
> <Font>
> <Alignment/>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Label>
> <MajorGrid>
> <LineAttributes>
> <Color>
> <Red>196</Red>
> <Green>196</Green>
> <Blue>196</Blue>
> </Color>
> </LineAttributes>
> <TickAttributes>
> <Color>
> <Red>196</Red>
> <Green>196</Green>
> <Blue>196</Blue>
> </Color>
> </TickAttributes>
> </MajorGrid>
> <MinorGrid>
> <LineAttributes>
> <Color>
> <Red>225</Red>
> <Green>225</Green>
> <Blue>225</Blue>
> </Color>
> </LineAttributes>
> <TickAttributes>
> <Color>
> <Red>225</Red>
> <Green>225</Green>
> <Blue>225</Blue>
> </Color>
> </TickAttributes>
> </MinorGrid>
> <Scale>
> </Scale>
> <Origin>
> <Type>Min</Type>
> <Value>0.0</Value>
> </Value>
> </Origin>
> </AssociatedAxes>
> <SeriesDefinitions>
> <Query>
> </Query>
> <SeriesPalette>
> <Red>127</Red>
> <Green>127</Green>
> <Blue>127</Blue>
> </Entries>
> </SeriesPalette>
> <Series>
> <Label>
> <Caption>
> <Value></Value>
> <Font>
> <Alignment/>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Label>
> <DataDefinition>
> </DataDefinition>
> <DataPoint>
> <Components>
> </Components>
> </DataPoint>
> </Series>
> <Grouping>
> </Grouping>
> </SeriesDef
Current Time: Sat Apr 20 00:42:03 GMT 2024
Powered by FUDForum. Page generated in 0.04161 seconds
