Re: How does BIRT know the columns returned from proc? [message #368689 is a reply to message #368659] |
Thu, 18 June 2009 19:59 |
Originally posted by: jasonweathersby.windstream.net
Dean,
When you put the ? in for the parameters you should have had to enter a
default value there. (BTW your sp can return multiple cursors, but you
have to pick one in the designer).
2 - This should not be happening. I tried this on my install on MySQL
and had no issues. What happens when you change the values? Are you
getting any data?
3 -
You can add a script tag to a text element like:
<script type="text/javascript">
function forward() {
location.replace("http://www.google.com");
forward();
</script>
And then use the visibility expression Total.count() >0 to hide it when
you have rows.
If you are using the APIs you can call the task.getErrors() method, but
it sounds like you are using the viewer.
Jason
Dean Hiller wrote:
> How in the world does BIRT do discovery on the columns output by more
> stored
> proc? My stored proc has 4 inputs and before it can run the stored proc,
> it must ask me for defaults to pass in but does not!!!! I assume it
> is taking a guess, but then on some stored procs, if it guesses wrong, a
> single column called error with an error code might be returned(maybe
> with another column called error message). How is BIRT running my proc
> which takes 4 parameters? I ask because my proc errors out and gets the
> error columns instead of the real columns.
> 2nd question: I can't seem to rerun to get clean output columns once I
> setup the parameters and default the parameters to valid values.
> 3rd question: How can my java code call into the BIRT Engine after
> running the report but before displaying it to see if there was 0 rows
> returned OR if there was an error returned so that I can redirect to an
> error page instead of showing a report with 0 rows via excel or pdf?
> thanks for any help on this.
> Dean
Re: How does BIRT know the columns returned from proc? [message #368750 is a reply to message #368730] |
Wed, 24 June 2009 13:48 |
Dean,
I do not see a dataset in the xml snippet.
Jason
Dean Hiller wrote:
> sweeeeet!!! task.getErrors() was exactly what I wanted but the "other
> issue persists" for some reason....(I worked around by changing proc to
> not error out which get around the problem)....
> nope, after the ?, ?, ?, it doesn't ask...weird. I deleted all
> parameters, and deleted all data sets and was then viewed my xml source
> after saving. Then I redid the steps to pick the proc from the
> wizard(when creating data set) and after typing the proc, it never asks
> me for the default values(I only have one which is a Date type in this
> case). Here is the xml if you are curious just before I create the data
> set......(I also tried taking out the log4jdbc driver and using
> ojdbc14.jar directly with the correct oracle class as well, but that
> didn't seem to help either.)
> <report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.17"
> id="1">
> <property name="createdBy">Eclipse BIRT Designer Version
> 2.3.2.r232_20090202 Build <2.3.2.v20090218-0730></property>
> <property name="units">in</property>
> <property name="iconFile">/templates/blank_report.gif</property>
> <property name="bidiLayoutOrientation">ltr</property>
> <data-sources>
> <oda-data-source
> extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
> id="7">
> <property
> name="odaDriverClass">net.sf.log4jdbc.DriverSpy</property >
> <property
> name="odaURL">jdbc:log4jdbc:oracle:thin:@10.10.x.x:1521:xcodev01 </property>
> <property name="odaUser">deano</property>
> <encrypted-property name="odaPassword"
> encryptionID="base64">xxxZeFGdtVhbjAx</encrypted-property >
> </oda-data-source>
> </data-sources>
> <styles>
> <style name="report" id="4">
> <property name="fontFamily">"Verdana"</property>
> <property name="fontSize">10pt</property>
> </style>
> <style name="crosstab-cell" id="5">
> <property name="borderBottomColor">#CCCCCC</property>
> <property name="borderBottomStyle">solid</property>
> <property name="borderBottomWidth">1pt</property>
> <property name="borderLeftColor">#CCCCCC</property>
> <property name="borderLeftStyle">solid</property>
> <property name="borderLeftWidth">1pt</property>
> <property name="borderRightColor">#CCCCCC</property>
> <property name="borderRightStyle">solid</property>
> <property name="borderRightWidth">1pt</property>
> <property name="borderTopColor">#CCCCCC</property>
> <property name="borderTopStyle">solid</property>
> <property name="borderTopWidth">1pt</property>
> </style>
> <style name="crosstab" id="6">
> </style>
> </styles>
> <page-setup>
> <simple-master-page name="Simple MasterPage" id="2">
> <property name="topMargin">0.25in</property>
> <property name="leftMargin">0.25in</property>
> <property name="bottomMargin">0.25in</property>
> <property name="rightMargin">0.25in</property>
> <page-footer>
> <text id="3">
> <property name="contentType">html</property>
> <text-property name="content"><![CDATA[<value-of>new
> Date()</value-of>]]></text-property>
> </text>
> </page-footer>
> </simple-master-page>
> </page-setup>
> </report>
Re: no multiple cursor support? [message #368751 is a reply to message #368731] |
Wed, 24 June 2009 13:49 |
Dean,
You can specify which cursor is used in the dataset editor.
Jason
Dean Hiller wrote:
> oh, does BIRT not support putting the two cursors into two result sets?
> I guess that means I have to split the proc into two different calls then?
> thanks,
> Dean
FUDForum. Page generated in 0.03327 seconds
