Node set from XML data source? [message #368617] |
Mon, 15 June 2009 23:46 |
Originally posted by: fhj.adsf.com
I am using the below xml file as datasource:
<root>
<lines>
<line order="0">
<content id="A" value="0_A"/>
<content id="B" value="0_B"/>
<content id="C" value="0_C"/>
<content id="D" value="0_D"/>
<content id="E" value="0_E"/>
</line>
<line order="1">
<content id="A" value="1_A"/>
<content id="B" value="1_B"/>
<content id="C" value="1_C"/>
<content id="D" value="1_D"/>
<content id="E" value="1_E"/>
</line>
</lines>
</root>
I use the following row mapping:
/root
In the following its assumed that its not allowed to change the above row
mapping.
When I define this column mapping:
XPath: /lines/line/content[@id="A"]/@value
and drag it into a table the result is:
0_A
But I need the result to be:
0_A
1_A
How do I get all values from all lines where id=A ? Remeber that its not
allowed to change the row mapping. I have the feeling that its impossible
but why??
Re: Node set from XML data source? [message #368627 is a reply to message #368617] |
Tue, 16 June 2009 14:58 |
Originally posted by: jasonweathersby.windstream.net
Try a row xpath syntax as
/root/lines/line/content[@id="A"]
and column mapping
/@id
and
/@value
Jason
> <root>
> <lines>
> <line order="0">
> </line>
> <line order="1">
> </line>
> </lines>
> </root>
> /root
> mapping.
> 0_A
> 0_A
> 1_A
> but why??
FUDForum. Page generated in 0.03640 seconds
