Re: BIRT background image is screwed [message #368595 is a reply to message #368592] |
Fri, 12 June 2009 16:01 |
Larry Li Messages: 32 Registered: July 2009 |
Member |
Well, this is what I found about birt background functionality... I wish
it helps if someone else has similar problems.
First, it works much better in bmp images than the other types such as jpg
gif.
So, using bmp has a better chance to get a "normal" background.
Second, the image size ratio (height/width) should be the same (or very
close) to the height/width ratio of the report. Therefore, birt won't
generate "unexpected" background image.
If I do these two steps carefully, I have a higher chance (but not always)
to get the background I want.
By the way, all of those "background repeat," "background size," and
"contain" properties do not help fixing this background image problem.
Larry
> Larry,
> This seems like a bug. But you can try set the "background repeat" to
> "no repeat" and "background size height/width" to "contain" through
> Properties View or Advanced Property tab for the two Master Page elements.
> Larry Li wrote:
>> Hello,
>> The background images do not fit well in the page.
>> I make an example report which has two pages.
>> Each page uses a different background image.
>> When I preview in PDF format,
>> the first page looks fine, but the second page background is screwed.
>> The report file and images are all here:
>> http://www1.cs.columbia.edu/~wl318/birt/
>> Is there a way to fix this? I use BIRT 2.5.0
>> Thank you.
>> Larry
FUDForum. Page generated in 0.03701 seconds
