Re: Reg. Scripted Data Source ClassPath [message #368571 is a reply to message #368559] |
Wed, 10 June 2009 16:17 |
Originally posted by: jasonweathersby.windstream.net
Shivam,
Can you post the entire script for the open method and the entire stack
trace? You have several choices to put the file.
1 - Create a Java project in the same workspace as BIRT and it should
find it.
2 - Or jar it and drop it in the viewer plugins scriptlib directory.
3 - Or select the reprot and then in the properties add it as a resource.
Jason
shivam wrote:
> In which directory should I put my classes for scripted data source. I have
> tried
> classes directory as given in the tutorials but no luck. I am using 2.3.2.
> I am using Designer instead of api.
> Error that I keep getting are :
> There are errors evaluating script "__bm_open()" TypeError[JavaPackage
> Test.SimpleClass] is not a
> function , it is ... NativeJavaPackage.
> Thanks ,
> Shivam
FUDForum. Page generated in 0.01987 seconds
