Re: Problem with word emitter [message #368530 is a reply to message #368524] |
Mon, 08 June 2009 14:35 |
Originally posted by: jasonweathersby.windstream.net
Conor,
Any chance you could post an example report that has the issue?
Jason
Conor O'Mahony wrote:
> Sorry, forgot to include version info -
> Eclipse is 3.4.1
> BIRT is 2.3.1
> Many thanks,
> Conor
>> I have integrated BIRT report engine into my RCP application- where
>> the user can select the output type (PDF or DOC) and the language
>> (English, German, Spanish etc.) to generate a report from a report
>> design (designed using the DEAPI).
>> The pdf option works fine for all languages but whenever I change the
>> output to DOC and the language to anything other than English, I get
>> the below error (e.g. for German)-
>> Does anyone know what might be causing this?
>> SCHWERWIEGEND: An error happened while running the report. Cause:
>> java.lang.ArrayIndexOutOfBoundsException: -1
>> at
>> org.eclipse.birt.report.engine.emitter.XMLWriter.indent(XMLW riter.java:378)
>> at
>> org.eclipse.birt.report.engine.emitter.XMLWriter.closeTag(XM LWriter.java:188)
>> at
>> org.eclipse.birt.report.engine.emitter.wpml.WpmlWriter.end(W pmlWriter.java:1592)
>> at
>> org.eclipse.birt.report.engine.emitter.wpml.WordEmitterImpl. end(WordEmitterImpl.java:291)
>> at
>> org.eclipse.birt.report.engine.emitter.wpml.WordEmitter.end( WordEmitter.java:80)
>> at
>> org.eclipse.birt.report.engine.emitter.CompositeContentEmitt er.end(CompositeContentEmitter.java:64)
>> at
>> org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:153)
>> at
>> org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:72)
>> at
>> com.pilz.ie.pascal.report.core.logic.impl.birt.BIRTReportTas k$1.run(BIRTReportTask.java:101)
>> at java.lang.Thread.run(Unknown Source)
>> Exception in thread "Thread-5" java.lang.RuntimeException:
>> org.eclipse.birt.report.engine.api.EngineException: Error happened
>> at
>> com.pilz.ie.pascal.report.core.logic.impl.birt.BIRTReportTas k$1.run(BIRTReportTask.java:105)
>> Caused by: org.eclipse.birt.report.engine.api.EngineException: Error
>> at
>> org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:167)
>> at
>> at
>> ... 1 more
>> Caused by: java.lang.ArrayIndexOutOfBoundsException: -1
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 3 more
Re: Problem with word emitter (CANNOT REPRODUCE) [message #368543 is a reply to message #368530] |
Tue, 09 June 2009 09:06 |
Conor O'Mahony Messages: 108 Registered: July 2009 |
Hi Jason,
As luck would have it - this seems to have resolved itself, I had been fixing other issues and when
I went back to try and reproduce this I could not...
If I come across it again I will post the report.
Thanks for your help,
Conor
Jason Weathersby wrote:
> Conor,
> Jason
>> Eclipse is 3.4.1
>> BIRT is 2.3.1
>> Many thanks,
>> Conor
>>> Hi,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 1 more
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 3 more
FUDForum. Page generated in 0.02288 seconds
