Re: Problem With Report Parameter displayText In the BIRT Interactive Viewer Under Tomcat [message #368512 is a reply to message #368505] |
Fri, 05 June 2009 14:08 |
Originally posted by: jasonweathersby.windstream.net
John,
I am looking into this now. What download did you use for the trial?
Jason
John Feigal wrote:
> We have developed some BIRT reports using the Eclipse based BIRT Report
> Designer (2.3.1). Several of the reports include dynamic cascading report
> parameters that are generated from flat text files. A dynamic text cell on
> the reports contains an expression like what follows:
> params["leftDocumentView"].displayText + " by Customer " +
> params["dataAttribute"].displayText;
> The expected results are generated when a report is previewed in the Report
> Designer. Also, when a report is invoked from our web application via a URL
> that launches the generic BIRT viewer installed under Tomcat, we see the
> expected results.
> We currently have a trial license for the BIRT Interactive Viewer that is an
> option in the Actuate Java Components. When the Acutate Java Components is
> installed under Tomcat and one of the reports is invoked from our web
> application va a URL that launches the BIRT Interactive Viewer, we do not
> see the expected results for the expression. We see "null by Customer null"
> displayed instead of "Placements by Customer Gender", for example.
> I have replaced ".displayText" with ".value" in the XML in the rptdesign and
> we see the actual report parameter values.
> Using Google I found the following URL
> ( http://dev.eclipse.org/newslists/news.eclipse.birt/msg25241. html) which
> seems to be related to a similar issue someone was having in 2007, but I
> don't understand where the code that Jason Weathersby provided should be
> placed in the report design. It also isn't clear if Jason's proposed code
> will work when a report is launched in both the generic BIRT viewer and in
> the BIRT Interactive Viewer.
> We are seriously considering the purchase of the BIRT Interactive Viewer,
> but we are concerned about having to develop different versions of BIRT
> reports depending on which viewer will be used.
> Any suggestions on how to easily address the report parameter displayText
> issue would be appreciated.
Re: Problem With Report Parameter displayText In the BIRT Interactive Viewer Under Tomcat [message #368514 is a reply to message #368512] |
Fri, 05 June 2009 15:23 |
John J Feigal Messages: 31 Registered: July 2009 |
Member |
Jason
I downloaded the ActuateJavaComponent.war file (147 MB) on April 24, 2009.
We had some initial problems downloading from www.birt-exchange.org. That
was just about the time that the new website architecture was implemented.
I communicated with jbauson via phone and email in order to successfully
download the war file.
Based upon information in log files, I believe that our trial license
expires on June 14.
Thanks.
John
"Jason Weathersby" <jasonweathersby@windstream.net> wrote in message
news:h0b8rd$t9d$1@build.eclipse.org...
> John,
> Jason
>> report parameters that are generated from flat text files. A dynamic
>> text cell on the reports contains an expression like what follows:
>> Report Designer. Also, when a report is invoked from our web application
>> via a URL that launches the generic BIRT viewer installed under Tomcat,
>> we see the expected results.
>> an option in the Actuate Java Components. When the Acutate Java
>> Components is installed under Tomcat and one of the reports is invoked
>> from our web application va a URL that launches the BIRT Interactive
>> Viewer, we do not see the expected results for the expression. We see
>> "null by Customer null" displayed instead of "Placements by Customer
>> and we see the actual report parameter values.
>> code will work when a report is launched in both the generic BIRT viewer
>> and in the BIRT Interactive Viewer.
Re: Problem With Report Parameter displayText In the BIRT Interactive Viewer Under Tomcat [message #368537 is a reply to message #368514] |
Mon, 08 June 2009 21:09 |
Member |
Jason
I located the copy of the zip file that contained the war file that I
installed under Tomcat.
The name of the zip file is ActuateJavaComponent_war-100C.zip and all of
the files in the zip file are dated March 31, 2009. I'm not sure if that
provides any additional information relevent to your research.
John
"John Feigal" <JohnFeigal@ags-us.com> wrote in message
news:h0bd9h$7qf$1@build.eclipse.org...
> Jason
> That was just about the time that the new website architecture was
> implemented. I communicated with jbauson via phone and email in order to
> successfully download the war file.
> expires on June 14.
> Thanks.
> John
>> John,
>> Jason
>>> is an option in the Actuate Java Components. When the Acutate Java
>>> Viewer, but we are concerned about having to develop different versions
>>> of BIRT reports depending on which viewer will be used.
>>> displayText issue would be appreciated.
Re: Problem With Report Parameter displayText In the BIRT Interactive Viewer Under Tomcat [message #368549 is a reply to message #368537] |
Tue, 09 June 2009 13:15 |
John,
I can reproduce the problem. I will get a bug created in the
ActuateJavaComponent war to get it fixed.
Jason
John Feigal wrote:
> Jason
> John
>> Jason
>> expires on June 14.
>> Thanks.
>> John
>>> John,
>>> Jason
FUDForum. Page generated in 0.03436 seconds
