Home » Archived » BIRT » JDBC Driver classpath in BIRT RCP Designer Problem
JDBC Driver classpath in BIRT RCP Designer Problem [message #368440] |
Fri, 29 May 2009 14:52 |
David Johns Messages: 15 Registered: July 2009 |
Junior Member |
I have a custom JDBC driver that I need to use while creating reports in
the BIRT RCP Designer. I have run into two problems depending on the
version of BIRT that I am running and I don¡Št know how to resolve them.
I would like to determine a way that would work for both Birt2.2.2 and
Birt2.3.2 versions if possible.
I am not having a problem when I go to run the reports in my application,
as they are embedded in my application and it replaces the data source
using a JNDI lookup, so my problem is only when previewing and viewing
reports from the BIRT RCP Designer.
JDBC Driver Requirements:
Main jar: AjJDBC.jar
Supporting jars: AjConnectors.jar, wlfullclient.jar, sqljdbc.jar
All of these files need to be in the classpath when connecting and
querying the data. The driver wraps the normal sql server jdbc driver and
makes JEE calls to Weblogic when it intercepts certain data fields being
returned in the result set. Also, part of this is using the Java Security
Framework (JAAS) to log in to Weblogic.
This works fine outside of BIRT when it has everything in it¡Šs class
path. However, I am getting class not found errors in BIRT during
different circumstances when previewing a report.
Problem Summaries:
Problem 1: Cannot put all .jar files in ¡K/drivers directory because it
causes BIRT to hang when viewing the DataSource because of .jar size
(wlfullclient.jar is 56MB).
Problem 2: Even if all .jar files are in the ../drivers directory, in
Birt 2.2.2 when previewing a report, the ContextClassLoader is a WebApp
classloader and the login security has the wrong classloader, so it cannot
find and load subject during the login.
I can provide a lot more details of what I have tried if you are
interested Œ
Requested solution:
I am looking for a solution that would let me configure BIRT so that I
would not have to modify my jdbc driver, but when Birt was accessing the
ODA JDBC data source using my JDBC driver it will have the correct .jar
files available to the correct class loader.
If that is not possible, then I need to know what the appropriate changes
would be to correctly let clients use the BIRT RCP Designer with our JDBC
driver.
Any help in this would be greatly appreciated.
Re: JDBC Driver classpath in BIRT RCP Designer Problem [message #368465 is a reply to message #368440] |
Mon, 01 June 2009 16:50 |
Originally posted by: jasonweathersby.windstream.net
David,
In 2.3.2 you can set the location of the drivers in the app context, but
I am not certain this will fix your issue. It should be able to load up
all the jars in the drivers directory. Can you open a bug with the
stacktrace you get when trying this method?
Jason
> them. I would like to determine a way that would work for both
> Birt2.2.2 and Birt2.3.2 versions if possible.
> application, as they are embedded in my application and it replaces the
> data source using a JNDI lookup, so my problem is only when previewing
> and viewing reports from the BIRT RCP Designer.
> and makes JEE calls to Weblogic when it intercepts certain data fields
> being returned in the result set. Also, part of this is using the Java
> Security Framework (JAAS) to log in to Weblogic.
> Problem Summaries:
> cannot find and load subject during the login.
> interested �Œ
> Requested solution:
> changes would be to correctly let clients use the BIRT RCP Designer with
> our JDBC driver.
Re: JDBC Driver classpath in BIRT RCP Designer Problem [message #368515 is a reply to message #368465] |
Fri, 05 June 2009 22:22 |
Junior Member |
Jason,
You indicated that I can set the "app context", can you refer me to some
documentation on this. (Is there a configuration setting that I can make
when viewing reports inside Birt RCP?) I must just be looking in the wrong
spot.
Also, for 2.3.2 I assume the problem I am having when all of my JDBC
driver dependencies in the .../driver directory is because it is scanning
my wlfullclient.jar file to see if it is a JDBC driver (since it is in the
.../driver directory.) If there is a way to move it out of that directory
and still have it in the classpath (and specifically in the path for the
ContextClassloader) I assume that should solve the problem.
If I put all of the driver info in the
...report.data.oda.jdbc_versionInfo/driver, as long as I don't go into the
DataSource, it appears to work correctly. When I go into the datasource,
then I just get the hourglass for a very long time (I will let it continue
to run and see if I get a response, it has been running for over 30
minutes so far).
If I can get a stacktrace after it blows up, I will create open a bug.
Thanks for your help.
David
Jason Weathersby wrote:
> David,
> Jason
>> Problem Summaries:
>> interested ï¿œÅ
>> Requested solution:
>> our JDBC driver.
Re: JDBC Driver classpath in BIRT RCP Designer Problem [message #368528 is a reply to message #368515] |
Mon, 08 June 2009 14:28 |
David,
Before modifying the app context in your app code try adding the
following to the beforeFactory script of a test report:
reportContext.getAppContext().put("OdaJDBCDriverClassPath",
"C:/apps/apache-tomcat-5.5.20/webapps/2.3rc1/WEB-INF/lib");
Obviously change the path. If this works
Take a look at this blog:
http://birtworld.blogspot.com/2008/11/birt-connection-poolin g-continued-again.html
If you are using the Viewer and not the API you will can set up the app
context like the following:
1 - add this like before you launch the viewer in your RCP app
ViewerPlugin.getDefault( ).getPluginPreferences(
).setValue("APPCONTEXT_EXTENSION_KEY", "MyAppContext");
Implement MyAppContext like:
package org.eclipse.birt.examples.rcpviewer;
import java.util.Map;
import org.eclipse.birt.report.viewer.api.AppContextExtension;
public class MyAppContext extends AppContextExtension{
public Map getAppContext(Map appContext) {
Map hm = super.getAppContext(appContext);
hm.put("PARENT_CLASSLOADER", PreviewBirtAction.class.getClassLoader());
//hm.put("webapplication.projectclasspath", "c:/jars/mjo.jar");
//add the jdbc driver path variable mention above here
return hm;
public String getName() {
// TODO Auto-generated method stub
return "MyAppContext";
Jason
David Johns wrote:
> Jason,
> wrong spot.
> scanning my wlfullclient.jar file to see if it is a JDBC driver (since
> it is in the ../driver directory.) If there is a way to move it out of
> that directory and still have it in the classpath (and specifically in
> the path for the ContextClassloader) I assume that should solve the
> problem.
> the DataSource, it appears to work correctly. When I go into the
> datasource, then I just get the hourglass for a very long time (I will
> let it continue to run and see if I get a response, it has been running
> for over 30 minutes so far).
> David
>> David,
>> but I am not certain this will fix your issue. It should be able to
>> load up all the jars in the drivers directory. Can you open a bug
>> with the stacktrace you get when trying this method?
>> Jason
>>> in the BIRT RCP Designer. I have run into two problems depending on
>>> the version of BIRT that I am running and I don¡Št know how to
>>> resolve them. I would like to determine a way that would work for
>>> both Birt2.2.2 and Birt2.3.2 versions if possible. I am not having a
>>> problem when I go to run the reports in my application, as they are
>>> embedded in my application and it replaces the data source using a
>>> driver and makes JEE calls to Weblogic when it intercepts certain
>>> data fields being returned in the result set. Also, part of this is
>>> using the Java Security Framework (JAAS) to log in to Weblogic.
>>> class path. However, I am getting class not found errors in BIRT
>>> during different circumstances when previewing a report.
>>> Problem Summaries:
>>> because it causes BIRT to hang when viewing the DataSource because of
>>> .jar size (wlfullclient.jar is 56MB).
>>> in Birt 2.2.2 when previewing a report, the ContextClassLoader is a
>>> WebApp classloader and the login security has the wrong classloader,
>>> so it cannot find and load subject during the login.
>>> interested ᅵ�
>>> Requested solution:
>>> I would not have to modify my jdbc driver, but when Birt was
>>> accessing the ODA JDBC data source using my JDBC driver it will have
>>> the correct .jar files available to the correct class loader. If that
>>> JDBC driver.
Re: JDBC Driver classpath in BIRT RCP Designer Problem [message #368672 is a reply to message #368528] |
Thu, 18 June 2009 14:46 |
Junior Member |
Jason,
Sorry about the delays in responses we are just getting out our release,
so this was moved down in priority, then put back as my top priority again.
I think I might have introduced some confusion in what I am trying to do.
I would like to be able to create a set of instructions for report
designers that will be using our product on how to configure their BIRT
RCP Report Designer. After our clients have created a report, they can
then inport the report into our application, and everything is working
correctly as we override the DataSource that they configure in the report.
However, when designing the report, our JDBC driver needs to connect to
the Weblogic 10.3 appserver to resolve some of the data fields (derived
fields). Our driver has an option that can be specified to not attempt to
resolve these fields and they will return a null (which is what they are
doing now). However, our requirement has changed so that now I must
provide the values for the derived fields. This is where our driver is
having problems when it is attempting to connect to weblogic.
So I am trying to create step by step instructions for our clients of what
they need to do inside the BIRT RCP Designer to create a valid data source
to use while designing the reports. (We replace the datasource inside our
App, so it is only for the Report Designer tool that this matters).
That being said (sorry it is so verbose), I attempted adding the
beforeFactory script that you recommended, and it did not work. I got a
java.lang.NoClassDefFoundError when doing a connection test inside the
Edit Data Source window.
In Birt 2.2.2 I have been able to make some modifications to get items to
work, however, I have changed the ContextClassLoader when getting a
connection to the class loader of my driver class (and don't change it
back). I am not sure what the ramifications of that are so I am trying to
handle this properly.
Also, I realized if I can connect to the Weblogic DataSource, that should
also provide a solution for me. I am having problems doing that, however,
I will post that info on a different thread that seems to have a more
appropriate title.
Thank you for your help and comments.
David
> David,
> @Override
> return hm;
> @Override
> Jason
> David Johns wrote:
>> Jason,
>> wrong spot.
>> problem.
>> David
>>> David,
>>> Jason
>>>> the version of BIRT that I am running and I donáÃ
t know how to
>>>> This works fine outside of BIRT when it has everything in itáÃ
s
>>>> Problem Summaries:
>>>> Problem 1: Cannot put all .jar files in áK/drivers directory
>>>> interested ï¿ÅÃ
ᅵ
>>>> Requested solution:
>>>> JDBC driver.
Re: JDBC Driver classpath in BIRT RCP Designer Problem [message #368684 is a reply to message #368672] |
Thu, 18 June 2009 19:18 |
David,
Which ODA are you using to design the reports (Your own or JDBC)?
Jason
David Johns wrote:
> Jason,
> do. I would like to be able to create a set of instructions for report
> to resolve these fields and they will return a null (which is what they
> are doing now). However, our requirement has changed so that now I must
> what they need to do inside the BIRT RCP Designer to create a valid data
> source to use while designing the reports. (We replace the datasource
> inside our App, so it is only for the Report Designer tool that this
> matters).
> to work, however, I have changed the ContextClassLoader when getting a
> to handle this properly.
> should also provide a solution for me. I am having problems doing that,
> however, I will post that info on a different thread that seems to have
> a more appropriate title.
> David
>> David,
>> app context like the following:
>> @Override
>> return hm;
>> @Override
>> Jason
>> David Johns wrote:
>>> Jason,
>>> some documentation on this. (Is there a configuration setting that I
>>> can make when viewing reports inside Birt RCP?) I must just be
>>> looking in the wrong spot.
>>> (since it is in the ../driver directory.) If there is a way to move
>>> it out of that directory and still have it in the classpath (and
>>> specifically in the path for the ContextClassloader) I assume that
>>> will let it continue to run and see if I get a response, it has been
>>> running for over 30 minutes so far).
>>> David
>>>> David,
>>>> Jason
>>>>> reports in the BIRT RCP Designer. I have run into two problems
>>>>> depending on the version of BIRT that I am running and I don�¡�
>>>>> t know how to resolve them. I would like to determine a way that
>>>>> would work for both Birt2.2.2 and Birt2.3.2 versions if possible. I
>>>>> the data source using a JNDI lookup, so my problem is only when
>>>>> previewing and viewing reports from the BIRT RCP Designer.
>>>>> is using the Java Security Framework (JAAS) to log in to Weblogic.
>>>>> This works fine outside of BIRT when it has everything in it�¡�
>>>>> s class path. However, I am getting class not found errors in BIRT
>>>>> Problem Summaries:
>>>>> Problem 1: Cannot put all .jar files in �¡K/drivers directory
>>>>> of .jar size (wlfullclient.jar is 56MB).
>>>>> classloader, so it cannot find and load subject during the login.
>>>>> interested ï¿��ᅵ
>>>>> Requested solution:
>>>>> that I would not have to modify my jdbc driver, but when Birt was
>>>>> have the correct .jar files available to the correct class loader.
>>>>> with our JDBC driver.
Re: JDBC Driver classpath in BIRT RCP Designer Problem [message #368686 is a reply to message #368684] |
Thu, 18 June 2009 19:31 |
Junior Member |
Jason,
I am using the ODA_JDBC bridge that comes with the designer.
David
> David,
> Jason
> David Johns wrote:
>> Jason,
>> matters).
>> David
>>> David,
>>> @Override
>>> return hm;
>>> @Override
>>> Jason
>>> David Johns wrote:
>>>> Jason,
>>>> David
>>>>> David,
>>>>> Jason
donÃᅵáÃï¿œ
itÃᅵáÃï¿œ
>>>>>> Problem Summaries:
>>>>>> Problem 1: Cannot put all .jar files in ÃᅵáK/drivers directory
>>>>>> interested ïÿÃ
ï¿œÃᅵï¿Å
>>>>>> Requested solution:
Re: JDBC Driver classpath in BIRT RCP Designer Problem [message #368697 is a reply to message #368686] |
Fri, 19 June 2009 01:20 |
David,
I assume you mean just the JDBC ODA. The DTP project does support a
Bridge extension which is somewhat different. In the designer the user
has to specify what class is used to connect when using the JDBC plugin.
Which one are are you specifying (Apart from the issue you are having
with JNDI).
On the JNDI issue that should be working. I am still looking at it.
Jason
David Johns wrote:
> Jason,
> David
>> David,
>> Jason
>> David Johns wrote:
>>> Jason,
>>> release, so this was moved down in priority, then put back as my top
>>> priority again.
>>> report designers that will be using our product on how to configure
>>> their BIRT RCP Report Designer. After our clients have created a
>>> report, they can then inport the report into our application, and
>>> everything is working correctly as we override the DataSource that
>>> to the Weblogic 10.3 appserver to resolve some of the data fields
>>> (derived fields). Our driver has an option that can be specified to
>>> not attempt to resolve these fields and they will return a null
>>> (which is what they are doing now). However, our requirement has
>>> changed so that now I must provide the values for the derived fields.
>>> This is where our driver is having problems when it is attempting to
>>> data source to use while designing the reports. (We replace the
>>> datasource inside our App, so it is only for the Report Designer tool
>>> that this matters).
>>> got a java.lang.NoClassDefFoundError when doing a connection test
>>> inside the Edit Data Source window.
>>> items to work, however, I have changed the ContextClassLoader when
>>> getting a connection to the class loader of my driver class (and
>>> don't change it back). I am not sure what the ramifications of that
>>> are so I am trying to handle this properly.
>>> that, however, I will post that info on a different thread that seems
>>> to have a more appropriate title.
>>> David
>>>> David,
>>>> @Override
>>>> return hm;
>>>> @Override
>>>> Jason
>>>> David Johns wrote:
>>>>> Jason,
>>>>> I can make when viewing reports inside Birt RCP?) I must just be
>>>>> JDBC driver dependencies in the .../driver directory is because it
>>>>> is scanning my wlfullclient.jar file to see if it is a JDBC driver
>>>>> move it out of that directory and still have it in the classpath
>>>>> (and specifically in the path for the ContextClassloader) I assume
>>>>> into the DataSource, it appears to work correctly. When I go into
>>>>> the datasource, then I just get the hourglass for a very long time
>>>>> (I will let it continue to run and see if I get a response, it has
>>>>> been running for over 30 minutes so far).
>>>>> David
>>>>>> David,
>>>>>> context, but I am not certain this will fix your issue. It should
>>>>>> be able to load up all the jars in the drivers directory. Can you
>>>>>> open a bug with the stacktrace you get when trying this method?
>>>>>> Jason
> don�ᅵ�¡�ᅵ
>>>>>>> replaces the data source using a JNDI lookup, so my problem is
>>>>>>> only when previewing and viewing reports from the BIRT RCP Designer.
>>>>>>> and querying the data. The driver wraps the normal sql server
>>>>>>> jdbc driver and makes JEE calls to Weblogic when it intercepts
>>>>>>> certain data fields being returned in the result set. Also, part
>>>>>>> of this is using the Java Security Framework (JAAS) to log in to
>>>>>>> Weblogic.
> it�ᅵ�¡�ᅵ
>>>>>>> BIRT during different circumstances when previewing a report.
>>>>>>> Problem Summaries:
>>>>>>> Problem 1: Cannot put all .jar files in �ᅵ�¡K/drivers
>>>>>>> directory because it causes BIRT to hang when viewing the
>>>>>>> DataSource because of .jar size (wlfullclient.jar is 56MB).
>>>>>>> directory, in Birt 2.2.2 when previewing a report, the
>>>>>>> ContextClassLoader is a WebApp classloader and the login security
>>>>>>> has the wrong classloader, so it cannot find and load subject
>>>>>>> during the login.
>>>>>>> interested �¯�¿�ᅵ�ᅵï¿�
>>>>>>> Requested solution:
>>>>>>> loader. If that is not possible, then I need to know what the
>>>>>>> appropriate changes would be to correctly let clients use the
>>>>>>> BIRT RCP Designer with our JDBC driver.
Re: JDBC Driver classpath in BIRT RCP Designer Problem [message #368707 is a reply to message #368697] |
Fri, 19 June 2009 15:28 |
Junior Member |
Jason,
You are correct in your assumption. I have put our custom JDBC Driver in
that directory (it is a wrapper for a MS SQL Server JDBC driver with some
customization to handle the processing of our derived fields. Our driver
has a dependency on three other .jar's. One is sqljdbc.jar (MS Sql's
JDBC), we have a custom AjConnectors.jar that we use to connect to the
specific app server, and the wlfullclient.jar (weblogic's full client jar)
which is the one that is very large.
To get the birt 2.2.2 to work I added a manifest entry in our driver jar
to point to a "./lib/AjConnectors.jar" and it has a manifest entry that
points to "wlfullclient.jar". I put the jars in the following structure:
.../org.eclipse.birt.report.data.oda.jdbc_<ver>/drivers
AjDriver.jar
sqljdbc.jar
/lib
AjConnectors.jar
wlfullclient.jar
This seemed to solve the problem except when logging in to make a call to
the appserver, the java security classes switch and use the context class
loader which is the webapp viewer (in some cases) and the login fails with
a class not found exception. So it worked when doing a DataSet preview
because it was using the ODA datasource, but it failed when using the
viewer as it was using the webapp viewer class loader. (Didn't remember
the correct names of the class loaders, but that was the general idea).
In birt 2.3.2 when I put the .jar files in the above configuration, it
appears that the classloader does not find the relationship to the
AjConnectors.jar file when doing a test connection (I am getting a class
not found exception for one of the classes in the AjConnectors.jar.
So I am hoping that I am just going about setting up everything wrong, and
once I figure it out it will all work nicely ;-)
I had one other anomoly on the JNDI issue, I will add a note to that
thread.
Here is the stack trace that I got when running the Birt 2.3.2 with the
configuration as stated above. The
com.cu.ajility.appserver.exception.ConnectorServiceNotFoundE xception class
is in the AjConnectors.jar file.
!SESSION 2009-06-19 08:13:51.368
eclipse.buildId=unknown
java.version=1.6.0_07
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui 4 0 2009-06-19 08:14:14.305
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.NoClassDefFoundError:
com/cu/ajility/appserver/exception/ConnectorServiceNotFoundE xception
com.cu.ajent.sql.AjConnection.getJdbcServiceDelegate(AjConne ction.java:953)
at com.cu.ajent.sql.AjDriver.connect(AjDriver.java:342)
org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager$Wrap pedDriver.connect(JDBCDriverManager.java:1082)
at java.sql.DriverManager.getConnection(Unknown Source)
org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.doCo nnect(JDBCDriverManager.java:218)
org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.getC onnection(JDBCDriverManager.java:153)
org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.tryC reateConnection(JDBCDriverManager.java:654)
org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.test Connection(JDBCDriverManager.java:560)
org.eclipse.birt.report.data.oda.jdbc.ui.util.DriverLoader.t estConnection(DriverLoader.java:118)
org.eclipse.birt.report.data.oda.jdbc.ui.profile.JDBCSelecti onPageHelper.testConnection(JDBCSelectionPageHelper.java:635 )
org.eclipse.birt.report.data.oda.jdbc.ui.profile.JDBCSelecti onPageHelper.access$7(JDBCSelectionPageHelper.java:619)
org.eclipse.birt.report.data.oda.jdbc.ui.profile.JDBCSelecti onPageHelper$7.widgetSelected(JDBCSelectionPageHelper.java:5 41)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
org.eclipse.birt.report.designer.internal.ui.dialogs.BaseDia log.open(BaseDialog.java:112)
org.eclipse.birt.report.designer.internal.ui.views.data.prov iders.DataSourceNodeProvider.performEdit(DataSourceNodeProvi der.java:88)
org.eclipse.birt.report.designer.internal.ui.views.DefaultNo deProvider.performRequest(DefaultNodeProvider.java:410)
org.eclipse.birt.report.designer.internal.ui.views.actions.E ditAction.doAction(EditAction.java:85)
org.eclipse.birt.report.designer.internal.ui.views.actions.A bstractElementAction.run(AbstractElementAction.java:66)
org.eclipse.birt.report.designer.internal.ui.views.RenameLis tener.doubleClick(RenameListener.java:214)
org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredV iewer.java:799)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:880)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(S tructuredViewer.java:797)
org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSel ect(AbstractTreeViewer.java:1419)
org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSe lected(StructuredViewer.java:1173)
org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEven t(OpenStrategy.java:237)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.ja va:234)
org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:295)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2348)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 00)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:495)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:490)
org.eclipse.birt.report.designer.ui.rcp.DesignerApplication. run(DesignerApplication.java:38)
org.eclipse.equinox.internal.app.EclipseAppContainer.callMet hodWithException(EclipseAppContainer.java:574)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:195)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
Caused by: java.lang.ClassNotFoundException:
org.eclipse.birt.core.framework.URLClassLoader.findClass(URL ClassLoader.java:159)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
... 66 more
> David,
> with JNDI).
> Jason
> David Johns wrote:
>> Jason,
>> David
>>> David,
>>> Jason
>>> David Johns wrote:
>>>> Jason,
>>>> priority again.
>>>> that this matters).
>>>> David
>>>>> David,
>>>>> @Override
>>>>> return hm;
>>>>> @Override
>>>>> Jason
>>>>> David Johns wrote:
>>>>>> Jason,
>>>>>> David
>>>>>>> David,
>>>>>>> Jason
>>>>>>>> dont know how to resolve them. I would like to determine a way that
>>>>>>>> Weblogic.
>>>>>>>> its class path. However, I am getting class not found errors in
>>>>>>>> Problem Summaries:
>>>>>>>> Problem 1: Cannot put all .jar files in ../drivers
>>>>>>>> during the login.
>>>>>>>> interested
>>>>>>>> Requested solution:
Re: JDBC Driver classpath in BIRT RCP Designer Problem [message #368719 is a reply to message #368707] |
Sat, 20 June 2009 05:30 |
David,
If you have added it to the manifest it should be picking it up. You
may get this error if you have more than one copy in your cp.
I wish I had wl here to test it.
Jason
David Johns wrote:
> Jason,
> in that directory (it is a wrapper for a MS SQL Server JDBC driver with
> some customization to handle the processing of our derived fields. Our
> driver has a dependency on three other .jar's. One is sqljdbc.jar (MS
> Sql's JDBC), we have a custom AjConnectors.jar that we use to connect to
> the specific app server, and the wlfullclient.jar (weblogic's full
> client jar) which is the one that is very large.
> AjDriver.jar
> sqljdbc.jar
> /lib
> AjConnectors.jar
> wlfullclient.jar
> to the appserver, the java security classes switch and use the context
> class loader which is the webapp viewer (in some cases) and the login
> fails with a class not found exception. So it worked when doing a
> DataSet preview because it was using the ODA datasource, but it failed
> when using the viewer as it was using the webapp viewer class loader.
> (Didn't remember the correct names of the class loaders, but that was
> the general idea).
> and once I figure it out it will all work nicely ;-)
> thread.
> class is in the AjConnectors.jar file.
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> ... 66 more
>> David,
>> user has to specify what class is used to connect when using the JDBC
>> plugin. Which one are are you specifying (Apart from the issue you
>> are having with JNDI).
>> Jason
>> David Johns wrote:
>>> Jason,
>>> David
>>>> David,
>>>> Jason
>>>> David Johns wrote:
>>>>> Jason,
>>>>> top priority again.
>>>>> to do. I would like to be able to create a set of instructions for
>>>>> connect to the Weblogic 10.3 appserver to resolve some of the data
>>>>> fields (derived fields). Our driver has an option that can be
>>>>> specified to not attempt to resolve these fields and they will
>>>>> return a null (which is what they are doing now). However, our
>>>>> requirement has changed so that now I must provide the values for
>>>>> the derived fields. This is where our driver is having problems
>>>>> of what they need to do inside the BIRT RCP Designer to create a
>>>>> valid data source to use while designing the reports. (We replace
>>>>> the datasource inside our App, so it is only for the Report
>>>>> seems to have a more appropriate title.
>>>>> David
>>>>>> David,
>>>>>> the app context like the following:
>>>>>> @Override
>>>>>> "c:/jars/mjo.jar");
>>>>>> return hm;
>>>>>> @Override
>>>>>> Jason
>>>>>> David Johns wrote:
>>>>>>> Jason,
>>>>>>> to some documentation on this. (Is there a configuration setting
>>>>>>> that I can make when viewing reports inside Birt RCP?) I must
>>>>>>> just be looking in the wrong spot.
>>>>>>> it is scanning my wlfullclient.jar file to see if it is a JDBC
>>>>>>> driver (since it is in the ../driver directory.) If there is a
>>>>>>> way to move it out of that directory and still have it in the
>>>>>>> into the datasource, then I just get the hourglass for a very
>>>>>>> long time (I will let it continue to run and see if I get a
>>>>>>> response, it has been running for over 30 minutes so far).
>>>>>>> bug.
>>>>>>> David
>>>>>>>> David,
>>>>>>>> should be able to load up all the jars in the drivers
>>>>>>>> directory. Can you open a bug with the stacktrace you get when
>>>>>>>> trying this method?
>>>>>>>> Jason
>>>>>>>>> depending on the version of BIRT that I am running and I dont
>>>>>>>>> possible. I am not having a problem when I go to run the
>>>>>>>>> reports in my application, as they are embedded in my
>>>>>>>>> application and it replaces the data source using a JNDI
>>>>>>>>> part of this is using the Java Security Framework (JAAS) to log
>>>>>>>>> in to Weblogic.
>>>>>>>>> This works fine outside of BIRT when it has everything in its
>>>>>>>>> Problem Summaries:
>>>>>>>>> Problem 1: Cannot put all .jar files in ../drivers directory
>>>>>>>>> security has the wrong classloader, so it cannot find and load
>>>>>>>>> are interested
>>>>>>>>> Requested solution:
>>>>>>>>> was accessing the ODA JDBC data source using my JDBC driver it
>>>>>>>>> will have the correct .jar files available to the correct class
Current Time: Fri Mar 29 07:02:39 GMT 2024
Powered by FUDForum. Page generated in 0.03471 seconds
