Re: Nested XML [message #368468 is a reply to message #368439] |
Mon, 01 June 2009 17:29 |
Originally posted by: jasonweathersby.windstream.net
Anand,
Have you seen this tutorial?
http://www.birt-exchange.org/devshare/designing-birt-reports /563-birt-xml-data-source-tutorial/#description
You can also use nested datsets by using nested tables. In BIRT 2.5 the
xml datasource now supports parameters making this much easier. You can
also use a joint dataset and hide any column you want. The easiest way
to do this is to not add the column to any table.
Jason
Anand Mandhre wrote:
> hello people,
> How should someone work with nested xml ? My problem is while creating a
> dataset from nested xml.
> I want to make dataset which represent (see xml below) release(1..n) +
> open issue(0..n)+solved issues(0...n)+remarks(0...n)
> 1) Is it possible to have dataset within another dataset.
> 2) Is it possible to combine datasets but then hide column used for
> making join.
> <Relase id="1" >
> <Open Issue>
> <Issue>
> <name></name>
> </Issue>
> <Issue>
> <name></name>
> </Issue>
> </Open Issue>
> <Solved Issue>
> <Issue>
> <name></name>
> </Issue>
> <Issue>
> <name></name>
> </Issue>
> </Solved Issue>
> <Remarks>
> <Issue>
> <name></name>
> </Issue>
> <Issue>
> <name></name>
> </Issue>
> </Remarks>
> </Release>
> <Release id="2">
> ...></release>
FUDForum. Page generated in 0.02336 seconds
