Re: Alternate Table Views [message #368348 is a reply to message #368345] |
Fri, 22 May 2009 14:38 |
Originally posted by: jasonweathersby.windstream.net
Mitch,
Are you basing which table is displayed by a report parameter?
If so you can name both tables (General Property) and then in the
beforeFactory event just drop the one you do not need.
//bool param
if( params["droptable"].value ){
reportContext.getDesignHandle().findElement("mytable").drop();
Jason
Mitch Christensen wrote:
> Hey,
> I need to create to separate tables that are driven from the same Data
> Set. I will only ever display one or the other, and I would like to
> avoid executing the SQL query twice even though I only consume the
> result set once.
> It seems that I've seen this before, but I can't find it.
> Is there a way to disable/delete a table such that it doesn't display
> and doesn't cause the Data Set to re-execute the SQL query?
> Thanks.
> -Mitch Christensen
FUDForum. Page generated in 0.03108 seconds
