Re: Do not prompt parameter input [message #368201 is a reply to message #368200] |
Tue, 12 May 2009 03:57 |
Larry,
If the parameters are in the url the box should not be displayed. What
exact version are you using?
Jason
Larry Li wrote:
> Hello,
> I use the viewer in birt-runtime-2_5_0\WebViewerExample. Before a report
> is opened, there is always a window asking me to enter the parameters.
> Is there a way to disable this? because I already provide the parameters
> in the url.
> Thank you.
> Larry
Re: Do not prompt parameter input [message #368212 is a reply to message #368208] |
Tue, 12 May 2009 15:37 |
Larry,
Can you log a bug for this?
Jason
Larry Li wrote:
> Jason,
> Both my BIRT designer and BIRT runtime are 2.5.0. I found it doesn't
> prompt the parameter window if I don't check "Is Required" for all of
> the parameters. On the other hand, if any of them is required, it will
> ask me to enter parameter values even though they are in the url.
> Larry
>> Larry,
>> What exact version are you using?
>> Jason
>> Larry Li wrote:
>>> Hello,
>>> I use the viewer in birt-runtime-2_5_0WebViewerExample. Before a
>>> report is opened, there is always a window asking me to enter the
>>> parameters. Is there a way to disable this? because I already provide
>>> the parameters in the url.
>>> Thank you.
>>> Larry
Re: Do not prompt parameter input [message #368215 is a reply to message #368212] |
Tue, 12 May 2009 16:39 |
Larry Li Messages: 32 Registered: July 2009 |
Member |
Done!
By the way, if I set the parameter to both "Is Required" and "Hidden",
then there is no prompt.
Larry
> Larry,
> Jason
> Larry Li wrote:
>> Jason,
>> Larry
>>> Larry,
>>> Jason
>>> Larry Li wrote:
>>>> Hello,
>>>> Thank you.
>>>> Larry
FUDForum. Page generated in 0.02861 seconds
