Home » Archived » BIRT » PDF - Generation Time...
Re: PDF - Generation Time... [message #368127 is a reply to message #368125] |
Tue, 05 May 2009 14:32 |
Patrick,
Can you post the report?
Jason
Patrick wrote:
> Hello!:-)
> I'have a report, where the html generation for a preview takes about 39
> seconds. When i try to preview the report in pdf, it's not done in 4
> Minutes. Is that normal? My other reports have about 50% time -
> diference at maximum. If its not normal, how can i speed up the report
> generation in pdf?
> Thanks!
> (BIRT 2.1.3, RCP Designer )
Re: PDF - Generation Time... [message #368130 is a reply to message #368127] |
Tue, 05 May 2009 15:13 |
Patrick Messages: 48 Registered: July 2009 |
Member |
Here it comes...
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.7"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version 1.0.1 Build
<20051130-1157></property>
<property name="units">mm</property>
<property name="comments">Copyright (c) 2006 <<Your Company Name
here>></property>
<list-property name="propertyBindings">
<structure>
<property name="name">queryText</property>
<property name="id">42</property>
<expression name="value">"Select st.cusid, cu.NAME1 as
CusName1, cu.NAME2 as CusName2, st.artid, st.PACID as VPK, st.NAME1,
st.NAME2, cu.bunid, SUM(st.TURNOVER08) as UmsLfdJahr, SUM(st.TURNOVER07)
as UmsVorjahr, SUM(st.TURNOVER06) as UmsVorvorjahr,SUM(st.QUANTITY08) as
MenLfdJahr, SUM(st.QUANTITY07) as MenVorjahr, SUM(st.QUANTITY06) as
MenVorvorjahr,SUM(st.PROFIT08) as RohgLfdJahr, SUM(st.PROFIT07) as
RohgVorjahr, SUM(st.PROFIT06) as RohgVorvorjahr from
KINFO.STAT"+params["bunId"]+"01 st, KINFO.CUSTOMER01 cu where cu.bunid =
'"+params["bunId"]+"' and st.cusid = cu.cusid group by cu.bunid,
st.CUSID, cu.NAME1, cu.NAME2, st.artid, st.PACID, st.NAME1, st.NAME2 order
by cu.NAME1, st.NAME1 asc, st.NAME2 asc, st.PACID asc"</expression>
</structure>
<structure>
<property name="id">46</property>
<expression name="value">"Select NAME from KINFO.BUSUNTP where
BUNID = '"+params["bunId"]+"'"</expression>
</structure>
</list-property>
<parameters>
<scalar-parameter name="bunId" id="45">
<property name="valueType">static</property>
<property name="dataType">string</property>
<property name="controlType">text-box</property>
<property name="defaultValue">ST</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
<scalar-parameter name="username" id="505">
<property name="defaultValue">Max Mustermann</property>
</structure>
</scalar-parameter>
<scalar-parameter name="DatenVorhanden" id="979">
<property name="dataType">integer</property>
<property name="defaultValue">1</property>
</structure>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source extensionID="com.iq.oda.ws" name="Debala04"
id="41"/>
</data-sources>
<data-sets>
<oda-data-set extensionID="com.iq.oda.ws.dataSet"
name="WSDB2_StatData_QuantityPerYear" id="42">
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ARTID</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">NAME1</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">NAME2</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">VPK</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">UMSLFDJAHR</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">UMSVORJAHR</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">UMSVORVORJAHR</property>
</structure>
<structure>
<property name="position">8</property>
<property name="name">MENLFDJAHR</property>
</structure>
<structure>
<property name="position">9</property>
<property name="name">MENVORJAHR</property>
</structure>
<structure>
<property name="position">10</property>
<property name="name">MENVORVORJAHR</property>
</structure>
<structure>
<property name="position">11</property>
<property name="name">ROHGLFDJAHR</property>
</structure>
<structure>
<property name="position">12</property>
<property name="name">ROHGVORJAHR</property>
</structure>
<structure>
<property name="position">13</property>
<property name="name">ROHGVORVORJAHR</property>
</structure>
<structure>
<property name="position">14</property>
<property name="name">CUSID</property>
</structure>
<structure>
<property name="position">15</property>
<property name="name">CUSNAME1</property>
</structure>
<structure>
<property name="position">16</property>
<property name="name">CUSNAME2</property>
</structure>
<structure>
<property name="position">17</property>
<property name="name">BUNID</property>
</structure>
</list-property>
</structure>
<property name="rowFetchLimit">0</property>
<property name="dataSource">Debala04</property>
<structure>
<property name="nativeName">ARTID</property>
</structure>
<structure>
<property name="nativeName">NAME1</property>
</structure>
<structure>
<property name="nativeName">NAME2</property>
</structure>
<structure>
<property name="nativeName">VPK</property>
</structure>
<structure>
<property name="nativeName">UMSLFDJAHR</property>
</structure>
<structure>
<property name="nativeName">UMSVORJAHR</property>
</structure>
<structure>
<property name="nativeName">UMSVORVORJAHR</property>
</structure>
<structure>
<property name="nativeName">MENLFDJAHR</property>
</structure>
<structure>
<property name="nativeName">MENVORJAHR</property>
</structure>
<structure>
<property name="nativeName">MENVORVORJAHR</property>
</structure>
<structure>
<property name="nativeName">ROHGLFDJAHR</property>
</structure>
<structure>
<property name="nativeName">ROHGVORJAHR</property>
</structure>
<structure>
<property name="nativeName">ROHGVORVORJAHR</property>
</structure>
<structure>
<property name="nativeName">CUSID</property>
</structure>
<structure>
<property name="nativeName">CUSNAME1</property>
</structure>
<structure>
<property name="nativeName">CUSNAME2</property>
</structure>
<structure>
<property name="nativeName">BUNID</property>
</structure>
</list-property>
<property name="queryText">Select st.artid, st.NAME1,
st.NAME2, st.PACID as VPK, SUM(st.TURNOVER08) as UmsLfdJahr,
SUM(st.TURNOVER07) as UmsVorjahr, SUM(st.TURNOVER06) as UmsVorvorjahr,
SUM(st.QUANTITY08) as MenLfdJahr, SUM(st.QUANTITY07) as MenVorjahr,
SUM(st.QUANTITY06) as MenVorvorjahr, SUM(st.PROFIT08) as RohgLfdJahr,
SUM(st.PROFIT07) as RohgVorjahr, SUM(st.PROFIT06) as RohgVorvorjahr,
st.cusid, cu.NAME1 as CUSNAME1, cu.NAME2 as CUSNAME2, cu.BUNID from
KINFO.STATST01 st, KINFO.CUSTOMER01 cu where st.cusid = cu.cusid and 'ST'
= cu.BUNID group by st.artid, st.PACID, st.NAME1, st.NAME2,
st.PACID,st.cusid, cu.NAME1, cu.NAME2, cu.BUNID order by st.PACID,
lower(st.NAME1) asc</property>
</oda-data-set>
name="WSDB2_BUNID_NAME" id="46">
<structure>
<property name="name">NAME</property>
</structure>
</list-property>
</structure>
<structure>
<property name="nativeName">NAME</property>
</structure>
</list-property>
<property name="queryText">Select NAME from KINFO.BUSUNTP
where BUNID = 'ST'</property>
</oda-data-set>
</data-sets>
<styles>
<style name="Header" id="435">
<property name="backgroundColor">#FF8040</property>
<property name="fontWeight">bold</property>
<property name="borderBottomStyle">none</property>
<property name="borderBottomWidth">thin</property>
<property name="borderTopStyle">none</property>
<property name="borderTopWidth">thin</property>
</style>
<style name="Font_Number" id="515">
<property name="fontFamily">"Arial"</property>
<property name="fontSize">9pt</property>
<structure name="numberFormat">
<property name="category">Currency</property>
<property name="pattern">#,##0</property>
</structure>
<structure name="stringFormat">
</structure>
</style>
<style name="Kruse_TableHeader" id="1424">
<property name="color">#165A87</property>
</style>
<style name="Align" id="1465">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<property name="type">a4</property>
<property name="orientation">landscape</property>
<property name="topMargin">10mm</property>
<property name="leftMargin">20mm</property>
<property name="bottomMargin">10mm</property>
<property name="rightMargin">20mm</property>
<page-header>
<grid id="53">
<property name="marginTop">0%</property>
<property name="marginLeft">0%</property>
<property name="marginBottom">0pt</property>
<property name="marginRight">0%</property>
<property name="verticalAlign">middle</property>
<property name="canShrink">false</property>
<property name="height">0%</property>
<property name="width">257mm</property>
<method
name="onPrepare"><![CDATA[if(reportContext.getOutputFormat()== "html")
this.getStyle().marginTop = "1%";
this.getStyle().textAlign = "center";
}]]></method>
<column id="54">
<property name="width">30%</property>
</column>
<column id="55">
<property name="width">40%</property>
</column>
<column id="56">
</column>
<row id="57">
<property name="height">0.4166666667in</property>
<property name="backgroundColor">#FFFFFF</property>
<cell id="58">
<property
name="borderBottomColor">#165A87</property>
<property
name="borderBottomStyle">solid</property>
<property
<property name="paddingTop">0pt</property>
<property name="paddingLeft">0pt</property>
<property name="paddingBottom">4pt</property>
<property name="textAlign">left</property>
<image id="1113">
<property name="source">embed</property>
<property name="imageName">K.png</property>
</image>
</cell>
<cell id="59">
<property
<property
<property
<property name="paddingTop">4pt</property>
<property name="textAlign">center</property>
<text id="514">
<property
<property name="fontSize">14pt</property>
<property
<property
name="contentType">html</property>
<text-property
name="content"><![CDATA[Jahreswerte Kunden ]]></text-property>
</text>
</cell>
<cell id="60">
<property
<property
<property
<property name="paddingBottom">0pt</property>
<property name="paddingRight">0pt</property>
<property name="textAlign">right</property>
</cell>
</row>
<row id="1475">
<cell id="1476">
</cell>
<cell id="1477">
</cell>
<cell id="1478">
<text id="1076">
<property
<property name="marginTop">0mm</property>
<property name="marginLeft">0pt</property>
<property
name="marginBottom">0mm</property>
<property
<text-property
name="content"><![CDATA[Geschäftsbereich]]></text-property >
</text>
<data id="930">
<property
<property name="marginTop">9px</property>
<property
<property
name="dataSet">WSDB2_BUNID_NAME</property>
<list-property name="boundDataColumns">
<structure>
<property
<expression
name="expression">dataSetRow["NAME"]</expression>
<property
</structure>
</list-property>
<property
name="resultSetColumn">NAME</property>
</data>
</cell>
</row>
<row id="1111">
<cell id="1112">
<property name="colSpan">3</property>
<property name="rowSpan">1</property>
<property
name="borderTopColor">#165A87</property>
<property
name="borderTopStyle">solid</property>
<text id="1110">
<property
name="contentType">auto</property>
<text-property name="content"><![CDATA[
]]></text-property>
</text>
</cell>
</row>
</grid>
</page-header>
<page-footer>
<grid id="494">
<method
name="onPrepare"><![CDATA[if(reportContext.getOutputFormat() == "html")
}]]></method>
<column id="1095">
</column>
<column id="495">
<property name="width">7.5%</property>
</column>
<column id="496">
<property name="width">5%</property>
</column>
<column id="497">
</column>
<column id="1097">
</column>
<row id="1098">
<list-property name="visibility">
<structure>
<property name="format">html</property>
<expression
name="valueExpr">true</expression>
</structure>
</list-property>
<cell id="1099">
<property name="colSpan">5</property>
<property
<property
<text id="1104">
<property
]]></text-property>
</text>
</cell>
</row>
<row id="1479">
<structure>
<property name="format">pdf</property>
<expression
</structure>
</list-property>
<cell id="1480"/>
<cell id="1481"/>
<cell id="1482"/>
<cell id="1483"/>
<cell id="1484"/>
</row>
<row id="498">
<cell id="1094">
<text id="1105">
<property
<method
name="onCreate"><![CDATA[if(reportContext.getOutputFormat() == "html")
this.getStyle().textAlign = "left";
}]]></method>
<property
<text-property
name="content"><![CDATA[Ersteller: <VALUE-OF>var datum = new Date();
//Uhrzeit
var stunden = "00" + datum.getHours();
stunden = stunden.substr(stunden.length-2, 2);
var minuten = "00" + datum.getMinutes();
minuten = minuten.substr(minuten.length-2, 2);
var sekunden = "00" + datum.getSeconds();
sekunden = sekunden.substr(sekunden.length-2, 2);
var uhrzeit = stunden+":"+minuten+":"+sekunden;
//Datum
var tag = "00" + datum.getDate();
tag = tag.substr(tag.length-2, 2);
var monat = "00" + (datum.getMonth()+1);
monat = monat.substr(monat.length-2, 2);
var jahr = "00" + datum.getFullYear();
jahr = jahr.substr(jahr.length-4, 4);
var date = tag+"."+monat+"."+jahr;
//Zusammenbauen
params["username"] + " " + date + " " +
uhrzeit;</VALUE-OF>]]></text-property>
</text>
</cell>
<cell id="499">
<auto-text id="500">
<property
<structure>
<property
<expression
</structure>
</list-property>
<property
name="type">page-number</property>
</auto-text>
</cell>
<cell id="501">
<text id="502">
<property
<property
<structure>
<property
<expression
</structure>
</list-property>
<property
name="contentType">plain</property>
<text-property
name="content"><![CDATA[/]]></text-property>
</text>
</cell>
<cell id="503">
<auto-text id="504">
<property
<structure>
<property
<expression
</structure>
</list-property>
<property name="type">total-page</property>
</auto-text>
</cell>
<cell id="1096">
<text id="1546">
<property
<property
name="dataSet">WSDB2_StatData_QuantityPerYear</property>
<structure>
<property
<expression
name="expression">dataSetRow["ARTID"]</expression>
<property
</structure>
<structure>
<property
<expression
name="expression">dataSetRow["NAME1"]</expression>
<property
</structure>
<structure>
<property
<expression
name="expression">dataSetRow["NAME2"]</expression>
<property
</structure>
<structure>
<property
<expression
name="expression">dataSetRow["VPK"]</expression>
<property
</structure>
<structure>
<property
<expression
name="expression">dataSetRow["UMSLFDJAHR"]</expression>
<property
</structure>
<structure>
<property
<expression
name="expression">dataSetRow["UMSVORJAHR"]</expression>
<property
</structure>
<structure>
<property
<expression
name="expression">dataSetRow["UMSVORVORJAHR"]</expression >
<property
</structure>
<structure>
<property
<expression
name="expression">dataSetRow["MENLFDJAHR"]</expression>
<property
</structure>
<structure>
<property
<expression
name="expression">dataSetRow["MENVORJAHR"]</expression>
<property
</structure>
<structure>
<property
<expression
name="expression">dataSetRow["MENVORVORJAHR"]</expression >
<property
</structure>
<structure>
<property
<expression
name="expression">dataSetRow["ROHGLFDJAHR"]</expression >
<property
</structure>
<structure>
<property
<expression
name="expression">dataSetRow["ROHGVORJAHR"]</expression >
<property
</structure>
<structure>
<property
<expression
name="expression">dataSetRow["ROHGVORVORJAHR"]</expression >
<property
</structure>
<structure>
<property
<expression
name="expression">dataSetRow["CUSID"]</expression>
<property
</structure>
<structure>
<property
<expression
name="expression">dataSetRow["CUSNAME1"]</expression>
<property
</structure>
<structure>
<property
<expression
name="expression">dataSetRow["CUSNAME2"]</expression>
<property
</structure>
<structure>
<property
<expression
name="expression">dataSetRow["BUNID"]</expression>
<property
</structure>
</list-property>
<property
<text-property
name="content"><![CDATA[Reportversion: 1.05 /
<VALUE-OF>(Total.count(dataSetRow["CUSID"])).toString() + "
Datensätze"</VALUE-OF> ]]></text-property>
</text>
</cell>
</row>
</grid>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="1180">
<property name="style">Font_Number</property>
<property
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression name="expression">"Kdnr.
"+dataSetRow["CUSID"]</expression>
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<property name="name">to</property>
<expression
name="expression">Total.sum(row["UMSLFDJAHR"], null, 1)</expression>
<property name="aggregateOn">Customer</property>
</structure>
<structure>
<property name="name">TotalUmsVorJahr</property>
<expression
name="expression">Total.sum(row["UMSVORJAHR"])</expression >
</structure>
<structure>
<property name="name">TotalUmsVorvorjahr</property>
<expression
name="expression">Total.sum(row["UMSVORVORJAHR"])</expression >
</structure>
<structure>
<property name="name">to4</property>
<expression
name="expression">Total.sum(row["MENLFDJAHR"], null, 1)</expression>
</structure>
<structure>
<property name="name">TotalMenVorJahr</property>
<expression
name="expression">Total.sum(row["MENVORJAHR"])</expression >
</structure>
<structure>
<property name="name">TotalMenVorvorJahr</property>
<expression
Re: PDF - Generation Time... [message #368135 is a reply to message #368130] |
Tue, 05 May 2009 16:14 |
Patrick,
I did not see anything in the report that would cause performance
issues. What ODA are you using and how long does it take to get the
data? Also can you make a copy of the report and drop the table footer
to see the amount of time it takes?
Jason
Patrick wrote:
> Here it comes...
> id="1">
> Name here>></property>
> <structure>
> order by cu.NAME1, st.NAME1 asc, st.NAME2 asc, st.PACID asc"</expression>
> </structure>
> <structure>
> where BUNID = '"+params["bunId"]+"'"</expression>
> </structure>
> </list-property>
> <parameters>
> </structure>
> </scalar-parameter>
> </structure>
> </scalar-parameter>
> </structure>
> </scalar-parameter>
> </parameters>
> <data-sources>
> id="41"/>
> </data-sources>
> <data-sets>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> 'ST' = cu.BUNID group by st.artid, st.PACID, st.NAME1, st.NAME2,
> </oda-data-set>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> </list-property>
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </structure>
> </structure>
> </style>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-header>
> <grid id="53">
> <method
> }]]></method>
> <column id="54">
> </column>
> <column id="55">
> </column>
> <column id="56">
> </column>
> <row id="57">
> <cell id="58">
> <property
> <property
> <property
> <image id="1113">
> </image>
> </cell>
> <cell id="59">
> <property
> <property
> <property
> <text id="514">
> <property
> <property name="contentType">html</property>
> <text-property
> </text>
> </cell>
> <cell id="60">
> <property
> <property
> <property
> </cell>
> </row>
> <row id="1475">
> <cell id="1476">
> </cell>
> <cell id="1477">
> </cell>
> <cell id="1478">
> <text id="1076">
> <property
> <property name="marginBottom">0mm</property>
> <text-property
> </text>
> <data id="930">
> <property
> <property
> <structure>
> <property
> <expression
> <property
> </structure>
> </list-property>
> <property
> </data>
> </cell>
> </row>
> <row id="1111">
> <cell id="1112">
> <property
> <property name="borderTopStyle">solid</property>
> <text id="1110">
> <property name="contentType">auto</property>
> ]]></text-property>
> </text>
> </cell>
> </row>
> </grid>
> </page-header>
> <page-footer>
> <grid id="494">
> <method
> }]]></method>
> <column id="1095">
> </column>
> <column id="495">
> </column>
> <column id="496">
> </column>
> <column id="497">
> </column>
> <column id="1097">
> </column>
> <row id="1098">
> <structure>
> <expression
> </structure>
> </list-property>
> <cell id="1099">
> <property
> <text id="1104">
> ]]></text-property>
> </text>
> </cell>
> </row>
> <row id="1479">
> <structure>
> <expression
> </structure>
> </list-property>
> <cell id="1480"/>
> <cell id="1481"/>
> <cell id="1482"/>
> <cell id="1483"/>
> <cell id="1484"/>
> </row>
> <row id="498">
> <cell id="1094">
> <text id="1105">
> <property
> <method
> }]]></method>
> <text-property
> //Uhrzeit
> //Datum
> //Zusammenbauen
> </text>
> </cell>
> <cell id="499">
> <property
> <structure>
> <property
> <expression
> </structure>
> </list-property>
> <property name="type">page-number</property>
> </auto-text>
> </cell>
> <cell id="501">
> <text id="502">
> <property
> <structure>
> <property
> <expression
> </structure>
> </list-property>
> <property
> <text-property
> </text>
> </cell>
> <cell id="503">
> <property
> <structure>
> <property
> <expression
> </structure>
> </list-property>
> </auto-text>
> </cell>
> <cell id="1096">
> <text id="1546">
> <property
> <property
> <structure>
> <property
> <expression
> <property
> </structure>
> <structure>
> <property
> <expression
> <property
> </structure>
> <structure>
> <property
> <expression
> <property
> </structure>
> <structure>
> <expression
> <property
> </structure>
> <structure>
> <property
> <expression
> <property
> </structure>
> <structure>
> <property
> <expression
> <property
> </structure>
> <structure>
> <property
> <expression
> <property
> </structure>
> <structure>
> <property
> <expression
> <property
> </structure>
> <structure>
> <property
> <expression
> <property
> </structure>
> <structure>
> <property
> <expression
> <property
> </structure>
> <structure>
> <property
> <expression
> <property
> </structure>
> <structure>
> <property
> <expression
> <property
> </structure>
> <structure>
> <property
> <expression
> <property
> </structure>
> <structure>
> <property
> <expression
> <property
> </structure>
> <structure>
> <property
> <expression
> <property
> </structure>
> <structure>
> <property
> <expression
> <property
> </structure>
> <structure>
> <property
> <expression
> <property
> </structure>
> </list-property>
> <text-property
> </text>
> </cell>
> </row>
> </grid>
> </page-footer>
> </page-setup>
> <body>
> <table id="1180">
> <property
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
Re: PDF - Generation Time... [message #368211 is a reply to message #368206] |
Tue, 12 May 2009 15:32 |
Patrick,
I believe this has been corrected since 2.1.3. I am using 2.3.2 and
this issue is not there.
Jason
Patrick wrote:
> Hello! :-)
> Removing the table - footer didn't improve the performance. The
> colleague responsible for the oda data source is out of office so i'cant
> get any infomation from him at the moment.
> However i discovered something else. I tried to log the excution of
> various methods during the report creation.
> importPackage(Packages.java.io);
> fos = new java.io.FileOutputStream("c:\\logging\\logFile3.txt");
> pw = new java.io.PrintWriter(fos);
> var d = new Date();
> var h = d.getHours();
> var m = d.getMinutes();
> var s = d.getSeconds();
> pw.println("initialize " + h+"."+m+"."+s);
> It seems that all the DataSet - Methods from one DataSet are all called
> twice. The onFetch-Method is called even more. Is that normal behaviour?
> If not, what cut possibly cause this? My log-File (10 Preview - Rows)
> -"Methodname" + this.name + Hours.Minutes.Seconds
> -WSDB2_StatData_QuantityPerYear is the DataSet - Name?
> initialize 12.20.37
> beforeOpen WSDB2_StatData_QuantityPerYear 12.20.37
> afterOpen 12.20.47
> onFetch WSDB2_StatData_QuantityPerYear 12.20.47
> beforeOpen WSDB2_StatData_QuantityPerYear 12.20.47
> afterOpen 12.20.47
> beforeClose 12.20.47
> afterClose 12.20.47
> afterClose 12.20.47
Current Time: Tue Apr 23 06:18:03 GMT 2024
Powered by FUDForum. Page generated in 0.04189 seconds
