possible to access report from ODA ? [message #368086] |
Fri, 01 May 2009 13:47 |
Originally posted by: phillip.delucia.yahoo.de
I’m pretty new to BIRT and this is my first project. I want to use BIRT
for visualizing measuring data. Therefore, I created an ODA extension to
read data from the measurement files. My task is now to optimize the
workflow. The user will be able to select which row he wants to use as
x-axis data (other data rows will be used as y-axis data) on the
customized DataSetWizardpage. What I want to do now, is to automatically
create a scatter chart using this data.
So my question is: Is it possible to create a chart from within the
wizard page (until now I didn't find a way to access the report)? How
does this work?
And if it doesn't: Is there another way to create the chart without
further user interaction? Is there a way to create a report-template
with a chart which uses some parameter or something as data input which
I can bind programmatically to my dataset?
Phil
Re: possible to access report from ODA ? [message #368116 is a reply to message #368086] |
Tue, 05 May 2009 13:24 |
Phil,
Take a look at this example. It takes parameters and modifies the
number of series based on the parameters.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.17"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.3.1.v20080911 Build <2.3.1.v20080922-1151></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2007 <<Your Company
Name here>></property>
<html-property name="description">Creates a blank report with no
predefined content.</html-property>
<method name="beforeFactory"><![CDATA[importPackage(
Packages.java.io );
importPackage(Packages.org.eclipse.birt.chart.model.data.imp l);
importPackage(Packages.org.eclipse.birt.chart.model.componen t.impl);
importPackage(Packages.org.eclipse.birt.chart.model.type.imp l);
//Chart must be named
cht =
reportContext.getReportRunnable().designHandle.getDesignHand le().findElement( "MyChart");
mychart = cht.getReportItem().getProperty( "chart.instance" );
xAxis =mychart.getAxes().get(0);
yAxis1 = xAxis.getAssociatedAxes().get(0);
for( i=0; i < params["SelectSeriesToAdd"].value.length; i++){
var sdNew = SeriesDefinitionImpl.create();
var ls = LineSeriesImpl.create();
ls.getLabel().setVisible(true);
var qry = QueryImpl.create("row[\"" +
params["SelectSeriesToAdd"].value[i] + "\"]" );
ls.getDataDefinition().add(qry)
sdNew.getSeries().add( ls );
yAxis1.getSeriesDefinitions().add( sdNew );
}]]></method>
<text-property name="displayName">Blank Report</text-property>
<property name="iconFile">/templates/blank_report.gif</property>
<parameters>
<scalar-parameter name="SelectSeriesToAdd" id="10">
<property name="valueType">static</property>
<property name="dataType">string</property>
<property name="paramType">multi-value</property>
<property name="controlType">list-box</property>
<property name="mustMatch">true</property>
<property name="fixedOrder">true</property>
<property name="distinct">true</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
<list-property name="selectionList">
<structure>
<property name="value">PRICEEACH</property>
</structure>
<structure>
<property name="value">QUANTITYORDERED</property>
</structure>
</list-property>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="6">
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="OrderDetails" id="8">
<list-property name="columnHints">
<structure>
<property name="columnName">ORDERNUMBER</property>
<property name="displayName">ORDERNUMBER</property>
</structure>
<structure>
<property name="columnName">PRODUCTCODE</property>
<property name="displayName">PRODUCTCODE</property>
</structure>
<structure>
<property name="columnName">QUANTITYORDERED</property>
<property name="displayName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="columnName">PRICEEACH</property>
<property name="displayName">PRICEEACH</property>
</structure>
<structure>
<property name="columnName">ORDERLINENUMBER</property>
<property name="displayName">ORDERLINENUMBER</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTCODE</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">ORDERLINENUMBER</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
<property name="queryText">select *
from orderdetails
where ordernumber = 10101</property>
</oda-data-set>
</data-sets>
<styles>
<style name="crosstab-cell" id="4">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="5">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<extended-item extensionName="Chart" name="MyChart" id="9">
<xml-property
name="xmlRepresentation"><![CDATA[<model:ChartWithAxes
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:attribute="http://www.birt.eclipse.org/ChartModelAttribute"
xmlns:data="http://www.birt.eclipse.org/ChartModelData"
xmlns:layout="http://www.birt.eclipse.org/ChartModelLayout"
xmlns:model="http://www.birt.eclipse.org/ChartModel"
xmlns:type="http://www.birt.eclipse.org/ChartModelType">
<Type>Bar Chart</Type>
<SubType>Side-by-side</SubType>
<Block>
<Children xsi:type="layout:TitleBlock">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
<Height>0.0</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Bottom>3.0</Bottom>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Rowspan>-1</Rowspan>
<Columnspan>-1</Columnspan>
<Outline>
<Style>Solid</Style>
<Thickness>1</Thickness>
<Color>
<Transparency>255</Transparency>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
<Visible>false</Visible>
</Outline>
<Visible>true</Visible>
<Label>
<Caption>
<Value>Bar Chart Title</Value>
<Font>
<Size>16.0</Size>
<Bold>true</Bold>
<Alignment>
<horizontalAlignment>Center</horizontalAlignment>
<verticalAlignment>Center</verticalAlignment>
</Alignment>
</Font>
</Caption>
<Background xsi:type="attribute:ColorDefinition">
<Transparency>0</Transparency>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Bottom>0.0</Bottom>
<Right>3.0</Right>
</Insets>
</Label>
</Children>
<Children xsi:type="layout:Plot">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<HorizontalSpacing>5</HorizontalSpacing>
<VerticalSpacing>5</VerticalSpacing>
<ClientArea>
<Outline>
<Thickness>0</Thickness>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>0.0</Left>
<Right>0.0</Right>
</Insets>
</ClientArea>
</Children>
<Children xsi:type="layout:Legend">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>2.0</Top>
<Left>2.0</Left>
<Bottom>2.0</Bottom>
<Right>2.0</Right>
</Insets>
</ClientArea>
<Text>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Text>
<Orientation>Vertical</Orientation>
<Direction>Top_Bottom</Direction>
<Separator>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Separator>
<Position>Right</Position>
<ItemType>Categories</ItemType>
<Title>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Above</TitlePosition>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>432.75000000240004</Width>
<Height>288.0</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
</Block>
<Dimension>Two_Dimensional</Dimension>
<Script>function beforeDrawAxisLabel( axis, label, context )
importPackage(Packages.org.eclipse.birt.chart.model.attribut e);
//LINEAR_LITERAL
//LOGARITHMIC_LITERAL
//TEXT_LITERAL
//DATE_TIME_LITERAL
if (axis.getType() == AxisType.LINEAR_LITERAL)
var value = label.getCaption().getValue();
value = value + "*";
label.getCaption().setValue(value);
* Called before populating the series dataset using the DataSetProcessor.
* @param series
* Series
* @param idsp
* IDataSetProcessor
* @param icsc
* IChartScriptContext
function beforeDataSetFilled( series, idsp, icsc )
</Script>
<Units>Points</Units>
<SeriesThickness>10.0</SeriesThickness>
<SampleData>
<BaseSampleData>
<DataSetRepresentation>'A','B','C'</DataSetRepresentation>
</BaseSampleData>
<OrthogonalSampleData>
<DataSetRepresentation>5,4,12</DataSetRepresentation>
<SeriesDefinitionIndex>0</SeriesDefinitionIndex>
</OrthogonalSampleData>
</SampleData>
<Interactivity/>
<Axes>
<Type>Text</Type>
<Title>
<Caption>
<Value>X-Axis Title</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Below</TitlePosition>
<AssociatedAxes>
<Type>Linear</Type>
<Title>
<Caption>
<Value>Y-Axis Title</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
<Rotation>90.0</Rotation>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Left</TitlePosition>
<SeriesDefinitions>
<Query>
<Definition></Definition>
</Query>
<SeriesPalette>
<Entries xsi:type="attribute:ColorDefinition">
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>192</Red>
<Green>192</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>192</Green>
<Blue>128</Blue>
</Entries>
<Red>7</Red>
<Green>146</Green>
<Blue>94</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>0</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>255</Blue>
</Entries>
<Red>128</Red>
<Green>64</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>80</Red>
<Green>240</Green>
<Blue>120</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>0</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>0</Blue>
</Entries>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
</SeriesPalette>
<Series xsi:type="type:BarSeries">
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
<Definition> (row["QUANTITYORDERED"]*row["PRIC EEACH"])/10 </Definition>
</DataDefinition>
<SeriesIdentifier></SeriesIdentifier>
<DataPoint>
<Components>
<Type>Orthogonal_Value</Type>
</Components>
<Separator>, </Separator>
</DataPoint>
<LabelPosition>Outside</LabelPosition>
<Stacked>false</Stacked>
<Riser>Rectangle</Riser>
</Series>
<Grouping>
<Enabled>false</Enabled>
<GroupingInterval>2.0</GroupingInterval>
<GroupType>Text</GroupType>
<AggregateExpression>Sum</AggregateExpression>
</Grouping>
<Sorting>Ascending</Sorting>
</SeriesDefinitions>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<LabelPosition>Left</LabelPosition>
<MajorGrid>
<LineAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</LineAttributes>
<TickStyle>Across</TickStyle>
<TickAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</TickAttributes>
</MajorGrid>
<MinorGrid>
<LineAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</TickAttributes>
</MinorGrid>
<Scale>
<MinorGridsPerUnit>5</MinorGridsPerUnit>
</Scale>
<Origin>
<Type>Min</Type>
<Value xsi:type="data:NumberDataElement">
<Value>0.0</Value>
</Value>
</Origin>
<PrimaryAxis>true</PrimaryAxis>
<Percent>false</Percent>
</AssociatedAxes>
<SeriesDefinitions>
<Query>
</Query>
<SeriesPalette>
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>192</Red>
<Green>192</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>192</Green>
<Blue>128</Blue>
</Entries>
<Red>7</Red>
<Green>146</Green>
<Blue>94</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>0</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>255</Blue>
</Entries>
<Red>128</Red>
<Green>64</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>80</Red>
<Green>240</Green>
<Blue>120</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>0</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>0</Blue>
</Entries>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
</SeriesPalette>
<Series>
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
<Definition>row["PRODUCTCODE"]</Definition >
</DataDefinition>
<DataPoint>
<Components>
</Components>
</DataPoint>
</Series>
<Grouping>
</Grouping>
<Orientation>Horizontal</Orientation>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<LabelPosition>Below</LabelPosition>
<MajorGrid>
<LineAttributes>
<Color>
FUDForum. Page generated in 0.02642 seconds
