More than one default value for Combo/List [message #363930] |
Mon, 14 July 2008 20:32 |
Originally posted by: brian.w.geary.saic.com
Hello:
I have many list boxes. I would like to make all the values in the
list be selected (default). The user would then need to deselect the ones
they did not want. Currently they need to select all the values before
they can run a report. In most cases they want all of them. I prefer not
to use an alias such as "ALL".
Re: More than one default value for Combo/List [message #520283 is a reply to message #520103] |
Thu, 11 March 2010 19:56 |
This true. You can set the defaultValueList in the defaultValueList
event like:
var dVLArray = [];
dVLArray[0]= "10104";
dVLArray[1] = "10108";
dVLArray;
This also means you could write your own class to call your db and get
the values and enter it here. I am looking at one more option that I
will detail in a later post if it works out.
Jason
Michenaud Laurent wrote:
> My combo is linked to a dataset.
> So, i think that if i had a record in my table, the new value will not be
> added automatically in the default values of the combo.
FUDForum. Page generated in 0.03516 seconds
