Home » Modeling » Epsilon » Loading EMF models from a resource within some plugin
Loading EMF models from a resource within some plugin [message #3177] |
Tue, 11 November 2008 17:29 |
Originally posted by: szchaler.acm.org
I'm trying to use the code below to load a model from an ecore file that
resides in another plugin. This gets me an
StringIndexOutOfBoundsException. What could I be doing wrong?
EmfModel core = new EmfModel();
StringProperties properties = new StringProperties();
properties.put(EmfModel.PROPERTY_NAME, "Core");
properties.put(EmfModel.PROPERTY_IS_METAMODEL_FILE_BASED, "false");
properties.put(EmfModel.PROPERTY_METAMODEL_URI, EcorePackage.eNS_URI);
properties.put(EmfModel.PROPERTY_MODEL_FILE, "bundleentry://678/resources/core.ecore");
properties.put(EmfModel.PROPERTY_READONLOAD, "true");
properties.put(EmfModel.PROPERTY_STOREONDISPOSAL, "false");
core.load(properties, ResourcesPlugin.getWorkspace().getRoot()
.getRawLocation().toPortableString());
module.getContext().getModelRepository().addModel(core);
Note, I have adjusted the URL passed to PROPERTY_MODEL_FILE to the value
it actually has at runtime. In my real code this is being computed using
FileLocator.find. The Exception is thrown in the load() call. The file
does exist and the plugin has set that directory to be part of the
binary build.
What is the correct way of doing this?
Steffen
Dr. rer. nat. Steffen Zschaler
Senior Research Associate
Lancaster University
Lancaster, United Kingdom
Email szschaler@acm.org
WWW http://www.steffen-zschaler.de/
Consider submitting to QoSA 2009, the 5th International Conference on
the Quality of Software-Architectures.
http://qosa.ipd.uka.de/
Consider submitting to MiSE 2009, the 3rd International Workshop on
Models in Software Engineering
http://wikiserver.sse.cs.tu-bs.de/mise09
Re: Loading EMF models from a resource within some plugin [message #3210 is a reply to message #3177] |
Tue, 11 November 2008 17:37 |
Dimitrios Kolovos Messages: 1776 Registered: July 2009 |
At a first glance it seems that this line is causing the problem:
ResourcesPlugin.getWorkspace().getRoot().getRawLocation().to PortableString());
by giving load(...) the second argument
ResourcesPlugin.getWorkspace().getRoot().getRawLocation().to PortableString(),
it assumes that the path of the model is relative.
Could you please try
core.load(properties,null);
instead and let me know if it works. If not I'll investigate more.
Dimitrios
Steffen Zschaler wrote:
> binary build.
> Steffen
Re: Loading EMF models from a resource within some plugin [message #3243 is a reply to message #3210] |
Wed, 12 November 2008 10:10 |
Thanks, this has helped. For some reason, I am not getting a
FileNotFoundException. Not quite sure why this is, I am assuming OSGI is
hiding this file from me. Well, I guess its time for another workaround :-(
Steffen
> Cheers,
> Dimitrios
>> that resides in another plugin. This gets me an
>> value it actually has at runtime. In my real code this is being
>> computed using FileLocator.find. The Exception is thrown in the
>> load() call. The file does exist and the plugin has set that
>> directory to be part of the binary build.
>> Regards,
>> Steffen
Re: Loading EMF models from a resource within some plugin [message #3275 is a reply to message #3243] |
Wed, 12 November 2008 11:32 |
Hi Steffen,
Currently EmfModel is configured to work only with models/metamodels
that reside in the filesystem. I've added support for plugin based
models/metamodels too and committed to the SVN. Are you using Epsilon
from source? If not and it's too much trouble switching to SVN I can
send you a patched plugin to replace in your Eclipse installation. In
the new version you'll be able to load your plugin-based model like this:
"platform:/plugin/your.plugin.name/core.ecore");
Dimitrios
> Steffen
>> Cheers,
>> Dimitrios
>>> Hi,
>>> Regards,
>>> Steffen
Re: Loading EMF models from a resource within some plugin [message #3309 is a reply to message #3243] |
Wed, 12 November 2008 11:36 |
--------------070706000409030306070703
OK, I have this bit working now. Just to document the stupid mistakes I
made, in case somebody else is making them as well :-) :
* Never try to put something into a StringProperty that is not
actually a String. I tried putting in a URL :-( The thing is:
StringProperty will not tell you about your mistake, but will
rather silently throw your input away, so that load() later on
will not be able to figure out what file you are referring to...
* When you convert the URL to a String, make sure of two things:
o Use FileLocator.toFileURL to make sure the file is put into
some accessible location
o Do NOT use URL.toString() to produce the String. This will
produce a String of the form "file://..." EmfModel.load
cannot actually deal with this and will throw
incomprehensible exceptions at you (Telling you that this is
not a valid relative pathname, which is ... true). Instead,
use URL.getPath() and all will be happy.
Steffen
> is hiding this file from me. Well, I guess its time for another
> workaround :-(
> Steffen
>> Cheers,
>> Dimitrios
>>> Hi,
>>> "false");
>>> Regards,
>>> Steffen
<html>
<head>
</head>
made, in case somebody else is making them as well :-) :<br>
<ul>
<li>Never try to put something into a StringProperty that is not
StringProperty will not tell you about your mistake, but will rather
silently throw your input away, so that load() later on will not be
able to figure out what file you are referring to...</li>
<li>When you convert the URL to a String, make sure of two things:</li>
<ul>
<li>Use FileLocator.toFileURL to make sure the file is put into
some accessible location</li>
<li>Do NOT use URL.toString() to produce the String. This will
produce a String of the form <a class="moz-txt-link-rfc2396E" href="file://...">"file://..."</a> EmfModel.load cannot actually
deal with this and will throw incomprehensible exceptions at you
(Telling you that this is not a valid relative pathname, which is ...
true). Instead, use URL.getPath() and all will be happy.</li>
</ul>
</ul>
Cheers,<br>
<br>
Steffen<br>
<br>
<blockquote cite="mid:gfea3g$3oc$1@build.eclipse.org" type="cite">Thanks,
workaround :-(
<br>
<br>
Steffen
<br>
<br>
<br>
<blockquote type="cite">At a first glance it seems that this line is
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Dimitrios
<br>
<br>
<br>
<blockquote type="cite">Hi,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
"false");
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
computed using FileLocator.find. The Exception is thrown in the load()
call. The file does exist and the plugin has set that directory to be
<br>
<br>
<br>
<br>
<br>
<br>
Steffen
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
<br>
<pre class="moz-signature" cols="72">--
Email <a class="moz-txt-link-abbreviated" href="mailto:szschaler@acm.org">szschaler@acm.org</a>
WWW <a class="moz-txt-link-freetext" href="http://www.steffen-zschaler.de/">http://www.steffen-zschaler.de/</a>
<a class="moz-txt-link-freetext" href="http://qosa.ipd.uka.de/">http://qosa.ipd.uka.de/</a>
<a class="moz-txt-link-freetext" href="http://wikiserver.sse.cs.tu-bs.de/mise09">http://wikiserver.sse.cs.tu-bs.de/mise09</a></pre>
</body>
</html>
--------------070706000409030306070703--
Re: Loading EMF models from a resource within some plugin [message #3341 is a reply to message #3309] |
Wed, 12 November 2008 11:47 |
Hi Steffen,
Glad you found a workaround for this and thanks for sharing your
experiences! I'll look into the issues you mentioned and address them in
the next release of Epsilon.
Thanks again!
Dimitrios
> Cheers,
> Steffen
>> workaround :-(
>> Steffen
>>> Cheers,
>>> Dimitrios
>>>> Hi,
>>>> "false");
>>>> Regards,
>>>> Steffen
Re: Loading EMF models from a resource within some plugin [message #3411 is a reply to message #3275] |
Wed, 12 November 2008 11:57 |
This sounds really helpful :-) Anyway, I have it working now, so I'll
probably just stick to my solution (which probably does what you are
doing under the covers anyway :-) ).
Steffen
> Hi Steffen,
> Cheers,
> Dimitrios
>> workaround :-(
>> Steffen
>>> Cheers,
>>> Dimitrios
>>>> Hi,
>>>> "false");
>>>> Regards,
>>>> Steffen
Re: Loading EMF models from a resource within some plugin [message #3545 is a reply to message #3341] |
Wed, 12 November 2008 13:23 |
Created https://bugs.eclipse.org/bugs/show_bug.cgi?id=255030 to track this.
> Hi Steffen,
> Thanks again!
> Dimitrios
>> I made, in case somebody else is making them as well :-) :
>> Cheers,
>> Steffen
>>> workaround :-(
>>> Steffen
>>>> Cheers,
>>>> Dimitrios
>>>>> Hi,
>>>>> "false");
>>>>> Regards,
>>>>> Steffen
Re: Loading EMF models from a resource within some plugin [message #561691 is a reply to message #3177] |
Dimitrios
> binary build.
> Steffen
Re: Loading EMF models from a resource within some plugin [message #561710 is a reply to message #3210] |
Steffen Zschaler Messages: 266 Registered: July 2009 |
Steffen
> Cheers,
> Dimitrios
>> Regards,
>> Steffen
Re: Loading EMF models from a resource within some plugin [message #561726 is a reply to message #3243] |
Hi Steffen,
Dimitrios
> Steffen
>> Cheers,
>> Dimitrios
>>> Hi,
>>> Regards,
>>> Steffen
Re: Loading EMF models from a resource within some plugin [message #561747 is a reply to message #3243] |
produce a String of the form "file://.." EmfModel.load
Steffen
> workaround :-(
> Steffen
>> Cheers,
>> Dimitrios
>>> Hi,
>>> "false");
>>> Regards,
>>> Steffen
<html>
<head>
</head>
<ul>
<ul>
produce a String of the form <a class="moz-txt-link-rfc2396E" href="file://..">"file://.."</a> EmfModel.load cannot actually
</ul>
</ul>
Cheers,<br>
<br>
Steffen<br>
<br>
workaround :-(
<br>
<br>
Steffen
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Dimitrios
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
"false");
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Steffen
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
<br>
</body>
</html>
Re: Loading EMF models from a resource within some plugin [message #561766 is a reply to message #3309] |
Hi Steffen,
Thanks again!
Dimitrios
> Cheers,
> Steffen
>> workaround :-(
>> Steffen
>>> Cheers,
>>> Dimitrios
>>>> Hi,
>>>> "false");
>>>> Regards,
>>>> Steffen
Re: Loading EMF models from a resource within some plugin [message #561806 is a reply to message #3275] |
Steffen
> Hi Steffen,
> Cheers,
> Dimitrios
>> workaround :-(
>> Steffen
>>> Cheers,
>>> Dimitrios
>>>> Hi,
>>>> "false");
>>>> Regards,
>>>> Steffen
Re: Loading EMF models from a resource within some plugin [message #561884 is a reply to message #3341] |
> Hi Steffen,
> Thanks again!
> Dimitrios
>> Cheers,
>> Steffen
>>> workaround :-(
>>> Steffen
>>>> Cheers,
>>>> Dimitrios
>>>>> Hi,
>>>>> "false");
>>>>> Regards,
>>>>> Steffen
Current Time: Thu Apr 25 12:46:17 GMT 2024
Powered by FUDForum. Page generated in 0.04796 seconds
