How to provide all packages [message #34863] |
Tue, 10 February 2004 04:34 |
Originally posted by: igorf.ca.ibm.com
Is there a way for a bundle to provide all packages from a library?
Something similar to library/export name="*" found in plugin.xml?
Igor
Re: How to provide all packages [message #35045 is a reply to message #34863] |
Tue, 10 February 2004 14:39 |
Originally posted by: jeff_mcaffer_REMOVE.ca.ibm.com
Currently no. We have debated this but found that it is not particularly
useful. Tooling (e.g., PDE) can take care of that. Otherwise the runtime
would have ot have/run jar analysis code to determine what packages are
being provided (the underlying mechanisms require this information for
efficiency purposes)
Note that currently PDE does not have this function but most people are
expected to continue writing plugin.xmls and these will be converted under
the covers for you.
Jeff
"Igor Fedorenko" <igorf@ca.ibm.com> wrote in message
news:c09mso$2nf$1@eclipse.org...
> Igor
FUDForum. Page generated in 0.02863 seconds
