Home » Modeling » TMF (Xtext) » Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater(Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater)
Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater [message #1862783] Fri, 29 December 2023 05:02 Go to next message
I Created DSL A and DSL B in xtext.
The DSL B referenced DSL A.
I created a source code file xxx.a in DSL A and a source code file yyy.b in DSL B.
In the xxx.a, I created a variable named "abcd".
In yyy.b, I referenced variable "abcd" from xxx.a.
I renamed variable "abcd" in xxx.a from popup menu "Rename Element".
The xtext showed me a error dialog, saied:
Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater.
How can I implement "Rename Element" function?
Please help me !
Thanks a lot !
  • Attachment: rename.png
    (Size: 25.83KB, Downloaded 89 times)
Re: Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater [message #1862784 is a reply to message #1862783] Fri, 29 December 2023 05:09 Go to previous messageGo to next message
Would be nice how your dsls look like. Do you make use of xtext cross references. If yes it will work ootb
Re: Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater [message #1862786 is a reply to message #1862784] Fri, 29 December 2023 06:31 Go to previous messageGo to next message
I made use of xtext cross references in my grammar.
index.php/fa/43862/0/
In AbstractGLVDslUiModule.java, the DefaultReferenceUpdater.java was injected.
index.php/fa/43860/0/
The popup menu "Find references" in xtext worked well.
index.php/fa/43861/0/
[Updated on: Fri, 29 December 2023 06:33] by Moderator
Re: Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater [message #1862788 is a reply to message #1862786] Fri, 29 December 2023 07:06 Go to previous messageGo to next message
Can you please provide a complete minimal reproducer
Re: Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater [message #1862789 is a reply to message #1862784] Fri, 29 December 2023 07:07 Go to previous messageGo to next message
In instance of OptionalReferenceUpdaterProxy,The referenceUpdater field is null.
index.php/fa/43863/0/
  • Attachment: null.png
    (Size: 89.19KB, Downloaded 433 times)
Re: Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater [message #1862790 is a reply to message #1862789] Fri, 29 December 2023 07:16 Go to previous messageGo to next message
Yes but this should not happen if you register dsls oropetly.
Do you have all dsls in one project?
If yes is plugin.xml_gen generated. If yes did you merge it to plugin.xml
Re: Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater [message #1862791 is a reply to message #1862790] Fri, 29 December 2023 07:22 Go to previous messageGo to next message
My two DSLs are in two projects.
index.php/fa/43864/0/
  • Attachment: dsls.png
    (Size: 69.46KB, Downloaded 441 times)
Re: Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater [message #1862792 is a reply to message #1862790] Fri, 29 December 2023 07:28 Go to previous messageGo to next message
This is my GenerateGLVDsl.mwe2:
index.php/fa/43865/0/
  • Attachment: workflow.png
    (Size: 46.18KB, Downloaded 422 times)
Re: Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater [message #1862793 is a reply to message #1862791] Fri, 29 December 2023 07:28 Go to previous messageGo to next message
Then I really need a reproducer
There is too much stuff / configurations possible
Re: Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater [message #1862794 is a reply to message #1862793] Fri, 29 December 2023 07:29 Go to previous messageGo to next message
Can you create two reproducer hello world projects
Re: Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater [message #1862795 is a reply to message #1862794] Fri, 29 December 2023 08:09 Go to previous messageGo to next message
Can you tell me which configurations may make the referenceUpdater field of OptionalReferenceUpdaterProxy to be null ?
Re: Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater [message #1862796 is a reply to message #1862795] Fri, 29 December 2023 08:22 Go to previous messageGo to next message
Workflow . Modules . Plugin.xml(_gen)
I don't even know if null is an issue there
Re: Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater [message #1862797 is a reply to message #1862796] Fri, 29 December 2023 08:27 Go to previous messageGo to next message
Eg the stand-alone setup in workflow looks fishy
You usually use referencedResource inside language to
Refer to other genmodel
I also don't know how file extensions and their casing look like
Re: Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater [message #1862798 is a reply to message #1862797] Fri, 29 December 2023 09:42 Go to previous messageGo to next message
This is my GenerateGLVDsl.mwe2 :
module com.abcd.glv.dsl.GenerateGLVDsl
import org.eclipse.emf.mwe.utils.*
import org.eclipse.xtext.xtext.generator.*
import org.eclipse.xtext.xtext.generator.model.project.*
var rootPath = ".."
Workflow {
	bean = StandaloneSetup {
		scanClassPath = true
		platformUri = rootPath
		registerGenModelFile = "platform:/resource/com.abcd.udt.dsl/model/generated/UDTdsl.genmodel"
	component = XtextGenerator {
		configuration = {
			project = StandardProjectConfig {
				baseName = "com.abcd.glv.dsl"
				rootPath = rootPath
				runtimeTest = {
					enabled = true
				eclipsePlugin = {
					enabled = true
				eclipsePluginTest = {
					enabled = true
				createEclipseMetaData = true
			code = {
				encoding = "UTF-8"
				lineDelimiter = "\r\n"
				fileHeader = "/*\n * generated by Xtext \${version}\n */"
				preferXtendStubs = false
		language = StandardLanguage {
			name = "com.abcd.glv.dsl.GLVDsl"
			fileExtensions = "global"
			referencedResource = "platform:/resource/com.abcd.udt.dsl/model/generated/UDTdsl.genmodel"
			serializer = {
				generateStub = false
			validator = {
			// composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
			// Generates checks for @Deprecated grammar annotations, an IssueProvider and a corresponding PropertyPage
				generateDeprecationValidation = true
			generator = {
				generateXtendStub = true
			junitSupport = {
				junitVersion = "5"
GenerateUDTdsl.mwe2 file
module com.abcd.udt.GenerateUDTdsl
var rootPath = ".."
Workflow {
		configuration = {
				baseName = "com.abcd.udt.dsl"
				rootPath = rootPath
				runtimeTest = {
					enabled = true
				eclipsePlugin = {
					enabled = true
					enabled = true
			code = {
				encoding = "UTF-8"
			name = "com.abcd.udt.UDTdsl"
			fileExtensions = "udt"
			formatter={
				generateStub=true
				generateXtendStub=true
			serializer = {
			validator = {
			generator = {
			junitSupport = {
				junitVersion = "5"
UDT.xtext
grammar com.abcd.udt.UDTdsl hidden(WS, ML_COMMENT, SL_COMMENT)
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
generate uDTdsl "http://www.xxxxx.com/ide/plc/UDTdsl"
UDT_TYPE_DEF_LIST:
	list+=UDT_CUSTOM_TYPE_DEF+
UDT_CUSTOM_TYPE_DEF:
	{UDT_CUSTOM_TYPE_DEF} 'TYPE'
	type_def+=UDT_TYPE_DEF*
	'END_TYPE';
UDT_TYPE_DEF:
	UDT_ARRAY_TYPE_DEF | UDT_SUB_SET_TYPE_DEF | UDT_ENUM_TYPE_DEF | UDT_DIRECT_TYPE_DEF | UDT_STRUCT_TYPE_DEF;
UDT_ARRAY_TYPE_DEF:
	name=ID ':' arrayExp = UDT_ARRAY_EXP end=SEMICOLON;
UDT_ARRAY_EXP:
	'ARRAY' '[' value1=subrange_type (',' value2=subrange_type)? ']' 'OF' (pointer_to?=UDT_POINTER_TO)?
	(type=UDT_BASIC_TYPE | userDefinedTypeName=ID) (initValue=UDT_VAR_INIT_VALUE)?
UDT_ARRAY_EXP2:
subrange_type:
	lower=INT upto=UPTO upper=INT;
UDT_SUB_SET_TYPE_DEF:
	name=ID ':' dataType+=UDT_BASIC_TYPE '(' lower=INT_WITH_PLUS_MINUS_OPTIONAL upto=UPTO upper=INT_WITH_PLUS_MINUS_OPTIONAL ')' end=SEMICOLON;
UDT_ENUM_TYPE_DEF:
	name=ID ':' '(' value+=UDT_FIELD_INIT_VALUE (',' value+=UDT_FIELD_INIT_VALUE)* ')' initValue=UDT_ENUM_INIT_VALUE? end=SEMICOLON;
UDT_FIELD_INIT_VALUE:
	name=ID(op=":=" intValue=INT)?
UDT_ENUM_INIT_VALUE:
	":=" symbol=ID;
UDT_DIRECT_TYPE_DEF:
	name=ID ':' dataType=UDT_BASIC_TYPE (':=' initValue+=INT)? end=SEMICOLON;
UDT_STRUCT_TYPE_DEF:
	name=ID ':' 'STRUCT'
	statements+=UDT_STRUCT_STATEMENT+
	'END_STRUCT' (end=SEMICOLON)?;
UDT_STRUCT_STATEMENT:
	name=ID ':' ((ref_to?='REF_TO')| (pointer_to?=UDT_POINTER_TO))? (arry=UDT_ARRAY_EXP2)?  dataType=(UDT_BASIC_TYPE|UDT_USERDEFINEDTYPENAME) (initValue=UDT_VAR_INIT_VALUE)? (end=SEMICOLON)?;
UDT_USERDEFINEDTYPENAME:
	name=ID
UDT_POINTER_TO:
	pointer="POINTER" to="TO"
UDT_BASIC_TYPE:
	value=('BIT' | 'BOOL' | 'BYTE' | 'WORD' | 'DWORD' | 'LWORD' | 'SINT' | 'USINT' | 'INT' | 'UINT' | 'DINT' | 'UDINT'
	| 'LINT'|'ULINT' | 'REAL' | 'LREAL' | 'STRING' | 'TIME' | 'TIME_OF_DAY' | 'TOD' | 'DATE' | 'DATE_AND_TIME' | 'DT' | 'WSTRING'
	| 'ANY' | 'ANY_INT'
	| 'ANY_REAL' | 'ANY_NUM' | 'ANY_DATE' | 'ANY_BIT');
UDT_VAR_INIT_VALUE:
	op=':=' initValue=(UDT_ONE_DIMENSION_INIT |UDT_TWO_DIMENSION_INIT| UDT_VALUE_EXP | UDT_STRUCT_OR_FB_INIT);
UDT_TWO_DIMENSION_INIT:
	'[' valueExp+=UDT_ONE_DIMENSION_INIT(','valueExp+=UDT_ONE_DIMENSION_INIT)* ']'
UDT_ONE_DIMENSION_INIT:
	'[' valueExp+=( UDT_VALUE_EXP | UDT_STRUCT_OR_FB_INIT)(','valueExp+=(UDT_VALUE_EXP | UDT_STRUCT_OR_FB_INIT))* ']';
UDT_STRUCT_OR_FB_INIT:
	leftbrace="(" paramList=UDT_INIT_PARAM_LIST rightbrace=")"
UDT_INIT_PARAM_LIST:
	in+=UDT_INIT_PARAM (',' (comments+=ML_COMMENT)? in+=UDT_INIT_PARAM)*;
UDT_INIT_PARAM:
	(inName=ID ':=' (comments+=ML_COMMENT)?)? exp=(UDT_ONE_DIMENSION_INIT |UDT_TWO_DIMENSION_INIT| UDT_VALUE_EXP | UDT_STRUCT_OR_FB_INIT);
UDT_VALUE_EXP:
	(boolValue=('TRUE' | 'FALSE') | idValue=ID | strValue=STRING | intValueWithPlusOrMinus=INT_WITH_PLUS_MINUS |
	intValue=INT | timeValue=TIME | todValue=TOD | dateValue=DATE | durationValue=DURATION | dtValue=DT | hexValue=HEX |
	octValue=OCT | binaryValue=BINARY | real_value=REAL_NUMBER);
Number hidden():
	HEX | (INT | REAL_NUMBER) ('.' (INT | REAL_NUMBER))?;
REAL_NUMBER returns ecore::EBigDecimal hidden():
	('-' | '+')? INT '.' (EXT_INT | INT);
terminal EXT_INT:
	INT ('e' | 'E') ('-' | '+')? INT;
terminal TIME:
	('T#' | 't#') (INT 'h')? (INT 'm')? (INT 's')?;
terminal DATE:
	('D#'|'DATE#') INT '-' INT '-' INT;
terminal DURATION:
	('T#' | 't#') (INT 'd')? (INT 'h')? (INT 'm')? (INT 's')? (INT (. 'INT')? 'ms')?;
terminal DT:
	('DT#'|'DATE_AND_TIME#') INT '-' INT '-' INT '-' INT ':' INT ':' INT '.' INT;
terminal TOD:
	('TOD#' |'TIME_OF_DAY#') INT ':' INT ':' INT ('.' INT)?;
terminal HEX:
	'16#' ('0'..'9' | 'a'..'f' | 'A'..'F' | '_')+;
terminal OCT:
	'8#' ('0'..'8')+
terminal BINARY:
	'2#' ('0'..'1' | '_')+;
INT_WITH_PLUS_MINUS_OPTIONAL returns ecore::EInt:
	('-' | '+')?  INT;
INT_WITH_PLUS_MINUS returns ecore::EInt:
	('-' | '+')  INT;
terminal INT returns ecore::EInt:
	'0'..'9' ('0'..'9' | '_')*;
terminal SEMICOLON:
UPTO hidden(WS):
terminal ID:
		'^'? ('\u4E00'..'\u9FA5'|'\uF900'..'\uFA2D'|'a'..'z' | 'A'..'Z' | '_') ('a'..'z' | 'A'..'Z' | '_' | '0'..'9'|'\u4E00'..'\u9FA5'|'\uF900'..'\uFA2D')*;
terminal STRING:
	'"' ('\\' . /* 'b'|'t'|'n'|'f'|'r'|'u'|'"'|"'"|'\\' */ | !('\\' | '"'))* '"' |
	"'" ('\\' . /* 'b'|'t'|'n'|'f'|'r'|'u'|'"'|"'"|'\\' */ | !('\\' | "'"))* "'";
terminal fragment MLC_OTH:
terminal fragment MLC_OTH_RP:
terminal fragment MLC_LP_TOK:
	'('+ ('*' MLC_BODY | MLC_OTH_RP);
terminal fragment MLC_X_TOK:
	'*'+ (MLC_OTH | MLC_LP_TOK);
terminal fragment MLC_BODY:
	(MLC_OTH_RP | MLC_LP_TOK | MLC_X_TOK)* '*'+ ')';
terminal ML_COMMENT:
	'(*' MLC_BODY;
terminal SL_COMMENT:
	'//' !('\n' | '\r')* ('\r'? '\n')?;
terminal WS:
	(' ' | '\t' | '\r' | '\n')+;
terminal ANY_OTHER:
GLVDsl.xtext
grammar com.abcd.glv.dsl.GLVDsl hidden(WS, ML_COMMENT, SL_COMMENT)
import "platform:/resource/com.abcd.udt.dsl/model/generated/UDTdsl.ecore" as UDT
generate gLVDsl "http://www.xxxxx.com/ide/plc/glv/dsl/GLVDsl"
GLOBAL_VARIABLES:
	variables+=GLV_VAR_GLOBAL*
GLV_VAR_GLOBAL:
	{GLV_VAR_GLOBAL} 'VAR_GLOBAL' (persistent?='PERSISTENT' | retain?='RETAIN' | non_retain?='NON_RETAIN' | constant?='CONSTANT')?
	vars+=GLV_VAR_STATEMENT*
	'END_VAR';
GLV_VAR_STATEMENT:
	GLV_VAR_NAME end=SEMICOLON
GLV_VAR_NAME:
	(({VAR_WITH_NAME}(name=ID) (loc=LOCATION_MAPPING)?) | {VAR_WITH_LOCATION}(loc=LOCATION_MAPPING)) ':' ((ref_to?='REF_TO') | (pointer_to?=POINTER_TO))? (array=GLV_ARRAY_TYPE)?  ((type=GLV_BASIC_TYPE) |
	userDefinedTypeName=complextDataType) intValue=GLV_VAR_INIT_VALUE?;
POINTER_TO:
complextDataType:
	name= [UDT::UDT_TYPE_DEF];
GLV_VAR_INIT_VALUE:
	op=':=' initValue=(ONE_DIMENSION_INIT |TWO_DIMENSION_INIT| GLV_VALUE_EXP | STRUCT_OR_FB_INIT);
TWO_DIMENSION_INIT:
	'[' valueExp+=ONE_DIMENSION_INIT(','valueExp+=ONE_DIMENSION_INIT)* ']'
ONE_DIMENSION_INIT:
	'[' valueExp+=(GLV_VALUE_EXP | STRUCT_OR_FB_INIT)(','valueExp+=(GLV_VALUE_EXP | STRUCT_OR_FB_INIT))* ']';
STRUCT_OR_FB_INIT:
	leftbrace="(" paramList=INIT_PARAM_LIST rightbrace=")"
INIT_PARAM_LIST:
	in+=INIT_PARAM (',' (comments+=ML_COMMENT)? in+=INIT_PARAM)*;
INIT_PARAM:
	(inName=ID ':=' (comments+=ML_COMMENT)?)? exp=(ONE_DIMENSION_INIT |TWO_DIMENSION_INIT| GLV_VALUE_EXP | STRUCT_OR_FB_INIT);
GLV_VALUE_EXP:
LOCATION_MAPPING:
	'AT' LOCATION;
GLV_ARRAY_TYPE hidden(WS):
	'ARRAY' '[' dimension=DIMENSION ']' 'OF';
DIMENSION:
	dimension+=subrange_type (',' dimension+=subrange_type)*;
subrange_type:
terminal SEMICOLON:
GLV_BASIC_TYPE:
	| 'LINT' | 'REAL' | 'LREAL' | 'STRING' | 'TIME' | 'TIME_OF_DAY' | 'TOD' | 'DATE' | 'DATE_AND_TIME' | 'DT' | 'WSTRING'
	| 'ANY' | 'ANY_INT'
terminal TIME:
terminal DATE:
	('d#'|'D#') INT '-' INT '-' INT;
terminal DURATION:
terminal DT:
	('dt#'|'DT#') INT '-' INT '-' INT '-' INT ':' INT ':' INT ('.' INT)?;
terminal TOD:
	('tod#'|'TOD#') INT ':' INT ':' INT ('.' INT)?;
terminal HEX:
terminal BINARY:
INT_WITH_PLUS_MINUS returns ecore::EIntegerObject:
	'-' INT;
terminal INT returns ecore::EIntegerObject:
terminal EXT_INT:
terminal OCT:
	'8#' ('0'..'8')+
UPTO hidden(WS):
terminal LOCATION:
	'%' ('I' | 'Q' | 'M') (('*') | ('X' | 'B' | 'W' | 'D' | 'L')? ('0'..'9')+ (('.') ('0'..'9')+)?);
terminal ID:
terminal STRING:
	'(*' MLC_BODY;
terminal WS:
terminal ANY_OTHER:
Re: Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater [message #1862799 is a reply to message #1862798] Fri, 29 December 2023 10:02 Go to previous messageGo to next message
can you please provide the plugin.xml for global.ui
we need to find out why there is no
IResourceServiceProvider or entry here
in ReferenceUpdaterDispatcher
what resourceServiceProvider do you get.
(it is registered via plugin.xml)
if you copy your stuff to a new workspace/projects
do you still see the problem?
[Updated on: Fri, 29 December 2023 10:08] by Moderator
Re: Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater [message #1862800 is a reply to message #1862799] Fri, 29 December 2023 10:25 Go to previous messageGo to next message
plugin.xml in glv.dsl.ui plugin project
<?eclipse version="3.0"?>
<plugin>
	<extension
		point="org.eclipse.ui.editors">
		<editor
        class="com.abcd.glv.dsl.ui.GLVDslExecutableExtensionFactory:org.eclipse.xtext.ui.editor.XtextEditor"
        contributorClass="org.eclipse.ui.editors.text.TextEditorActionContributor"
        default="true"
        extensions="global"
        icon="icons/GlobalVar.gif"
        id="com.abcd.glv.dsl.GLVDsl"
        name="GLVDsl Editor">
		</editor>
	</extension>
	<extension
		point="org.eclipse.ui.handlers">
		<handler
			class="com.abcd.glv.dsl.ui.GLVDslExecutableExtensionFactory:org.eclipse.xtext.ui.editor.hyperlinking.OpenDeclarationHandler"
			commandId="org.eclipse.xtext.ui.editor.hyperlinking.OpenDeclaration">
			<activeWhen>
				<reference
					definitionId="com.abcd.glv.dsl.GLVDsl.Editor.opened">
				</reference>
			</activeWhen>
		</handler>
		<handler
			class="com.abcd.glv.dsl.ui.GLVDslExecutableExtensionFactory:org.eclipse.xtext.ui.editor.handler.ValidateActionHandler"
			commandId="com.abcd.glv.dsl.GLVDsl.validate">
			<activeWhen>
				<reference
				</reference>
			</activeWhen>
		</handler>
		<!-- copy qualified name -->
		<handler
			class="com.abcd.glv.dsl.ui.GLVDslExecutableExtensionFactory:org.eclipse.xtext.ui.editor.copyqualifiedname.EditorCopyQualifiedNameHandler"
			commandId="org.eclipse.xtext.ui.editor.copyqualifiedname.EditorCopyQualifiedName">
			<activeWhen>
				<reference definitionId="com.abcd.glv.dsl.GLVDsl.Editor.opened" />
			</activeWhen>
		</handler>
		<handler
			class="com.abcd.glv.dsl.ui.GLVDslExecutableExtensionFactory:org.eclipse.xtext.ui.editor.copyqualifiedname.OutlineCopyQualifiedNameHandler"
			commandId="org.eclipse.xtext.ui.editor.copyqualifiedname.OutlineCopyQualifiedName">
			<activeWhen>
				<and>
					<reference definitionId="com.abcd.glv.dsl.GLVDsl.XtextEditor.opened" />
					<iterate>
						<adapt type="org.eclipse.xtext.ui.editor.outline.IOutlineNode" />
					</iterate>
				</and>
			</activeWhen>
		</handler>
	</extension>
	<extension point="org.eclipse.core.expressions.definitions">
		<definition id="com.abcd.glv.dsl.GLVDsl.Editor.opened">
			<and>
				<reference definitionId="isActiveEditorAnInstanceOfXtextEditor"/>
				<with variable="activeEditor">
					<test property="org.eclipse.xtext.ui.editor.XtextEditor.languageName"
						value="com.abcd.glv.dsl.GLVDsl"
						forcePluginActivation="true"/>
				</with>
			</and>
		</definition>
		<definition id="com.abcd.glv.dsl.GLVDsl.XtextEditor.opened">
			<and>
				<reference definitionId="isXtextEditorActive"/>
				</with>
			</and>
		</definition>
	</extension>
	<extension
			point="org.eclipse.ui.preferencePages">
		<page
			class="com.abcd.glv.dsl.ui.GLVDslExecutableExtensionFactory:org.eclipse.xtext.ui.editor.preferences.LanguageRootPreferencePage"
			name="GLVDsl">
			<keywordReference id="com.abcd.glv.dsl.ui.keyword_GLVDsl"/>
		</page>
		<page
			category="com.abcd.glv.dsl.GLVDsl"
			class="com.abcd.glv.dsl.ui.GLVDslExecutableExtensionFactory:org.eclipse.xtext.ui.editor.syntaxcoloring.SyntaxColoringPreferencePage"
			id="com.abcd.glv.dsl.GLVDsl.coloring"
			name="Syntax Coloring">
		</page>
		<page
			class="com.abcd.glv.dsl.ui.GLVDslExecutableExtensionFactory:org.eclipse.xtext.ui.editor.templates.XtextTemplatePreferencePage"
			id="com.abcd.glv.dsl.GLVDsl.templates"
			name="Templates">
		</page>
	</extension>
	<extension
			point="org.eclipse.ui.propertyPages">
		<page
			name="GLVDsl">
			<enabledWhen>
				<adapt type="org.eclipse.core.resources.IProject"/>
			</enabledWhen>
			<filter name="projectNature" value="org.eclipse.xtext.ui.shared.xtextNature"/>
		</page>
	</extension>
	<extension
		point="org.eclipse.ui.keywords">
		<keyword
			label="GLVDsl"/>
	</extension>
	<extension
		point="org.eclipse.ui.commands">
		<command
			description="Trigger expensive validation"
			id="com.abcd.glv.dsl.GLVDsl.validate"
			name="Validate">
		</command>
		<command
			id="org.eclipse.xtext.ui.editor.copyqualifiedname.EditorCopyQualifiedName"
			categoryId="org.eclipse.ui.category.edit"
			description="Copy the qualified name for the selected element"
			name="Copy Qualified Name">
		</command>
		<command
			id="org.eclipse.xtext.ui.editor.copyqualifiedname.OutlineCopyQualifiedName"
		</command>
	</extension>
	<extension point="org.eclipse.ui.menus">
		<menuContribution
			locationURI="popup:#TextEditorContext?after=group.edit">
			<command
				style="push"
				tooltip="Trigger expensive validation">
				<visibleWhen checkEnabled="false">
					<reference
					</reference>
				</visibleWhen>
			</command>
		</menuContribution>
		<menuContribution locationURI="popup:#TextEditorContext?after=copy">
			<command commandId="org.eclipse.xtext.ui.editor.copyqualifiedname.EditorCopyQualifiedName"
				style="push" tooltip="Copy Qualified Name">
				</visibleWhen>
			</command>
		</menuContribution>
		<menuContribution locationURI="menu:edit?after=copy">
				</visibleWhen>
			</command>
		</menuContribution>
		<menuContribution locationURI="popup:org.eclipse.xtext.ui.outline?after=additions">
			<command commandId="org.eclipse.xtext.ui.editor.copyqualifiedname.OutlineCopyQualifiedName"
					<and>
						<iterate>
						</iterate>
					</and>
				</visibleWhen>
			</command>
		</menuContribution>
	</extension>
		<menuContribution locationURI="popup:#TextEditorContext?endof=group.find">
			<command commandId="org.eclipse.xtext.ui.editor.FindReferences">
					<reference definitionId="com.abcd.glv.dsl.GLVDsl.Editor.opened">
					</reference>
				</visibleWhen>
			</command>
		</menuContribution>
	</extension>
	<extension point="org.eclipse.ui.handlers">
		<handler
			class="com.abcd.glv.dsl.ui.GLVDslExecutableExtensionFactory:org.eclipse.xtext.ui.editor.findrefs.FindReferencesHandler"
			<activeWhen>
				<reference
				</reference>
			</activeWhen>
		</handler>
	</extension>
	<extension point="org.eclipse.core.contenttype.contentTypes">
		<content-type
			base-type="org.eclipse.core.runtime.text"
			file-extensions="glv"
			id="com.abcd.glv.dsl.GLVDsl.contenttype"
			name="GLVDsl File"
			priority="normal">
		</content-type>
	</extension>
	<!-- adding resource factories -->
	<extension
		point="org.eclipse.emf.ecore.extension_parser">
		<parser
			class="com.abcd.glv.dsl.ui.GLVDslExecutableExtensionFactory:org.eclipse.xtext.resource.IResourceFactory"
			type="glv">
		</parser>
	</extension>
	<extension point="org.eclipse.xtext.extension_resourceServiceProvider">
		<resourceServiceProvider
			class="com.abcd.glv.dsl.ui.GLVDslExecutableExtensionFactory:org.eclipse.xtext.ui.resource.IResourceUIServiceProvider"
			uriExtension="glv">
		</resourceServiceProvider>
	</extension>
	<!-- marker definitions for com.abcd.glv.dsl.GLVDsl -->
	<extension
			id="glvdsl.check.fast"
			name="GLVDsl Problem"
			point="org.eclipse.core.resources.markers">
		<super type="org.eclipse.xtext.ui.check.fast"/>
		<persistent value="true"/>
	</extension>
	<extension
			id="glvdsl.check.normal"
		<super type="org.eclipse.xtext.ui.check.normal"/>
	</extension>
	<extension
			id="glvdsl.check.expensive"
		<super type="org.eclipse.xtext.ui.check.expensive"/>
	</extension>
	<extension point="org.eclipse.ui.preferencePages">
		<page
			class="com.abcd.glv.dsl.ui.GLVDslExecutableExtensionFactory:org.eclipse.xtext.ui.validation.ValidatorPreferencePage"
			id="com.abcd.glv.dsl.GLVDsl.validator.preferencePage"
			name="Errors/Warnings">
		</page>
	</extension>
	<extension point="org.eclipse.xtext.builder.participant">
		<participant
			class="com.abcd.glv.dsl.ui.GLVDslExecutableExtensionFactory:org.eclipse.xtext.builder.IXtextBuilderParticipant"
			fileExtensions="glv"/>
	</extension>
		<page
			class="com.abcd.glv.dsl.ui.GLVDslExecutableExtensionFactory:org.eclipse.xtext.builder.preferences.BuilderPreferencePage"
			id="com.abcd.glv.dsl.GLVDsl.compiler.preferencePage"
			name="Compiler">
		</page>
	</extension>
	<extension point="org.eclipse.ui.propertyPages">
		<page
			id="com.abcd.glv.dsl.GLVDsl.compiler.propertyPage"
			name="Compiler">
			<enabledWhen>
			</enabledWhen>
		</page>
	</extension>
		<menuContribution locationURI="popup:#TextEditorContext?after=xtext.ui.openDeclaration">
			<command
				commandId="org.eclipse.xtext.ui.OpenGeneratedFileCommand"
				id="com.abcd.glv.dsl.GLVDsl.OpenGeneratedCode"
				style="push">
				</visibleWhen>
			</command>
		</menuContribution>
	</extension>
		<handler
			class="com.abcd.glv.dsl.ui.GLVDslExecutableExtensionFactory:org.eclipse.xtext.ui.generator.trace.OpenGeneratedFileHandler"
			commandId="org.eclipse.xtext.ui.OpenGeneratedFileCommand">
			<activeWhen>
			</activeWhen>
		</handler>
	</extension>
	<!-- Quick Outline -->
	<extension
		<handler
			class="com.abcd.glv.dsl.ui.GLVDslExecutableExtensionFactory:org.eclipse.xtext.ui.editor.outline.quickoutline.ShowQuickOutlineActionHandler"
			commandId="org.eclipse.xtext.ui.editor.outline.QuickOutline">
			<activeWhen>
				<reference
				</reference>
			</activeWhen>
		</handler>
	</extension>
	<extension
		<command
			description="Open the quick outline."
			id="org.eclipse.xtext.ui.editor.outline.QuickOutline"
			name="Quick Outline">
		</command>
	</extension>
		<menuContribution
			locationURI="popup:#TextEditorContext?after=group.open">
			<command commandId="org.eclipse.xtext.ui.editor.outline.QuickOutline"
				style="push"
				tooltip="Open Quick Outline">
					<reference definitionId="com.abcd.glv.dsl.GLVDsl.Editor.opened"/>
				</visibleWhen>
			</command>
		</menuContribution>
	</extension>
	<!-- quickfix marker resolution generator for com.abcd.glv.dsl.GLVDsl -->
	<extension
			point="org.eclipse.ui.ide.markerResolution">
		<markerResolutionGenerator
			class="com.abcd.glv.dsl.ui.GLVDslExecutableExtensionFactory:org.eclipse.xtext.ui.editor.quickfix.MarkerResolutionGenerator"
			markerType="com.abcd.glv.dsl.ui.glvdsl.check.fast">
			<attribute
				name="FIXABLE_KEY"
				value="true">
			</attribute>
		</markerResolutionGenerator>
			markerType="com.abcd.glv.dsl.ui.glvdsl.check.normal">
			<attribute
				name="FIXABLE_KEY"
				value="true">
			</attribute>
			markerType="com.abcd.glv.dsl.ui.glvdsl.check.expensive">
			<attribute
				name="FIXABLE_KEY"
				value="true">
			</attribute>
	</extension>
	<!-- Rename Refactoring -->
		<handler
			class="com.abcd.glv.dsl.ui.GLVDslExecutableExtensionFactory:org.eclipse.xtext.ui.refactoring.ui.DefaultRenameElementHandler"
			commandId="org.eclipse.xtext.ui.refactoring.RenameElement">
			<activeWhen>
				<reference
				</reference>
			</activeWhen>
		</handler>
	</extension>
		<menuContribution
			<command commandId="org.eclipse.xtext.ui.refactoring.RenameElement"
				style="push">
					<reference
					</reference>
				</visibleWhen>
			</command>
		</menuContribution>
	</extension>
		<page
			class="com.abcd.glv.dsl.ui.GLVDslExecutableExtensionFactory:org.eclipse.xtext.ui.refactoring.ui.RefactoringPreferencePage"
			id="com.abcd.glv.dsl.GLVDsl.refactoring"
			name="Refactoring">
		</page>
	</extension>
	<extension point="org.eclipse.compare.contentViewers">
		<viewer id="com.abcd.glv.dsl.GLVDsl.compare.contentViewers"
			class="com.abcd.glv.dsl.ui.GLVDslExecutableExtensionFactory:org.eclipse.xtext.ui.compare.InjectableViewerCreator"
			extensions="glv">
		</viewer>
		<contentTypeBinding
			contentTypeId="com.abcd.glv.dsl.GLVDsl.contenttype"
			contentViewerId="com.abcd.glv.dsl.GLVDsl.compare.contentViewers" />
	</extension>
	<extension point="org.eclipse.compare.contentMergeViewers">
		<viewer id="com.abcd.glv.dsl.GLVDsl.compare.contentMergeViewers"
			extensions="glv" label="GLVDsl Compare">
		</viewer>
		<contentTypeBinding
			contentMergeViewerId="com.abcd.glv.dsl.GLVDsl.compare.contentMergeViewers" />
	</extension>
	<extension point="org.eclipse.ui.editors.documentProviders">
		<provider id="com.abcd.glv.dsl.GLVDsl.editors.documentProviders"
			class="com.abcd.glv.dsl.ui.GLVDslExecutableExtensionFactory:org.eclipse.xtext.ui.editor.model.XtextDocumentProvider"
			extensions="glv">
		</provider>
	</extension>
	<extension point="org.eclipse.team.core.fileTypes">
		<fileTypes
			extension="glv"
			type="text">
		</fileTypes>
	</extension>
</plugin>
Re: Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater [message #1862801 is a reply to message #1862799] Fri, 29 December 2023 10:28 Go to previous messageGo to next message
index.php/fa/43866/0/
Re: Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater [message #1862802 is a reply to message #1862801] Fri, 29 December 2023 10:32 Go to previous messageGo to next message
Yea but I would expect a different class from ui project.
Re: Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater [message #1862803 is a reply to message #1862799] Fri, 29 December 2023 10:32 Go to previous messageGo to next message
 * generated by Xtext 2.26.0
package com.abcd.glv.dsl.ui;
import com.google.inject.Binder;
import com.google.inject.Provider;
import com.google.inject.name.Names;
import com.abcd.glv.dsl.ide.contentassist.antlr.GLVDslParser;
import com.abcd.glv.dsl.ide.contentassist.antlr.PartialGLVDslContentAssistParser;
import com.abcd.glv.dsl.ide.contentassist.antlr.internal.InternalGLVDslLexer;
import com.abcd.glv.dsl.ui.contentassist.GLVDslProposalProvider;
import com.abcd.glv.dsl.ui.labeling.GLVDslDescriptionLabelProvider;
import com.abcd.glv.dsl.ui.labeling.GLVDslLabelProvider;
import com.abcd.glv.dsl.ui.outline.GLVDslOutlineTreeProvider;
import com.abcd.glv.dsl.ui.quickfix.GLVDslQuickfixProvider;
import com.abcd.glv.dsl.validation.GLVDslValidatorConfigurationBlock;
import org.eclipse.compare.IViewerCreator;
import org.eclipse.core.resources.IWorkspaceRoot;
import org.eclipse.core.resources.ResourcesPlugin;
import org.eclipse.jface.viewers.ILabelProvider;
import org.eclipse.ui.plugin.AbstractUIPlugin;
import org.eclipse.xtext.builder.BuilderParticipant;
import org.eclipse.xtext.builder.EclipseOutputConfigurationProvider;
import org.eclipse.xtext.builder.IXtextBuilderParticipant;
import org.eclipse.xtext.builder.builderState.IBuilderState;
import org.eclipse.xtext.builder.clustering.CurrentDescriptions;
import org.eclipse.xtext.builder.impl.PersistentDataAwareDirtyResource;
import org.eclipse.xtext.builder.nature.NatureAddingEditorCallback;
import org.eclipse.xtext.builder.preferences.BuilderPreferenceAccess;
import org.eclipse.xtext.generator.IContextualOutputConfigurationProvider;
import org.eclipse.xtext.ide.LexerIdeBindings;
import org.eclipse.xtext.ide.editor.contentassist.antlr.IContentAssistParser;
import org.eclipse.xtext.ide.editor.contentassist.antlr.internal.Lexer;
import org.eclipse.xtext.ide.editor.partialEditing.IPartialEditingContentAssistParser;
import org.eclipse.xtext.parser.antlr.AntlrTokenDefProvider;
import org.eclipse.xtext.parser.antlr.ITokenDefProvider;
import org.eclipse.xtext.parser.antlr.LexerProvider;
import org.eclipse.xtext.resource.IResourceDescriptions;
import org.eclipse.xtext.resource.containers.IAllContainersState;
import org.eclipse.xtext.resource.impl.ResourceDescriptionsProvider;
import org.eclipse.xtext.service.SingletonBinding;
import org.eclipse.xtext.ui.DefaultUiModule;
import org.eclipse.xtext.ui.UIBindings;
import org.eclipse.xtext.ui.codetemplates.ui.AccessibleCodetemplatesActivator;
import org.eclipse.xtext.ui.codetemplates.ui.partialEditing.IPartialEditingContentAssistContextFactory;
import org.eclipse.xtext.ui.codetemplates.ui.partialEditing.PartialEditingContentAssistContextFactory;
import org.eclipse.xtext.ui.codetemplates.ui.preferences.AdvancedTemplatesPreferencePage;
import org.eclipse.xtext.ui.codetemplates.ui.preferences.TemplatesLanguageConfiguration;
import org.eclipse.xtext.ui.codetemplates.ui.registry.LanguageRegistrar;
import org.eclipse.xtext.ui.codetemplates.ui.registry.LanguageRegistry;
import org.eclipse.xtext.ui.compare.DefaultViewerCreator;
import org.eclipse.xtext.ui.editor.DocumentBasedDirtyResource;
import org.eclipse.xtext.ui.editor.IXtextEditorCallback;
import org.eclipse.xtext.ui.editor.contentassist.ContentAssistContext;
import org.eclipse.xtext.ui.editor.contentassist.FQNPrefixMatcher;
import org.eclipse.xtext.ui.editor.contentassist.IContentProposalProvider;
import org.eclipse.xtext.ui.editor.contentassist.IProposalConflictHelper;
import org.eclipse.xtext.ui.editor.contentassist.PrefixMatcher;
import org.eclipse.xtext.ui.editor.contentassist.antlr.AntlrProposalConflictHelper;
import org.eclipse.xtext.ui.editor.contentassist.antlr.DelegatingContentAssistContextFactory;
import org.eclipse.xtext.ui.editor.outline.IOutlineTreeProvider;
import org.eclipse.xtext.ui.editor.outline.impl.IOutlineTreeStructureProvider;
import org.eclipse.xtext.ui.editor.preferences.IPreferenceStoreInitializer;
import org.eclipse.xtext.ui.editor.quickfix.IssueResolutionProvider;
import org.eclipse.xtext.ui.editor.templates.XtextTemplatePreferencePage;
import org.eclipse.xtext.ui.refactoring.IDependentElementsCalculator;
import org.eclipse.xtext.ui.refactoring.IReferenceUpdater;
import org.eclipse.xtext.ui.refactoring.IRenameRefactoringProvider;
import org.eclipse.xtext.ui.refactoring.IRenameStrategy;
import org.eclipse.xtext.ui.refactoring.impl.DefaultDependentElementsCalculator;
import org.eclipse.xtext.ui.refactoring.impl.DefaultReferenceUpdater;
import org.eclipse.xtext.ui.refactoring.impl.DefaultRenameRefactoringProvider;
import org.eclipse.xtext.ui.refactoring.impl.DefaultRenameStrategy;
import org.eclipse.xtext.ui.refactoring.ui.DefaultRenameSupport;
import org.eclipse.xtext.ui.refactoring.ui.IRenameSupport;
import org.eclipse.xtext.ui.refactoring.ui.RefactoringPreferences;
import org.eclipse.xtext.ui.resource.ResourceServiceDescriptionLabelProvider;
import org.eclipse.xtext.ui.shared.Access;
import org.eclipse.xtext.ui.validation.AbstractValidatorConfigurationBlock;
 * Manual modifications go to {@link GLVDslUiModule}.
@SuppressWarnings("all")
public abstract class AbstractGLVDslUiModule extends DefaultUiModule {
	public AbstractGLVDslUiModule(AbstractUIPlugin plugin) {
		super(plugin);
	// contributed by org.eclipse.xtext.xtext.generator.ImplicitFragment
	public Provider<? extends IAllContainersState> provideIAllContainersState() {
		return Access.getJavaProjectsState();
	// contributed by org.eclipse.xtext.xtext.generator.parser.antlr.XtextAntlrGeneratorFragment2
	public Class<? extends IProposalConflictHelper> bindIProposalConflictHelper() {
		return AntlrProposalConflictHelper.class;
	public void configureContentAssistLexer(Binder binder) {
		binder.bind(Lexer.class)
			.annotatedWith(Names.named(LexerIdeBindings.CONTENT_ASSIST))
			.to(InternalGLVDslLexer.class);
	public void configureHighlightingLexer(Binder binder) {
		binder.bind(org.eclipse.xtext.parser.antlr.Lexer.class)
			.annotatedWith(Names.named(LexerIdeBindings.HIGHLIGHTING))
			.to(com.abcd.glv.dsl.parser.antlr.internal.InternalGLVDslLexer.class);
	public void configureHighlightingTokenDefProvider(Binder binder) {
		binder.bind(ITokenDefProvider.class)
			.to(AntlrTokenDefProvider.class);
	public Class<? extends ContentAssistContext.Factory> bindContentAssistContext$Factory() {
		return DelegatingContentAssistContextFactory.class;
	public Class<? extends IContentAssistParser> bindIContentAssistParser() {
		return GLVDslParser.class;
	public void configureContentAssistLexerProvider(Binder binder) {
		binder.bind(InternalGLVDslLexer.class).toProvider(LexerProvider.create(InternalGLVDslLexer.class));
	// contributed by org.eclipse.xtext.xtext.generator.validation.ValidatorFragment2
	public Class<? extends AbstractValidatorConfigurationBlock> bindAbstractValidatorConfigurationBlock() {
		return GLVDslValidatorConfigurationBlock.class;
	// contributed by org.eclipse.xtext.xtext.generator.exporting.QualifiedNamesFragment2
	public Class<? extends PrefixMatcher> bindPrefixMatcher() {
		return FQNPrefixMatcher.class;
	public Class<? extends IDependentElementsCalculator> bindIDependentElementsCalculator() {
		return DefaultDependentElementsCalculator.class;
	// contributed by org.eclipse.xtext.xtext.generator.builder.BuilderIntegrationFragment2
	public void configureIResourceDescriptionsBuilderScope(Binder binder) {
		binder.bind(IResourceDescriptions.class).annotatedWith(Names.named(ResourceDescriptionsProvider.NAMED_BUILDER_SCOPE)).to(CurrentDescriptions.ResourceSetAware.class);
	public Class<? extends IXtextEditorCallback> bindIXtextEditorCallback() {
		return NatureAddingEditorCallback.class;
	public Class<? extends IContextualOutputConfigurationProvider> bindIContextualOutputConfigurationProvider() {
		return EclipseOutputConfigurationProvider.class;
	public void configureIResourceDescriptionsPersisted(Binder binder) {
		binder.bind(IResourceDescriptions.class).annotatedWith(Names.named(ResourceDescriptionsProvider.PERSISTED_DESCRIPTIONS)).to(IBuilderState.class);
	public Class<? extends DocumentBasedDirtyResource> bindDocumentBasedDirtyResource() {
		return PersistentDataAwareDirtyResource.class;
	// contributed by org.eclipse.xtext.xtext.generator.generator.GeneratorFragment2
	public Class<? extends IXtextBuilderParticipant> bindIXtextBuilderParticipant() {
		return BuilderParticipant.class;
	public IWorkspaceRoot bindIWorkspaceRootToInstance() {
		return ResourcesPlugin.getWorkspace().getRoot();
	public void configureBuilderPreferenceStoreInitializer(Binder binder) {
		binder.bind(IPreferenceStoreInitializer.class)
			.annotatedWith(Names.named("builderPreferenceInitializer"))
			.to(BuilderPreferenceAccess.Initializer.class);
	// contributed by org.eclipse.xtext.xtext.generator.ui.labeling.LabelProviderFragment2
	public Class<? extends ILabelProvider> bindILabelProvider() {
		return GLVDslLabelProvider.class;
	public void configureResourceUIServiceLabelProvider(Binder binder) {
		binder.bind(ILabelProvider.class).annotatedWith(ResourceServiceDescriptionLabelProvider.class).to(GLVDslDescriptionLabelProvider.class);
	// contributed by org.eclipse.xtext.xtext.generator.ui.outline.OutlineTreeProviderFragment2
	public Class<? extends IOutlineTreeProvider> bindIOutlineTreeProvider() {
		return GLVDslOutlineTreeProvider.class;
	public Class<? extends IOutlineTreeStructureProvider> bindIOutlineTreeStructureProvider() {
	// contributed by org.eclipse.xtext.xtext.generator.ui.quickfix.QuickfixProviderFragment2
	public Class<? extends IssueResolutionProvider> bindIssueResolutionProvider() {
		return GLVDslQuickfixProvider.class;
	// contributed by org.eclipse.xtext.xtext.generator.ui.contentAssist.ContentAssistFragment2
	public Class<? extends IContentProposalProvider> bindIContentProposalProvider() {
		return GLVDslProposalProvider.class;
	// contributed by org.eclipse.xtext.xtext.generator.ui.refactoring.RefactorElementNameFragment2
	public void configureIPreferenceStoreInitializer(Binder binder) {
			.annotatedWith(Names.named("RefactoringPreferences"))
			.to(RefactoringPreferences.Initializer.class);
	public Class<? extends IRenameStrategy> bindIRenameStrategy() {
		return DefaultRenameStrategy.class;
	public Class<? extends IReferenceUpdater> bindIReferenceUpdater() {
		return DefaultReferenceUpdater.class;
	public Class<? extends IRenameRefactoringProvider> bindIRenameRefactoringProvider() {
		return DefaultRenameRefactoringProvider.class;
	public Class<? extends IRenameSupport.Factory> bindIRenameSupport$Factory() {
		return DefaultRenameSupport.Factory.class;
	// contributed by org.eclipse.xtext.xtext.generator.ui.templates.CodetemplatesGeneratorFragment2
	public Provider<? extends TemplatesLanguageConfiguration> provideTemplatesLanguageConfiguration() {
		return AccessibleCodetemplatesActivator.getTemplatesLanguageConfigurationProvider();
	public Provider<? extends LanguageRegistry> provideLanguageRegistry() {
		return AccessibleCodetemplatesActivator.getLanguageRegistry();
	@SingletonBinding(eager=true)
	public Class<? extends LanguageRegistrar> bindLanguageRegistrar() {
		return LanguageRegistrar.class;
	public Class<? extends XtextTemplatePreferencePage> bindXtextTemplatePreferencePage() {
		return AdvancedTemplatesPreferencePage.class;
	public Class<? extends IPartialEditingContentAssistParser> bindIPartialEditingContentAssistParser() {
		return PartialGLVDslContentAssistParser.class;
	public Class<? extends IPartialEditingContentAssistContextFactory> bindIPartialEditingContentAssistContextFactory() {
		return PartialEditingContentAssistContextFactory.class;
	// contributed by org.eclipse.xtext.xtext.generator.ui.compare.CompareFragment2
	public Class<? extends IViewerCreator> bindIViewerCreator() {
		return DefaultViewerCreator.class;
	public void configureCompareViewerTitle(Binder binder) {
		binder.bind(String.class).annotatedWith(Names.named(UIBindings.COMPARE_VIEWER_TITLE)).toInstance("GLVDsl Compare");
Re: Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater [message #1862804 is a reply to message #1862802] Fri, 29 December 2023 10:33 Go to previous messageGo to next message
uriExtension="glv">
</extension>
No global here
Did you really compare with plugin..xml_gen
Re: Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater [message #1862805 is a reply to message #1862804] Fri, 29 December 2023 10:48 Go to previous messageGo to next message
I synchronized plugin.xml_gen and plugin.xml。
<plugin>
	<extension
		<editor
        default="true"
        extensions="global"
		</editor>
	</extension>
	<extension
		<handler
			<activeWhen>
				<reference
				</reference>
			</activeWhen>
		</handler>
		<handler
			<activeWhen>
				<reference
				</reference>
			</activeWhen>
		</handler>
		<handler
			<activeWhen>
			</activeWhen>
		</handler>
		<handler
			<activeWhen>
				<and>
					<iterate>
					</iterate>
				</and>
			</activeWhen>
		</handler>
	</extension>
			<and>
				</with>
			</and>
		</definition>
			<and>
				</with>
			</and>
		</definition>
	</extension>
	<extension
		<page
			name="GLVDsl">
		</page>
		<page
		</page>
		<page
			name="Templates">
		</page>
	</extension>
	<extension
		<page
			name="GLVDsl">
			<enabledWhen>
			</enabledWhen>
		</page>
	</extension>
	<extension
		<keyword
			label="GLVDsl"/>
	</extension>
	<extension
		<command
			name="Validate">
		</command>
		<command
		</command>
		<command
		</command>
	</extension>
		<menuContribution
			<command
				style="push"
					<reference
					</reference>
				</visibleWhen>
			</command>
		</menuContribution>
				</visibleWhen>
			</command>
		</menuContribution>
				</visibleWhen>
			</command>
		</menuContribution>
					<and>
						<iterate>
						</iterate>
					</and>
				</visibleWhen>
			</command>
		</menuContribution>
	</extension>
					</reference>
				</visibleWhen>
			</command>
		</menuContribution>
	</extension>
		<handler
			<activeWhen>
				<reference
				</reference>
			</activeWhen>
		</handler>
	</extension>
		<content-type
			file-extensions="global"
			name="GLVDsl File"
			priority="normal">
		</content-type>
	</extension>
	<extension
		<parser
			type="global">
		</parser>
	</extension>
			uriExtension="global">
	</extension>
	<extension
	</extension>
	<extension
	</extension>
	<extension
	</extension>
		<page
		</page>
	</extension>
		<participant
			fileExtensions="global"/>
	</extension>
		<page
			name="Compiler">
		</page>
	</extension>
		<page
			name="Compiler">
			<enabledWhen>
			</enabledWhen>
		</page>
	</extension>
			<command
				style="push">
				</visibleWhen>
			</command>
		</menuContribution>
	</extension>
		<handler
			<activeWhen>
			</activeWhen>
		</handler>
	</extension>
	<extension
		<handler
			<activeWhen>
				<reference
				</reference>
			</activeWhen>
		</handler>
	</extension>
	<extension
		<command
		</command>
	</extension>
		<menuContribution
				style="push"
				</visibleWhen>
			</command>
		</menuContribution>
	</extension>
	<extension
			<attribute
				name="FIXABLE_KEY"
				value="true">
			</attribute>
			<attribute
				name="FIXABLE_KEY"
				value="true">
			</attribute>
			<attribute
				name="FIXABLE_KEY"
				value="true">
			</attribute>
	</extension>
		<handler
			<activeWhen>
				<reference
				</reference>
			</activeWhen>
		</handler>
	</extension>
		<menuContribution
				style="push">
					<reference
					</reference>
				</visibleWhen>
			</command>
		</menuContribution>
	</extension>
		<page
			name="Refactoring">
		</page>
	</extension>
			extensions="global">
		</viewer>
		<contentTypeBinding
	</extension>
			extensions="global" label="GLVDsl Compare">
		</viewer>
		<contentTypeBinding
	</extension>
		</provider>
	</extension>
		<fileTypes
			extension="global"
			type="text">
		</fileTypes>
	</extension>
</plugin>
But the referenceUpdater filed in OptionalReferenceUpdaterProxy is still null.
[Updated on: Fri, 29 December 2023 10:50] by Moderator
Re: Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater [message #1862806 is a reply to message #1862805] Fri, 29 December 2023 11:03 Go to previous messageGo to next message
Can you please provide reproduction project I can simply import and run. Also with sample model files and what to rename
Re: Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater [message #1862807 is a reply to message #1862806] Fri, 29 December 2023 11:30 Go to previous messageGo to next message
(in a fresh hello world project this works perfectly fine)
Re: Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater [message #1862808 is a reply to message #1862807] Fri, 29 December 2023 11:46 Go to previous messageGo to next message
That was interesting.Can you upload your projects to me ?
Re: Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater [message #1862809 is a reply to message #1862807] Fri, 29 December 2023 11:58 Go to previous messageGo to next message
https://github.com/cdietrich/xtext-two-dsls
Re: Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater [message #1862814 is a reply to message #1862809] Sat, 30 December 2023 00:00 Go to previous messageGo to next message
I found the reason that the field referenceUpdater in object of OptionalReferenceUpdaterProxy was null.
index.php/fa/43871/0/
In My GLVUtils.class, I created object of GLVDslStandaloneSetup.
index.php/fa/43870/0/
In the register method of GLVDslStandaloneSetup, the following code will regester DefaultResourceServiceProvider.
index.php/fa/43874/0/
I commented out those codes,then the "rename element" worked well.
index.php/fa/43873/0/
Thank you for your help! And Happy New Year!
新年快乐!
[Updated on: Sat, 30 December 2023 00:10] by Moderator
Re: Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater [message #1862815 is a reply to message #1862814] Sat, 30 December 2023 02:13 Go to previous messageGo to next message
Never ever call stand-alone setup from code that runs in eclipse
Re: Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater [message #1862816 is a reply to message #1862815] Sat, 30 December 2023 02:16 Go to previous messageGo to next message
I need to parse DSL source code file, what do i do ?
Re: Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater [message #1862817 is a reply to message #1862816] Sat, 30 December 2023 02:27 Go to previous messageGo to next message
Sorry, I asked chatgpt.It told me how to do .
Thanks a lot !
Re: Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater [message #1862819 is a reply to message #1862817] Sat, 30 December 2023 02:41 Go to previous message
for completeness: http://koehnlein.blogspot.com/2012/11/xtext-tip-how-do-i-get-guice-injector.html
Previous Topic:How do I implement the "Find References" function?
Next Topic:Cross references
Current Time: Wed Jun 18 20:30:00 EDT 2025
Powered by FUDForum. Page generated in 0.09747 seconds
