Can't convert diagram to PapyrusUMLComponentDiagram [message #1820786] |
Tue, 28 January 2020 19:10  |
Adrian Bernal Bermejo Messages: 11 Registered: May 2017 |
Junior Member |
I have a problem when I switch the architecture context and my diagram is converted to the uml component diagram.
When the method convertDiagram(Diagram diagram) from org.eclipse.papyrus.uml.architecture.commands.UMLModelConversionCommand is executed, the type of element represented by the diagram is compared in order to know if the component diagram element is a package or a component. As the class org.eclipse.uml2.uml.Package is not imported, the class of the element is compared to java.lang.Package. So that diagramKind is not initialized and the conversion is not done.
Is there a workaround to make it work for my plugin?
Thanks.
package org.eclipse.papyrus.uml.architecture.commands;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.gmf.runtime.notation.Diagram;
import org.eclipse.papyrus.infra.architecture.ArchitectureDomainManager;
import org.eclipse.papyrus.infra.core.architecture.RepresentationKind;
import org.eclipse.papyrus.infra.core.resource.ModelSet;
import org.eclipse.papyrus.infra.gmfdiag.common.model.NotationUtils;
import org.eclipse.papyrus.infra.gmfdiag.common.utils.DiagramUtils;
import org.eclipse.papyrus.infra.gmfdiag.representation.PapyrusDiagram;
import org.eclipse.papyrus.infra.gmfdiag.style.PapyrusDiagramStyle;
import org.eclipse.papyrus.infra.gmfdiag.style.StyleFactory;
import org.eclipse.papyrus.infra.nattable.model.nattable.Table;
import org.eclipse.papyrus.infra.nattable.representation.PapyrusTable;
import org.eclipse.papyrus.uml.architecture.UMLArchitectureContextIds;
import org.eclipse.papyrus.uml.architecture.UMLDiagramKinds;
import org.eclipse.papyrus.uml.architecture.UMLDiagramTypes;
import org.eclipse.papyrus.uml.architecture.UMLTableKinds;
import org.eclipse.papyrus.uml.diagram.common.commands.AbstractModelConversionCommand;
import org.eclipse.uml2.uml.Component;
import org.eclipse.uml2.uml.StructuredClassifier;
* A command to convert a model from an arbitrary context to the UML language context
public class UMLModelConversionCommand extends AbstractModelConversionCommand {
* @see org.eclipse.papyrus.uml.diagram.common.commands.ModelConversionCommandBase#doConvertModel(org.eclipse.papyrus.infra.core.resource.ModelSet)
* @param modelSet
public void doConvertModel(ModelSet modelSet) {
final Resource notationResource = NotationUtils.getNotationResource(modelSet);
if (notationResource != null) {
for (EObject eObject : notationResource.getContents()) {
if (eObject instanceof Diagram)
convertDiagram((Diagram)eObject);
else if (eObject instanceof Table)
convertTable((Table)eObject);
@SuppressWarnings("unchecked")
protected void convertDiagram(Diagram diagram) {
// get the existing diagram kind id if any
String diagramKindId = null;
PapyrusDiagramStyle pvs = DiagramUtils.getPapyrusDiagramStyle(diagram);
if (pvs != null) {
diagramKindId = pvs.getDiagramKindId();
// return if the existing diagram kind is already in the UML language
if (diagramKindId != null) {
PapyrusDiagram kind = getDiagramKindById(diagramKindId);
if (kind != null && UMLArchitectureContextIds.UML.equals(kind.getLanguage().getId())) {
return;
// Choose a UML diagram kind based on the diagram's type (and the diagram's element)
PapyrusDiagram diagramKind = null;
if (UMLDiagramTypes.ACTIVITY_DIAGRAM.equals(diagram.getType())) {
diagramKind = getDiagramKindById(UMLDiagramKinds.ACTIVITY_DIAGRAM);
} else if (UMLDiagramTypes.CLASS_DIAGRAM.equals(diagram.getType())) {
diagramKind = getDiagramKindById(UMLDiagramKinds.CLASS_DIAGRAM);
} else if (UMLDiagramTypes.COMMUNICATION_DIAGRAM.equals(diagram.getType())) {
diagramKind = getDiagramKindById(UMLDiagramKinds.COMMUNICATION_DIAGRAM);
} else if (UMLDiagramTypes.COMPONENT_DIAGRAM.equals(diagram.getType())) {
if (diagram.getElement() instanceof Component) {
diagramKind = getDiagramKindById(UMLDiagramKinds.COMPONENT_DIAGRAM_IN_COMPONENT);
} else if (diagram.getElement() instanceof Package) {
diagramKind = getDiagramKindById(UMLDiagramKinds.COMPONENT_DIAGRAM_IN_PACKAGE);
} else if (UMLDiagramTypes.COMPOSITE_STRUCTURE_DIAGRAM.equals(diagram.getType())) {
if (diagram.getElement() instanceof StructuredClassifier) {
diagramKind = getDiagramKindById(UMLDiagramKinds.COMPOSITE_STRUCTURE_DIAGRAM_IN_STRUCTURED_CLASSIFIER);
diagramKind = getDiagramKindById(UMLDiagramKinds.COMPOSITE_STRUCTURE_DIAGRAM_IN_PACKAGE);
} else if (UMLDiagramTypes.DEPLOYMENT_DIAGRAM.equals(diagram.getType())) {
diagramKind = getDiagramKindById(UMLDiagramKinds.DEPLOYMENT_DIAGRAM);
} else if (UMLDiagramTypes.INTERACTION_OVERVIEW_DIAGRAM.equals(diagram.getType())) {
diagramKind = getDiagramKindById(UMLDiagramKinds.INTERACTION_OVERVIEW_DIAGRAM);
} else if (UMLDiagramTypes.PROFILE_DIAGRAM.equals(diagram.getType())) {
diagramKind = getDiagramKindById(UMLDiagramKinds.PROFILE_DIAGRAM);
} else if (UMLDiagramTypes.SEQUENCE_DIAGRAM.equals(diagram.getType())) {
diagramKind = getDiagramKindById(UMLDiagramKinds.SEQUENCE_DIAGRAM);
} else if (UMLDiagramTypes.STATE_MACHINE_DIAGRAM.equals(diagram.getType())) {
diagramKind = getDiagramKindById(UMLDiagramKinds.STATE_MACHINE_DIAGRAM);
} else if (UMLDiagramTypes.TIMING_DIAGRAM.equals(diagram.getType())) {
diagramKind = getDiagramKindById(UMLDiagramKinds.TIMING_DIAGRAM);
} else if (UMLDiagramTypes.USE_CASE_DIAGRAM.equals(diagram.getType())) {
diagramKind = getDiagramKindById(UMLDiagramKinds.USE_CASE_DIAGRAM);
// set the new diagram kind
if (diagramKind != null) {
if (pvs == null){
pvs = StyleFactory.eINSTANCE.createPapyrusDiagramStyle();
pvs.setOwner(diagram.getElement());
diagram.getStyles().add(pvs);
pvs.setDiagramKindId(diagramKind.getId());
protected void convertTable(Table table) {
String tableKindId = table.getTableKindId();
// return if the existing table kind is already in the UML language
if (tableKindId != null) {
RepresentationKind kind = getTableKindById(tableKindId);
return;
// set the new table kind to a generic table (to make it visible in the model explorer)
// this does not by itself make the table readable under the UML context
PapyrusTable kind = getTableKindById(UMLTableKinds.GENERIC_TABLE);
if (kind != null) {
table.setTableKindId(kind.getId());
table.setTableConfiguration(kind.getConfiguration());
* Gets a diagram kind that matches the given id
private PapyrusDiagram getDiagramKindById(String id) {
ArchitectureDomainManager manager = ArchitectureDomainManager.getInstance();
RepresentationKind kind = manager.getRepresentationKindById(id);
return (kind instanceof PapyrusDiagram)? (PapyrusDiagram) kind : null;
* Gets a sync table kind that matches the given id
private PapyrusTable getTableKindById(String id) {
return (kind instanceof PapyrusTable)? (PapyrusTable) kind : null;
[Updated on: Tue, 28 January 2020 19:18] Report message to a moderator
FUDForum. Page generated in 0.01801 seconds
