Re: Oomph generated target vs tycho [message #1820678 is a reply to message #1820658] |
Sun, 26 January 2020 06:50 |
Ed Merks Messages: 33133 Registered: July 2009 |
Yes, the problem was different and is resolved.
In your case, the *.target itself appears to be correct and from looking at the IU dependencies, it involves features including/requirement other features, which transitively do include the plugin that fails to resolve with Tycho but succeeds in resolving when activating the *.target with PDE in the IDE. I didn't see anything odd about the requirement dependency chain that would explain why Tycho doesn't follow it and resolve the plugin while p2/PDE does. There were issues such as using planner versus slicer, but I believe you've tried using planner instead of slicer (as was in your attachment), and you said that also failed. I asked about the use of <optionalDependencies>ignore</optionalDependencies> in your case.
To actually help with your problem, I really need to be able to reproduce it locally, including being able to execute the Maven/Tycho build step.
I notice now that https://tesat-gitlab.factorplus.de/setup/oomph-blockdiagram/raw/master/oomph.setup/Blockdiagram.setup is public, so I will give it a try...
Ed Merks
Re: Oomph generated target vs tycho [message #1820735 is a reply to message #1820727] |
Tue, 28 January 2020 07:55 |
I pulled the changes and could reproduce the problem with javax.xml being missing. So I debugged that and indeed the problem was very similar to the other related bug. The details are captured here and a fix is committed:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=559236#c11
This got the Tycho build running farther, but then it failed resolving the product's dependencies because org.eclipse.equinox.executable.feature.group is missing. That's not so surprising because this dependency is not needed at development time, but it's definitely needed to build the executable(s) of the product. I could fix that by adding this requirement to the targlet:<?xml version="1.0" encoding="UTF-8"?>
<p2:Requirement
xmi:version="2.0"
xmlns:p2="http://www.eclipse.org/oomph/p2/1.0"
name="org.eclipse.equinox.executable.feature.group"
versionRange="[3.8.400,4.0.0]"/>
I chose this range so that the newest version (from 2019) is resolved and generated into the *.target.
I've kicked off a nightly build, so if you get the nightly installer from here you can test with these changes:
https://wiki.eclipse.org/Eclipse_Installer
http://www.eclipse.org/downloads/download.php?file=/oomph/products/latest/eclipse-inst-win64.exe
This bug is open for providing better documentation about the target generator:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=469654
At this point, only looking at the source code will help with all the possible details:
https://git.eclipse.org/c/oomph/org.eclipse.oomph.git/tree/plugins/org.eclipse.oomph.targlets.core/src/org/eclipse/oomph/targlets/internal/core/listeners/TargetDefinitionGenerator.java
And yes, the requirements in a targlet are very general and can even be used to specify package requirements. In general one does not actually specify requirements on bundles or features. Rather everything in a p2 repository is an installable unit and each unit has provided capabilities; most capabilities are IRequiredCapability with a namespace, name, and version. Requirements are specified to require some provided capability. So you'll see your requirements are using namespace org.eclipse.equinox.p2.iu and each feature and bundle provides such a capability. By convention, a feature's IU's name ends with .feature.group. So you already have requiremments that resolve to bundles: <requirement
name="com.google.inject"
versionRange="[3.0.0,3.1.0)"/> (namespace="org.eclipse.equinox.p2.iu" is the default value for a Requirement.)
Ed Merks
FUDForum. Page generated in 0.04611 seconds
