Home » Eclipse Projects » Sirius » Properties fields in Diagram Description
Properties fields in Diagram Description [message #1818041] Wed, 04 December 2019 16:36 Go to next message
Hello everyone,
In my meta-model, my class' attributes use EString type. Consequently, in the representation diagram I can write a string for the attributes of this class.
https://i.postimg.cc/nh2kFCJV/Selection-002.png
However, I would like to be able to write more complex string, not only on one line, but a text taking into account the new lines and tabulations. Exactly as when we want to enter an expression in the design:
https://i.postimg.cc/jSbgqpnc/Selection-001.png
Is it possible to do that? (it is ok for me if I have to use another class than EString).
Thank you,
Mickael
Re: Properties fields in Diagram Description [message #1818116 is a reply to message #1818041] Fri, 06 December 2019 08:51 Go to previous messageGo to next message
Maxime Porhel is currently offline Maxime PorhelFriend
Hi Mickael,
It seems that you might need to take a look to the Sirius properties views section of the Specifier manual : https://www.eclipse.org/sirius/doc/specifier/properties/Properties_View_Description.html.
The Text Area widget should correspond to your need.
You might also take a look to the corresponding tutorial https://wiki.eclipse.org/Sirius/Tutorials/PropertiesViewTutorial
Maxime Porhel - Obeo
Re: Properties fields in Diagram Description [message #1818505 is a reply to message #1818116] Tue, 17 December 2019 21:17 Go to previous message
Hi Maxime,
It is exactly what I was looking for. Thank you for your reply.
Sincerely,
Mickael
Previous Topic:How to let Edge end hook up to a border of a Node
Next Topic:Obeo's BPMN Designer
Current Time: Thu Dec 03 12:22:28 GMT 2020
Powered by FUDForum. Page generated in 0.02294 seconds
