Home » Eclipse Projects » Mosquitto » Mosquito does not start when any ip interface is down(Mosquitto does not start if any of ip interfaces in configuration file is down)
Mosquito does not start when any ip interface is down [message #1801377] Thu, 17 January 2019 22:02
Jean-Philippe BRUNET is currently offline Jean-Philippe BRUNETFriend
Mosquitto does not start if any of ip interfaces in configuration file is down.
I have a basic configuration with two interface, a local interface, and a vpn interface wich is not necessary up
If I comment listener VPN interface mosquitto always start
If I uncomment listener VPN interface mosquitto always start if VPN is up, and crashes if VPN is down.
Is there a way to tell mosquitto to start on active interfaces, and connect to others interfaces when they become available?
###### configuration file #######
# local (to be sure interface is up)
bind_address 127.0.0.1
# vpn interface,( not necessary up)
listener 1883 10.8.0.10
protocol mqtt
Previous Topic:MQTT Broker - Topic remap or message edit
Next Topic:OpenSSL error....can't figure it out
Current Time: Tue Feb 18 23:05:47 GMT 2020
Powered by FUDForum. Page generated in 0.01836 seconds
