Home » Eclipse Projects » Sirius » I can´t install Epsilon in Obeo Designer 11.0(Install Epsilon)
I can´t install Epsilon in Obeo Designer 11.0 [message #1797785] Tue, 06 November 2018 12:08 Go to next message
Cristian Gómez is currently offline Cristian GómezFriend
Hi everyone,
I need install the Epsilon 1.5 plugins for my Obeo Designer 11.0 but the wizards can't complete the installation. I attach an image of the problem. Any idea to solve the problem?
Thank you so much,
Cristian.
[Updated on: Tue, 06 November 2018 12:09]
Report message to a moderator
Re: I can´t install Epsilon in Obeo Designer 11.0 [message #1797786 is a reply to message #1797785] Tue, 06 November 2018 12:16 Go to previous messageGo to next message
Ed Willink is currently offline Ed WillinkFriend
You have provided a screen shot of the useless 'solution' rather than a copy and paste log of the original problem so it is hard to know what your problem is.
I have been using Epsilon 1.5 on recent platforms with only a minor testing problem [1]. But I think that it is very unlikely that this would cause an install problem.
Ed Willink
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=538063
Re: I can´t install Epsilon in Obeo Designer 11.0 [message #1797792 is a reply to message #1797786] Tue, 06 November 2018 12:54 Go to previous messageGo to next message
Sorry I haven't attacched this photo where the errors are shown.
Thanks.
  • Attachment: errors.png
    (Size: 27.50KB, Downloaded 25 times)
Re: I can´t install Epsilon in Obeo Designer 11.0 [message #1797794 is a reply to message #1797792] Tue, 06 November 2018 13:09 Go to previous messageGo to next message
Once again you have provide an inadequate screen shot showing just two levels of the error message. A copy and paste would show all and allow me to copy in turn.
From what you show it would appear that XSD is missing suggesting that you have a limited EMF install and have not permitted the install to search for more either by allowing contact all sites or by providing a useful EMF site.
Correction: I have been successfully using 1.5.0. It appears that 1.5.1 has silently displaced 1.5.0. Epsilon does not provide versioned update sites.
Ed Willink
Re: I can´t install Epsilon in Obeo Designer 11.0 [message #1797952 is a reply to message #1797794] Fri, 09 November 2018 07:15 Go to previous messageGo to next message
I solved the problem by following these installation steps in order:
Eclipse Photon Repository: http://download.eclipse.org/releases/photon/ (Install: Equinox Target Components)
GMF Tooling: http://download.eclipse.org/modeling/gmp/gmf-tooling/updates/releases/ (Install: Graphical Modelling Framework (GMF) Tooling SDK)
Epsilon 1.5.1: http://download.eclipse.org/epsilon/updates/
Thank you so much,
Cristian.
Re: I can´t install Epsilon in Obeo Designer 11.0 [message #1798082 is a reply to message #1797952] Mon, 12 November 2018 09:11 Go to previous message
Your problems prompted me to look at Epsilon/QVTo/GMF Tooling issues and it appears that having got past your installation problem you will soon hit the NPE during GMFgen problem.
GMF Tooling unfortunately uses internal QVTo API, which the QVTo project has twice evolved (in 2013 and 2016) breaking GMF Tooling on each occasion. You must therefore use an old version of QVTo to match the old version of the see,mingly dead GMF Tooling project.
However, since GMF Tooling is clearly still in use, I was inspired to try and re-instate the internal APIs and avoid the need for an old QVTo. See [1]
If you download and try
https://hudson.eclipse.org/qvt-oml/job/qvto-branch-tests/70/artifact/releng/org.eclipse.qvto.releng.build-site/target/org.eclipse.qvto-3.9.1.N20181109-1902.zip
you should find two API breakages re-instated. Once we have confirmation that this makes GMF Tooling useful again we can look to include the fixes in the next QVTo release.
Ed Willink
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=540971
Previous Topic:Sirius based RCP creation
Next Topic:API for edge creation?
Current Time: Mon Jan 25 16:41:21 GMT 2021
Powered by FUDForum. Page generated in 0.02548 seconds
