Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Detect Retina Display on MacOSX
Detect Retina Display on MacOSX [message #1791219] Tue, 26 June 2018 07:24
Marcel Austenfeld is currently offline Marcel AustenfeldFriend
I would like to detect reliable a Retina display on MacOSX. Is there a standard method available in the SWT API?
Background: I have some Swing component fonts which I have to scale down on a Retina display.
So far I found only this suggestions:
https://stackoverflow.com/questions/20767708/how-do-you-detect-a-retina-display-in-java
https://stackoverflow.com/questions/40399643/how-to-find-real-display-density-dpi-from-java-code/40399909#40399909
Previous Topic:Swing/SWT Integration without using JApplet
Next Topic:Detect Retina Display on MacOSX
Current Time: Wed Sep 19 20:34:35 GMT 2018
Powered by FUDForum. Page generated in 0.02174 seconds
