Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Swing/SWT Integration without using JApplet(Embed Swing in SWT without using JApplet)
Swing/SWT Integration without using JApplet [message #1790700] Thu, 14 June 2018 15:50
Page Wang is currently offline Page WangFriend
I need to embed some Swing widgets into SWT. I found many examples showing how to do it using SWT_AWT along with JApplet. But since JApplet will be deprecated in future JDK, I am looking for a replacement.
Can someone suggest any other ways to do this?
I tried to use JRootPane instead of JApplet, but find some side effects. According to the article found [ http://www.eclipse.org/articles/article.php?file=Article-Swing-SWT-Integration/index.html ], I should use a heavyweight component (under section "Creating a Root Pane Container"). But I couldn't find any other heavyweight component to use other than JApplet.
Any help is greatly appreciated!
Thanks.
Previous Topic:Swing/SWT Integration without using JApplet
Next Topic:Swing/SWT Integration without using JApplet
Current Time: Fri Nov 16 11:21:55 GMT 2018
Powered by FUDForum. Page generated in 0.07322 seconds
