Home » Eclipse Projects » Standard Widget Toolkit (SWT) » WrappedPageBook change layout
WrappedPageBook change layout [message #1780116] Wed, 17 January 2018 14:12
Adam Bialas is currently offline Adam BialasFriend
Is it possible to change WrappedPageBook layout? By default, it is set to PageBookLayout inner class of WrappedPageBook. The problem is its implementation - especially method computeMinimumWidth which takes 0 as a value for width hint. This causes that horizontal scroll is never shown if we use ScrolledPageBook (which uses WrappedPageBook inside).
I wanted to change the layout of WrappedPageBook and fix the implementation of computeMinimumWidth method so it will calculate correct value but WrappedPageBook inside method computeSize cast layout to the PageBookLayout.
Is there any possibility to customize it? I am using ScrolledPageBook from org.eclipse.ui.forms.DetailsPart.
Adam
Previous Topic:WrappedPageBook change layout
Next Topic:SashForm and DRAG_MINIMUM
Current Time: Thu Sep 20 19:06:03 GMT 2018
Powered by FUDForum. Page generated in 0.01984 seconds
