Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Not responding
Not responding [message #1777423] Wed, 29 November 2017 10:33
Ali Sedaghat is currently offline Ali SedaghatFriend
I've implemented a jface wizard in my swt application. In one page of this wizard a time-consuming operation is monitored by the wizard's progress monitor as follows:
getContainer().run(true, false, new IRunnableWithProgress() {
	public void run(IProgressMonitor monitor)
		throws InvocationTargetException, InterruptedException {
monitor.beginTask("", IProgressMonitor.UNKNOWN);
      getShell().getDisplay().asyncExec(new Runnable() {
	public void run() {
					//my operation
monitor.done();
The problem is that the application becomes not responding a little while after the operation starts. It seems that the fork parameter has no effect, becuase my operation is executed by the UI thread!!!
Previous Topic:Not responding
Next Topic:Insert a text box in between a composite from super class
Current Time: Thu Sep 20 18:01:22 GMT 2018
Powered by FUDForum. Page generated in 0.01770 seconds
