Re: Eclipse can't download update [message #1775394 is a reply to message #1775393] |
Sun, 29 October 2017 10:55 |
Horacio Anton Quiles Messages: 12 Registered: June 2016 |
Junior Member |
Actually, I have to qualify that: even the downloaded repository behaves strangely. It started installing, but then stalled for a long time, and the error log shows 3 warnings like this:
eclipse.buildId=4.7.1.M20171009-0410
java.version=1.8.0_51
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_AU
Framework arguments: -product org.eclipse.epp.package.cpp.product -product org.eclipse.epp.package.cpp.product -product org.eclipse.epp.package.cpp.product -product org.eclipse.epp.package.cpp.product -keyring /Users/mija/.eclipse_keyring
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -product org.eclipse.epp.package.cpp.product -product org.eclipse.epp.package.cpp.product -product org.eclipse.epp.package.cpp.product -data file:/Users/mija/programming/Eclipse_workspace_Oxygenized/ -product org.eclipse.epp.package.cpp.product -keyring /Users/mija/.eclipse_keyring
org.eclipse.equinox.p2.transport.ecf
Warning
Sun Oct 29 11:42:49 CET 2017
Connection to http://download.eclipse.org/egit/updates/plugins/org.eclipse.jgit.archive_4.9.0.201710071750-r.jar failed on download.eclipse.org:80 failed to respond. Retry attempt 0 started
org.apache.http.NoHttpResponseException: download.eclipse.org:80 failed to respond
at org.apache.http.impl.conn.DefaultHttpResponseParser.parseHead(DefaultHttpResponseParser.java:143)
at org.apache.http.impl.conn.DefaultHttpResponseParser.parseHead(DefaultHttpResponseParser.java:57)
at org.apache.http.impl.io.AbstractMessageParser.parse(AbstractMessageParser.java:259)
at org.apache.http.impl.AbstractHttpClientConnection.receiveResponseHeader(AbstractHttpClientConnection.java:281)
at org.apache.http.impl.conn.DefaultClientConnection.receiveResponseHeader(DefaultClientConnection.java:259)
at org.apache.http.impl.conn.AbstractClientConnAdapter.receiveResponseHeader(AbstractClientConnAdapter.java:232)
at org.apache.http.protocol.HttpRequestExecutor.doReceiveResponse(HttpRequestExecutor.java:273)
at org.apache.http.protocol.HttpRequestExecutor.execute(HttpRequestExecutor.java:125)
at org.apache.http.impl.client.DefaultRequestDirector.tryExecute(DefaultRequestDirector.java:686)
at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:488)
at org.apache.http.impl.client.AbstractHttpClient.doExecute(AbstractHttpClient.java:884)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:82)
at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1084)
at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1075)
at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:1071)
at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:74)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:56)
The 3 events appear simultaneously and all of them say "retry 0" (I would expect them to appear each some time after the previous one, and with a different retry count)
Still, the install did finish without an error, and Eclipse no longer reports available updates.
Re: Eclipse can't download update [message #1777850 is a reply to message #1775994] |
Tue, 05 December 2017 10:01 |
Junior Member |
Just in case it helps in the future: I kept having this problem, today Eclipse notified me of a JGit/EGit update but failed to install it (server timeout).
The interesting thing is that I switched ISP (from cable to cell) and it downloaded correctly.
This is weird, I can't think of anything else in my computer showing this kind of problem. There are no proxies or firewalls involved, at least in my side of the ISPs.
[Updated on: Tue, 05 December 2017 10:02] Report message to a moderator
FUDForum. Page generated in 0.04496 seconds
