Home » Modeling » Epsilon » Register EPackage on startup
Register EPackage on startup [message #1775317] Fri, 27 October 2017 14:41 Go to next message
louis andia. is currently offline louis andia.Friend
Member
My ecore is registered with Epsilon and working fine. I can open a model with MoDisco without problem each time i restart Eclipse and without to register my ecore again.
The problem is when i start Eclipse on a model file opened, it's like Eclipse try to open and display my model before Epsilon is loaded and EPackage is registered.
So, there is a way to tell Eclipse to load the plugin before trying to open the active file? Or the only way is to be sure when i close Eclipse the file open is not a model?
I hope it's clear.
Thank you.
Re: Register EPackage on startup [message #1775357 is a reply to message #1775317] Sat, 28 October 2017 09:44 Go to previous message
Dimitris Kolovos is currently offline Dimitris KolovosFriend
Hi Louis,
We'd need to tweak Exeed to force metamodel registration on startup to achieve this. Could you please file an enhancement request in the Bugzilla?
Dimitris
Previous Topic:EOL stansalone problem
Next Topic:ETL - Reuse trace model from one phase as source model in another phase
Current Time: Wed Jul 18 21:43:47 GMT 2018
Powered by FUDForum. Page generated in 0.01898 seconds
