Home » Eclipse Projects » Eclipse Platform » image decorator problem on table viewer .
image decorator problem on table viewer . [message #332535] Mon, 27 October 2008 15:17 Go to next message
Hi all ,
I have defined my Label Decorator based on the object type
<extension
point="org.eclipse.ui.decorators">
<decorator
adaptable="false"
class="com.rse.sevices.files.eom.decorators.LockedOnly"
id="com.rse.sevices.files.eom.decorators.LockedOnly"
label="ELocker Decorator"
lightweight="true"
location="BOTTOM_RIGHT"
state="true">
<enablement>
<objectClass
name="com.rse.sevices.files.eom.EOMHostFile">
</objectClass>
</enablement>
</decorator>
</extension>
I have got two views in my plug-in ... a treeviewer and a tableviewer
For both views I do:
---<tree>---
IWorkbench workbench = getSite().getWorkbenchWindow().getWorkbench();
viewer.setLabelProvider(new DecoratingLabelProvider (new
NavigatorViewLabelProvider(), workbench.getDecoratorManager()));
---<table>---
FolderExplorerLabelProvider (), workbench.getDecoratorManager()));
now the TreeViewer Label provider extends LabelProvider and in the get image
I do use the
Image decorated = decorator.decorateImage(image, element);
if (decorated != null)
return decorated;
to get the decorated image ... FINE ... WORKS!!!
THE PROBLEM IS IN THE TABLE VIEWER ...
public class FolderExplorerLabelProvider extends LabelProvider implements
ITableLabelProvider
I had to extends using LabelProvider to use the decorating label provider
(as I found in a few table viewer example) ...
But when it comes to rendering the table ... the getText is called instead
of the
getColumnText(Object element, int columnIndex)
what am I doing wrong?
Re: image decorator problem on table viewer . [message #332536 is a reply to message #332535] Mon, 27 October 2008 15:37 Go to previous message
note: if I set the table label provider directly to the
FolderExplorerLabelProvider everything works fine (with no decorator)
"Kar" <carmeloscala@hotmail.com> wrote in message
news:ge4m2l$cnb$1@build.eclipse.org...
> Hi all ,
> <extension
> <decorator
> adaptable="false"
> lightweight="true"
> state="true">
> <enablement>
> <objectClass
> </objectClass>
> </enablement>
> </decorator>
> </extension>
> ---<tree>---
> ---<table>---
> image I do use the
> return decorated;
> ITableLabelProvider
> of the
> Thanks
Previous Topic:using shortcuts wile in text widgets run Eclipse command instead of text behavior
Next Topic:[Databinding] POLICY_CONVERT with TableViewer and EditingSupport
Current Time: Tue Feb 18 14:31:04 GMT 2025
Powered by FUDForum. Page generated in 0.03661 seconds
