Re: Marker Annotations disapperaring in vertical toolbar [message #332497 is a reply to message #332343] |
Thu, 23 October 2008 13:38 |
Originally posted by: swanbrook66.gmail.com
gdollard wrote:
> Anyone???
> "gdollard" <glenn.dollard@gmail.com> wrote in message
> news:gdhhkp$t52$2@build.eclipse.org...
>> Hi All,
>> I'm noticing a problem with markers in our editor. Lets assume I
>> have 10 variables, each one of them has an annotation along the
>> vertical toolbar indicating that there is a problem with the variable (
>> variable not used for example).
>> Anyway, if I select some of those variables and change their type(via a
>> bulk copy and paste for example) I get different types of annotations
>> (again, this is supposed to happen in our editor, so all OK so far).
>> Now, lets say I change the data types of the variables back to their
>> original type, what I expect to see is the original annotations being
>> displayed in the vertical
>> toolbar but this is not the case for ALL variables.
>> I am noticing that some of the variables do show their correct annotation
>> but a few others don't show anything in the toolbar!
>> The underlying code for gathering and updating the error markers is
>> correct so I cannot understand why the GUI is not showing the correct
>> annotations.
>> I'm sorry if I am not clear but I am new enough to this area and it's some
>> bug fixing that I'm doing :-)
>> Can anyone give me some pointers as to where to look for the solution? Are
>> there some obvious thing I need to check first?
>> Thanks in advance!
>> g.
Doing something very similar here and also running into the same
problem. Would be interested in hearing how you get on and if you make
any progress
Thanks.
FUDForum. Page generated in 0.02916 seconds
