Home » Eclipse Projects » NatTable » How to register Jface Dialog to NatTable Cells ?
How to register Jface Dialog to NatTable Cells ? [message #1768413] Tue, 18 July 2017 12:43 Go to next message
Gaurav Tripathi is currently offline Gaurav TripathiFriend
Member
Currently, I created one dialog which extends Jface TitleAreaDialog.
How can I register this dialog with my NatTable cells?
I want that whenever the user clicks on NatTable cell of registered label column, my dialog should pop up and click on the Ok button should save the data in a model.
Thanks in advance.
Re: How to register Jface Dialog to NatTable Cells ? [message #1768564 is a reply to message #1768413] Thu, 20 July 2017 05:34 Go to previous message
Dirk Fauth is currently offline Dirk FauthFriend
You could register a MouseAction on such cells via custom UiBindingRegistry that opens the dialog on click.
Previous Topic:NatTable does not render cells after moving from 1.4 to 1.5
Next Topic:Selective edit of rows in Nattable
Current Time: Thu May 23 19:42:55 GMT 2019
Powered by FUDForum. Page generated in 0.01451 seconds
