Is Ant built-in/included in Eclipse v3.3.2? [message #332283] |
Thu, 16 October 2008 18:48 |
Originally posted by: markmccloud200.email.com
Is Ant built-in/included in Eclipse v3.3.2 or do I have to install it seperately?
If I have to install it in addition: How do I execute build.xml as an ANT task?
In other words: How do I use Ant from within Eclipse (not from the command
line)?
Mark
Re: Is Ant built-in/included in Eclipse v3.3.2? [message #332284 is a reply to message #332283] |
Fri, 17 October 2008 00:19 |
Originally posted by: codeslave.ca.ibm.com
It's included.
1. Open your Ant script in the Ant editor within Eclipse (you might need
to associate build.xml or *.xml with that editor first, using Window >
Preferences > File Associations).
2. Use ALT-SHIFT-X,Q to run the ant script; use ALT-SHIFT-D,Q to debug
the ant script.
OR
1. Drag the Ant script from Package Explorer into the Ant view.
2. Double-click the target within the script you want to run (or
right-click and you can select Debug As > Ant Build).
> line)?
> Mark
Nick Boldt :: http://wiki.eclipse.org/index.php/User:Nickb
Re: Is Ant built-in/included in Eclipse v3.3.2? [message #332288 is a reply to message #332283] |
Fri, 17 October 2008 08:33 |
On Thu, 16 Oct 2008 18:48:43 +0000 (UTC), markmccloud200@email.com
There is an Ant plug-in but I'm not sure if it's installed with all
packages. I have never installed an Ant seperately.
>line)?
Open the Ant View from the "Window/Show View" menu and drag your ant
script into this view. If you use "build.xml" as file name this will
work directly, otherwise you should add your filename pattern to the
Ant preferences.
Achim
Achim Lörke
Eclipse-Stammtisch in the Braunschweig, Germany area:
http://www.bredex.de/de/news/events.html
Achim Lörke
FUDForum. Page generated in 0.03430 seconds
